Question about Sta Rite STA-RITE CONTROL BOARD KIT - 42001-0096S
I have a Sta Rite Heater for our pool, and, the digital read out no longer functions. What do I need to replace? And, is it better to replace with a second hand functioning board or just get a new one? Any idea on price? The heater was installed in 2003.
  • 910 Answers
It could just be the readout that's failed but there's no way of knowing unless you know someone else who has the same unit and you can try their readout.
The 42001-0096S has been replaced 42002-0007S as detailed on the following page where you can also purchase a replacement readout.
http://www.discountpoolmart.com/product_info.php?products_id=2765&osCsid=4csdf7fnpq38th489s1dh6uif0
Details for Flue Sensor requirements on 42002-0007S are available at the following link.
http://www.discountpoolmart.com/product_info.php?products_id=1480&osCsid=4csdf7fnpq38th489s1dh6uif0
These are probably the cheapest you'll find as most places are quoting $330 for the PCB.
In the long run it's probably worth just replacing both parts with new units.
Posted on May 27, 2011
My sta rite will not shut off, it runs all the time, the pool temp is up to 98, i have already replaced the Thermistor. The digital read out on the heater says its on 33 while its actually 98,
I would replace the user interface board. I am assuming you have a Maxithurm heater. The thermister is sending info to the temp comtrol on the user interface. A model would help me to be more accurate.
Apr 29, 2017 | Sta Rite Pool & Spa
How to fix error code 6 on a sta-rite pool heater?
Try replacing the Temp sensor. You can not just jump it out, it needs to be repaced.
May 28, 2014 | Sta Rite Sta-Rite Max-E-Therm High...
My Sta-Rite poll heater doesn't work. The heater comes on when every time I restore power to the unit, the membrain buttons only work to change the temp. ont to shut off the unit, I use the service...
This issue sounds tricky. I recommend you callthe Sta Rite technical support at 888-782-7483 and they should be able to helpyou figure this issue out.
I hope this helps.
Sep 12, 2011 | Sta Rite STA-RITE CONTROL BOARD KIT -...
The heater won't start. The temp reading is 126 F all the time. The thermistor resistance changes with temp change. No diagnostic lights are on. Does it need a control board or is there another test?
Mine is doing the same. StaRite/Pentair tech support says the thermister needs to be replaced. I have one on order and will update on my status when I get the part replaced.
May 30, 2010 | Sta Rite Sta-Rite Max-E-Therm Low NOx Pool...
Ref: Sta-Rite Max-E 400. Pool temp is about 75
Your temp sensor has gone bad and will need to be replaced. It's a small tube that slides into the water manifold and you can follow the wires back to the board. Just unplug and set a new one in place.
May 12, 2010 | Sta Rite Sta-Rite Max-E-Therm High...
Sta rite 400na gives error code 05 after about 30 seconds
I am not sure if you have received an answer to the issue, or not, but just in case! An EO5 error code is an open stack flue sensor, or switch, There are two forms of the stack flue sensor, so you will need to know which one you have on the heater.
What this error code means is that the sensor "read" the flue temp to be over 500 degrees. Usually, it is just gone bad and reading the wrong temp.
Jun 14, 2009 | Sta Rite Sta-Rite Max-E-Therm High...
Temperature reads 125 degrees.
I am not sure if you have solved this issue, or not, but just in case. The problem is the Thermister, or temp sensor. That will need to be replaced since it is reading the water temp at 125.
The Thermister is located on the manifold, left hand side, between the first two bolts. It is pretty easy to change out and this will correct the problem.
Jun 08, 2009 | Sta Rite Sr200na - Max E Therm - Pool &...
Sta Rite STA-RITE CONTROL BOARD KIT - 42001-0096S Logo
176 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
steve morris
steve morris
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
