Question about Epson Office Equipment & Supplies
I own the 3800. When I make prints, the image prints out slightly askew on the paper. I have used the little arm to help feed larger sheets but the problem does not go away. I have this problem with 81/2x11 paper also.
  • Epson Master
  • 11,800 Answers
This is caused by a mechanical defect - the roller that pulls the paper from the tray does it incorrectly - the pickup wheel and/or the rollers are slightly misaligned or the feeder tray is not seated properly so so one of the pickup wheels grabs the sheet of paper a fraction of a moment sooner than the other.
You will have to fix that by either :
- twisting the feeder tray in the opposite direction of the printing skew (if the print goes to the left the right portion of the tray will have to be pushed slightly to the back) - or make sure the tray sits correctly;
or
- the printer will have to be opened and the pickup mechanism realigned - a job that only a well experienced repairman can do, you will have to take the printer to a dealer's repair shop.
Posted on May 27, 2011
My printed documents are coming out slightly askew, why?
check the paper tray, make sure the guide pushes the paper to one side, also make sure the back rest is at right position, meaning set for letter if letter size is used. and last check the feed rollers, if dirty, you can use alcohol to clean, i use WD40, and wipe off excess that rubber does not absorb.
Sep 30, 2010 | Dell 5210n Laser Printer
Paper feed problem- am i best off replacing
If it was feeding paper askew, I would have thought the paper track may be partially blocked. A bit of paper of debris of some sort blocking a smooth run of the paper.
Having had a real good look, see if it can find anything, the next thing I try is passing a sheet of heavy gauge paper or card maybe, to see if that clears the track. Most printers have a paper feed function which bypasses printing a document.
Mar 23, 2010 | Canon PIXMA iP90 Mobile Printer
MP830, how to retrieve faxes in memory to my PC
- A margin appears
on printouts.
2 B Paper feed
Improper paper
feeding:
- Multi-feeding
- Skewed paper
feeding
- Paper jam
- Paper feeding from the
ASF
- Plain paper
- Highest print speed
(Custom setting to 5)
- In the high temperature
and high humidity
environment
- In the low temperature
and low humidity
environment
- With the maximum
amount of paper set (13
mm)
and high humidity
environment, paper
becomes wavy; in the
low temperature and
low humidity
environment, paper
curls significantly.
When the maximum
amount of paper is set
in the ASF, and if the
paper-return tab fits in a
wave or curl of the
paper, the tab slips and
does not catch paper
properly, causing paper
feed problems.
- Reduce the amount of
paper set in the ASF to
half (approx. 5 mm
high).
- Multiple sheets of
paper feed at the
same time.
- Paper feeds at an
angle.
- A paper jam
occurs.
3 C Print results
Skewed paper
feeding (at the
level of +/- 1%)
ASF
- Credit Card size
Since coaxial tolerance
between the pinch roller
and the LF roller, which
determines the paper
feed alignment, is
0.2mm, skewed paper
feeding can occur.
However, according to
the field data of current
models, the skewness
level caused by the
coaxial tolerance of
0.2mm is within the
criteria of +/- 1%, thus
the phenomenon is left
as is.
- Align the paper guide to
the paper edge tighter
than usual.
- Paper feeds at an
angle.
- A margin appears
on printouts.
4 A Print results
Soiling on the
back side of paper
(lines or streaks
parallel to the
paper feed
direction)
- After continuous
borderless printing of
small sized paper (such
as 4 x 6), when a larger
sized paper (such as A4)
is printed.
- With Photo Paper Plus
Double Sided or
postcards, the
phenomenon is likely to
be noticeable and to be
complained of by users,
as printing is performed
on both sides of such
paper.
In borderless printing,
printing is performed to
the size slightly larger
than the paper size, and
ink off the paper is
absorbed by the platen's
ink absorber. Absorbed
ink may attach to the
platen rib(s) after
several dozen sheets are
printed, causing soiling
at the leading edge of
paper or on the back
side of paper.
1. Perform Bottom plate
cleaning (from the
MP driver or via the
operation panel) up to
3 times*1.
2. If soiling on the paper
still remains after 3
times of Bottom plate
cleaning, wipe the
platen rib(s) and their
surroundings with a
cotton swab.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
Soiling on paper in
automatic duplex
printing (lines or
streaks
perpendicular to
the paper feed
direction)
- Automatic duplex
printing (Photo Paper
Plus Double Sided,
postcards, plain paper)
On the rib(s) inside the
sheet feed unit used for
duplex printing, ink
mist may accumulate,
smearing paper.
Temporary operational
solution:
Cancel automatic duplex
printing, and manually
print each side of paper.
Cleaning by user:
cleaning (from the
3 times*1.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
- Even after Bottom
plate cleaning
was performed,
and the platen
ribs were cleaned
with cotton swab,
paper gets
smeared.
2-10
Oct 12, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Paper goes through tray 1 the image prints landscape on portait
Try placing the business card sheet in the main paper bin instead of the manual feed or adjusting the print orientation from Portrait to Landscape or vice versa.
Sep 25, 2009 | Computers & Internet
Miss feeds when print multilpe pages
The paper feed solenoid is sticking, it can be seen thru a hole in the back with the door opened. Not easy to get to, but I have been able to bend the stop tab slightly and run just fine.
Sep 02, 2009 | Konica Minolta magicolor 2300DL Laser...
Problem Printing Sheet Paper with the Epson 9800
On the machines control panel set to sheet fed (pressing the left button will change from Sheet, roll and roll with cut). In the print settings select your paper profile. On the page setup choose sheet. In the pull down menu you should only have basic paper sizes, no custom size. choose 20x30 and try again.
let me know if this helps
Feb 02, 2009 | Epson Stylus Pro 9800 InkJet Printer
HP Photosmart 7550 - Full Page Photo Printing Jams at end
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 17, 2009 | HP PhotoSmart 7550 InkJet Printer
Printer feeds in 2 or 3 sheets of paper at a time and then jams
Dears eveenz,
It seems that paper feed roller of your printer is broken. This part is integrated in drive assy. You need to replace drive assy of the printer in order to feed the paper properly. I plan to discuss this topic at Inkjet Printer Forum since I cannot post image more than 150 kb here. Explanation with image will make you know more easily. Please send me your mail to ijxpert@gmail.com so I can contact you as soon as I finish my post there.
Please rate me when you find this answer be useful for you
Regards,
Nov 08, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
HP 4250 - always prints askew with left margin at bottom approx 5mm greater than at the top. Any help greatfully received. John
It sounds like the paper is skewing as it is picked up by the roller - watch a sheet go through and see if thst is the case. Make sure the paper guide in the paper tray is pushed solidly to the left edge of the paper and check if it is loose. If it is loose then it might allow the paper to skew as it feeds in
May 09, 2008 | Office Equipment & Supplies
Paper jam/snag on hp PSC 2355
you may try to use a q-tip and some alcohol to clean the black tab[roller] it may be that a sticky substance has found it way on there, and the cleaning of may fix your problem, i hope this helps
May 06, 2007 | HP PSC 2355 All-In-One InkJet Printer
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
