Turned out ac unit for the first time the outisde fan isnt working
    Genius:
  • 1,033 Answers
Hello, most likey it is a bad capacitor, if you can spin tje fan by hand and it starts running it is a bad capacitor. If it does not get going by spinning it by hand than it is a bad motor.
Posted on May 27, 2011
Testimonial: "i belive its a bad capacitor i dont know how to change it tho,"
  • Robert May 29, 2011
    Turn off power to unit, open up tne panel on tne ac where thebwires enter. There should be a oval or round looking can, take off the wires and take a screwdriver with a insulated handle and discharge the capacitor by placing it across the terminals. And the simply replace with a new one. You can buy a cap at any heating and cooling store
Not working at all
you either have a bad run capacitor or low on coolant and you pressure switch isnt letting compressor come on
Mar 19, 2012 | Dometic 57915531 Air Conditioner
Ac isnt turning on. I turn the tempature control on and turn ac on but the hole unit doesnt work, i dont know if its the fuses or the ac unit itself.
if youre saying no fan, check the blower resistor down under the dash under the passenger side (relatively inexpensive) also check your fuse panels on either side of the dash for the blower fuses to be sure they are good as well.
Jul 30, 2010 | 2004 Pontiac Grand Prix
Fan not working on my CPLE36-1C AC unit outside. Why?
Hello Tim First Turn the power off! Try to turn the fan blade with a twig or something.Is it tight ? It should turn freely.If yes open the cover where the wires connect & check if the capisitor is expanded or leaking if so replace that with the SAME one (uf value&volts).Check for burnt wires also.The capicitor is a round or oval shaped can (looks like a large battery) with wires cliped/pluged in on top.Next let the motor cool off 1 hour and restore power.Does it BUZZ for a short time then stop?If yes its new motor time.Good luck
Jul 07, 2010 | Heating & Cooling
Bad Clutch Fan? Rear ac/heat don't work front only works on 4
The fan clutch isnt engaged at all times, therefore it may be normal to hold it in place (not recommended). On these trailblazer's 4.2L engine the fan clutch is electronically controlled. Usually when this vehicle's fan clutch malfunctions, there is a random ticking noise while idling or at a stop, also the "service engine soon" may turn on. As for the the fan speed problem, this may be a faulty blower resistor malf (typical) or climate control unit may be faulty. Hopefully this helps!!
May 05, 2010 | 2003 Chevrolet TrailBlazer
Z28 95 running hot
Is the fan running or do you have an electric fan? If fan isnt running or never comes on no matter what you do it will never run much cooler. If fan is good then you could flush the radiator a couple of times and that will help but if fan isnt working it wont last long
Aug 25, 2009 | 1995 Chevrolet Camaro
My 2005 Chevrolet Equinox ac isnt working the fan isnt blowing at all no ac or heat just a click when you turn it on.
have relays under hood checked, fuses too. Shouldn't take too much to find where the power is cut.
Aug 21, 2009 | 2005 Chevrolet Equinox
Duo therm ac not working
Make sure the fan blade turns freely when off. Not bound up anywhere. Check or replace the fan motor capacitor.
Jul 17, 2009 | Dometic Rooftop RV Air Conditioner
Air conditioning won't work. Thermostat says it's in 'recovery mode'
by the outside unit, you will have a shutoff. pull out the shutoff, and unscrew the cover. 2 cylinder like fuses are inside. It is likely that one or both are bad. When you turn on the AC and the outside fan does not turn on... this is likely this is the solution.
Apr 28, 2009 | Honeywell Electronic Programmable...
Outside unit come on for ac but inside won't come on for ac or heat
Turn Tsat to fan to see if inside unit will come on. If it does Tstat needs replaced. If not it is fan motor or fan relay. Possible cap. Do you here the fan relay come in. If it is a Good man unit it is time delay and you wont here it. Need to know your make of unit. Rusty
Apr 25, 2009 | Heating & Cooling
Heating & Cooling Logo
135 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
