Question about Logitech 931150 Mouse
Changing the batteries
My battery indicator tells me the battery is critical, I on the other hand do not know how to change the battery, where is the battery compartment. I have misplaced the written instructions that came with the product.
I don't see where to open it.
    President:
  • 8,637 Answers
I'll give you info on how to change batteries in two different type mouse units. Not sure what type you have.
The normal way to change batteries on a mouse is to turn it over and open the little door on the bottom The compartment holds 2 AA batteries.
Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this.
Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
Hope this helps. Bud
Posted on Jan 19, 2009
Laptop will not charge
Step 1:
Windows 7 Laptop Battery not charging b> Careful management of battery charging and power consumption settings on your laptop computer is essential if you spend a lot of time away from home or the office. To stop your Microsoft Windows 7 laptop from running out of juice at a critical moment, you can change the battery and power settings for the device. Select the battery meter icon from the desktop toolbar to change the laptop's power plan.
Click the battery meter icon in the notification area on the right-hand side of the computer's desktop taskbar. This launches the battery and power plan options dialog box. Find the battery status display at the top of the dialog box. This shows the remaining charge in the laptop battery, and indicates if the battery is currently plugged into a power supply and charging. Click the check-box beside the power plan option that best matches your current activities. Select "High Performance" if the laptop is connected to an external power supply and the battery is charging. Choose "Balanced" if you don't need to save power and you want Windows 7 to optimize the laptop's power settings. Select "Power Saver" if you need to run the laptop on only battery power for as long as possible. Click anywhere on the desktop screen to exit the battery and power plan options dialog box.
Feb 06, 2013 | Samsung RF511 15.6 inch Laptop - Black...
HI, i have a rockland watch, MFG# RK4112. I am having problems changing the batteries since there are two one for the digital, one for the traditional hand. I don't have the instructions with me. I had...
Thanks for contacting FixYa.
Instructions generally dont tell you how to change batteries.
I would highly recommend you take to a watchmaker/ jeweler to have this done with the right equipment.
Jewel
Sep 20, 2010 | Watches
The second hand jumps forward every 5 seconds but the watch still keeps time OK.
You need to replace battery.
Q/A from swiss army website.
Q. How do I know when the battery needs changing?
A. In select models, the battery end-of-life indicator signals that the battery should be replaced within two or three days. When the battery is low, the second hand stands still for 2-4 seconds, and then speeds up to the correct time. This indication will last for approximately one week, and then the timepiece hands stand still.
Jul 02, 2010 | Swiss Army Wenger Victorinox Swiss Army...
HOW DO I KNOW THAT MY NOKIA E71 UNIT THE BATTERY IS FULL CHARGE?
I think the battery indicator is on right hand top corner. Please note the changes there while recharging.
Feb 17, 2010 | Nokia E71 Smartphone
Why does my mouse keep saying battery critical
you must use alkaline batteries not heavy duty to achieve the most current for any electronics products
Jun 09, 2009 | Computers & Internet
What is the button and set of 5 lights on a dell c610 battery for
The LEDs on the battery indicate the charge remaining. Press the button and you should get 5 LEDs with a full charge. The LEDs stay on in a steady state as long as you hold trhe button
The LEDs can also indicate an internal failure of the battery (Usually 1 3 and 5 will flash) if the LEDs flash, the battery is either critically low or failing. If charging it doesn't change the LED flashing them the battery will need to be replaced
Jan 27, 2009 | Dell Latitude D600 Notebook
How do I know if my phillips gogear is charging?
Hi in the top right hand corner of the screen is the battery charge indicator, if its flashhing its charging, the segment will change colour (darker) as the charge builds up till all the indicator has changed colour. This is then fully charged.
(If this was helpful please rate)
Dec 23, 2008 | Philips GoGear HDD6330 MP3 Player
Pc is telling me to plud it in when the battery is at 90%
Your power settings may be set up to inform you at 90% the battery is getting low.
Windows XP
Go to control panel, Performance and Maintaince(only in catigory view), Power Settings click Alarms tab and adjust the sliders to the desired.
Windows Vista
Go to control panel, click change battery settings, find the option selected click the link below it saying Change Plan Settings, click the link change advanced power settings, go to the battery section and adjust the low battery level and critical level.
Dec 07, 2008 | Acer Aspire 3680 Laptop
Compaq nx 9020 battery charging problem
Damaged battery or internal circuit problem it is hard to to say. Bring your laptop to a repair shop. They can check the battery and tell you what the problem is.
Dec 04, 2008 | HP Compaq nx9020 Notebook
I just changed batteries but it keeps telling me that batteries are critical
it may need time to charge the battery up ,so leave the pc on for a couple of hours to charge it
good luck
Terry
Mar 12, 2008 | Computers & Internet
Logitech 931150 Mouse Logo
1,733 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
