Question about Back to Basics Smoothie Elite Work Top Blender
The blades on my smootie maker froze up and the black part under the canister chipped away. Is there a way to replace this part?
    Brigadier General:
  • 3,301 Answers
If this is the one made by Scholastic you can get them at 1-800-356-5360
Posted on May 27, 2011
Sj9668, blender is leaking from bottom. I think i could go to the store and ask for a gasket? What would be the name of the piece to go inbetween the blades and the bottom hardware? slightly lose.
Most blenders have similar issues and it occurs when you have a binding and the seal gets hot and the rubber wears away.
in this photo I replaced this part it was only 9.98 on Amazon.
But it was for a black and decker. Because you mentioned the blade felt loose I would try that.
search Amazon for blender parts, maybe use model number of your blender. But save picture to phone and then you have idea what you might need.
Oct 26, 2016 | Blenders
My blender is model# KSB5 & it works fine; the problem is the 'jar' is stuck onto the unit. I cannot remove the canister no matter how hard I try. Help?
This is a most unusual case, under the circumstances I would contact KitchenAid for a solution, have you tried turning canister clockwise and anticlockwise, should unlock in "anticlockwise position" if no luck contact the manufacture.
Mar 31, 2012 | KitchenAid KSB5 Professional Stainless...
Vitamin 3600 canister leak
I think it's the little washer in the blade assmbly since mine was worn to a sliver when it started doing what yours did. I replaced it with a similar washer and it worked for a week and then started spitting out metallic dust until it stopped working again. Could be the bearing seized. I would say yes a new blade assembly but I hadn't found one- since I have a 3600 which is very old-when my husband bought a used replacement container with a working blade assembly on ebay. $37 bucks, problem solved.
Mar 28, 2012 | Vitamix Blenders
My glass jar leaks from the bottom
remove the screw on blade holder, and make sure the gasket is in place ,, check the seal on it,, if its defective replace it,, check along the threads to make sure that the canister isn't cracked
Aug 28, 2011 | Black & Decker BL1900 5-Speed Blender
My vita-mix just stopped working, there is slight burned smell, I was blending walnut pieces with dates paste. Any suggestions?
If the burning smells like plastic then the walnut shells most likely put too much strain on the motor and burned it out. If the burning does not smell like plastic then you most likely have walnut shell grit jamming your motor.
This can be cleaned out by first ENSURING IT IS UNPLUGGED FROM THE WALL.
  • First remove the canister (if possible)
  • The remove the blade (if possible) check for a build up of grit between the blade and the shaft connecting it to the motor.
  • Check the channel the shaft passes through from the motor for large chunks of walnut shells or date paste.
  • Clean the canister thoroughly with warm water and leave it to soak overnight in a water/soap mixture.
If this has not resolved the issue then try to claim it under warranty or source replacement parts online.
Feb 28, 2011 | Vitamix Super 5000 Work Top Blender
I am unable to remove the blade, what can I do
the blade is a screw fit on the shaft of the blender,, if you only use one blade just rince the blade under the tap and dry it off before putting it away, the only way to un-screw the blade if its stuck is give it a sudden jolt on the side of the blade with a soft hammer in the same way as it turns,,this may shake it lose,,,not to hard though,,,
Nov 15, 2009 | Bamix Mono Hand Blender - Black...
KITCHENAIDE BLENDER
sounds like you engage gogs under you canister are slipping or wore out lift up your canister to check them. not sure if your particular model has set screws in them or not look and see might be it hope this helps
Sep 01, 2008 | KitchenAid KSB5 Professional Stainless...
Replacement parts
My blade assembly leaks just as you are describing. I found a website that offers replacement parts for Black and Decker appliances:
[Note: I have not ordered from this site yet so I can't say how reputable they are.]
They offer the glass jar, blade assembly, and other parts for the BL1900R. Judging from reviews, it may not be long until something else goes wrong.. I am gong to order the replacement part this one time. If anything else goes wrong though, forget it. Too bad. Black and Decker usually makes good stuff.
Jan 04, 2008 | Black & Decker BL1900R Blender
Back to Basics Smoothie Elite Work Top Blender Logo
43 people viewed this question
Top Back to Basics Blenders Experts
Mike
Are you a Back to Basics Blender Expert? Answer questions, earn points and help others
