Question about Ovens
Tappan tgfs26csb Gas Kitchen Range. Oven and Broil won't light. Replaced ignitor, rewired all connections, tapped on the saftey valve, the Temp sensor in the oven has continuity. HINT: about 8 seconds after you activate Bake or Broil, there is one clicking sound (just one click) behind the top panel cover. The ignitor gets hot. The top burners light fine.
  • 1 more comment
  • scott thompson May 28, 2011
    Is the thermostat in that panel at the top. So if i take off the back panel. What does it look like, how do i test it? Just continuity, or ohms? what should it draw
    Parts store won't let me reeturn it if it's not the fix.
    Is there a way I can test the existing clock assembly?
    Thanks!
  • scott thompson May 29, 2011
    OK... willing to take the chance, but is there any way to test it?
  • Ovens Master
  • 1,902 Answers
Hello & Welcome to FixYa
The click sound might be coming from the thermostat that is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on May 27, 2011
  • 1 more comment
  • Kevin White
    Kevin White May 28, 2011
    Sorry for replying late, just checked this model# does not have a thermostat.....the problem is with the clock assembly that is bad and needs replacement.
  • Kevin White
    Sears has that return thing, but I believe it is the control board.
  • Kevin White
    Kevin White May 29, 2011
    Unplug it and then test it with a voltmeter, let me know its reading
My kitchen aid YKERC607 oven, bake, broil does not work. oven top works however
If it is an electric range, it would be a control issue. If it is Gas, it could be ignitor or safety valve.
Mar 15, 2015 | Ovens Ovens
Inginator lightrs but oven does not heat
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Feb 27, 2014 | Frigidaire FEB27S5A Electric Single Oven
Tappan gas oven won't stay hot
bad flame sensor or check gas pressure
Aug 24, 2017 | Tappan Ovens
Oven appears to start, takes forever to preheat,
This is what I would do: I would unplug the range and connect my test cord to your range cord. I use an ammeter along with my test cord to read the amp draw of the bake ignitor. If it cannot get above 3.5 amps I know the ignitor is bad or weak. Since the oven is working that means there is a good circuit. In order for the safety bi-metal to open the amp draw must reach 3.5 amps or better. So to me I am thinking bad ignitor. To get to it I remove the door oven racks and bottom, I then remove the flame spreader and unplug the quick connect to the ignitor. I remove the burner and ignitor and replace the ignitor on a work bench. I am too old to be bending over and trying to do any parts replacement inside an oven. LOL. I have a training film which shows how the silicone carbide ignitor works HERE. Post a model number and I may have a service manual, do not forget to rate the answer.
Feb 26, 2010 | Kenmore 30172 / 30174 / 30179 Gas Single...
Tappan gas range model 72-3981-00/07. Upper oven does not ignite even though the igniter comes on and glows yellow.
The ignitor is weak and must be replaced. When you get the new ignitor turn off the gas supply and the power to replace the ignitor.
Remove the oven racks,remove the oven base pan,remove the flame spreader to access the ignitor.
Jan 10, 2010 | Tappan Ovens
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    I have a whirlpool gas stove, the bake or broil will not light.
    Check to see if the electric ignitors are connected at the ignition module, located under the top surface panel. It is possible that the wire(s) that go to the oven ignitors has burned off or become disconnected from the main spark module,
    It is also possible that the electrodes have failed and need to be replaced. These are the two (2) devices that produce the spark (and make the clicking sound) inside the oven compartment.
    If those are OK, then check the thermostat, as it could be faulty and preventing the oven from functioning.
    If you can smell gas when attempting to turn the oven (bake or broil) then the valves are good, if you don't smell any gas, the gas supply valves (one for each bake and broil tubes) need to be checked.
    You might also try lighting the oven manually with a long match or grill lighter to rule out faulty gas supply valves or a faulty thermostat, which if you can manually light the oven, it would prove that the ignitors must have failed.
    Here's the exploded line drawings for your stove along with the parts list, just click on each section to see the parts. You can order replacement parts from them as well.
    http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=gw395lepb02&pop=flush
    Hope you find this Very Helpful and best regards!
    Aug 28, 2009 | Ovens
    Sf195lehz5 free standing gas oven,
    Check both gas valve solonoids for 216 ohms [blue broiler wire to the orange common and red oven wire to orange common] both must be ok.
    Check oven temp sensor for 1080 ohms.
    If above are ok then the problem is either the spark module or the control board.
    Since the gas valve was not opening and there was not ignitor sound I replaced the spark module for about $90. You have a 50-50 chance of being right.
    My range is relitively new and I'm haveing an oven light problem which I traced to the control board so I may replaced this board to for about $200.
    HS
    Oct 05, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
    Ovens Logo
    63 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
