Question about Philips Televison & Video
I have Philips TV mode 32PF9956/12. It is no sound, when I go to Menu/Sound only Headphone volume is active. I do not know how to unactive Headphone volume and have sound back. Can you help me pls
  • maggahronn May 27, 2011
    Ok , thank you for answer, I dont have speakers or headphone. i have to talk to repair man after weekend. thanks again
    Thank you for answer and fast reply
  • Philips Master
  • 11,800 Answers
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
Posted on May 27, 2011
How adapt audio from 43 inch hd tv with no headphone jack to vivanco fms 2000 speakers
follow the chart troubleshooting and fix it. God bless you
No sound
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
Oct 14, 2013 | Televison & Video
Replace tv video card
FOLLOW this steps and fix it. God bless you
Perform some basic troubleshooting steps that apply to all TVs. These include checking the "Mute" button to see if it has been pressed, examining the L/R balance to ensure sound is coming from both speakers and checking the cable connections to auxiliary components such as the stereo system (which controls external speakers).
    • 2
Double-check the audio output jacks if you are using an S-video connection (a single round perforated jack) or component video connection (a trio of green, blue and red jacks). Those jacks only run the video signal to the RCA TV. In order to get an audio signal, you'll need to connect red and white RCA cables to their respective jacks on the TV.
    3 Check the back of the TV for a switch labeled "Int/Ext." It controls the sound input on some RCA TVs. If you don't have any separate speakers, the switch should be set to "Int."
      • 4
    Activate the sound set-up feature by pushing the "Menu" button and scrolling to the sound bar. (This option can usually be found only on RCA flat-screen and projection screen TVs.) The sound bar allows you to set the sound from mono to stereo, activate the surround sound features, adjust the sound for headphone use, set volume levels and activate preset sound levels for movies, sports, concerts, video games and other specific sorts of programming. If any of these settings don't match the configuration of your home theater system, it may cause problems with the sound. If you're confused about the options, select any settings that read "Normal" or "Automatic." That should set the RCA TV to factory standard audio settings.
      • 5
    Press the "Menu" button and scroll to the "Set-Up" option, then go to "Preferences." You'll see a bar on the menu marked "Maximum Volume." You can use that to limit how loud the TV can get, which can cause problems if you don't know it's been set. Move the arrow on the bar to reset the maximum volume, then hold down the "OK" button on the remote to hear what that volume sounds like. You can then listen to the TV as normal.
    Jul 20, 2013 | Sylvania Televison & Video
    Philips 32pf9986 has no sound after being moved from our house to parents house. Oddly the sound menu only has as a setting for headphone volume.
    Tries tv unplug,replug it back about an hour later,by letting the tv resetting itself back to the factory setting.Now,tv is on goto tv memu to PICTURE go down reset to reset the entire tv Tuner signal board.Then goto SOUND Setting,go down to resetting.This process are resetting everythings.The tv sould have sound now.
    Jan 03, 2011 | Philips 32PF9986 32 in. HDTV-Ready LCD...
    How do i set up the Technika TA-709 Wireless Headphones to my tv. Have lost the manual and am not getting any sound only static on all 3 channel selections.
    You should have all the necessary cables to do this with the package you bought, the wire which has a headphone style plug on each end should be plugged into the headphone jack on your tv.
    If they dont work then there are two further things that could be at fault:
    A: The headphone audio volume controls and the actual speaker volume controls on tvs are totally different and if the actual headphone volume is turned down then you will get an interference type noise thru your headphones as no sound is being detected by the reciever and therefore they go into kind of a standby mode. !!!!!!!!!!Try looking in your TV settings menu to make sure your headphone volume is turned up!!!!
    B: being an owner of a pair of these headphones I know how audio the cable can easily turn faulty from prolonged use us. The wires can easily break inside but look fine from the outside so get a new one. Headphone jack to Headphone jack cable.
    I use these along with my xbox 360 wireless earpiece (fits nicely under the headphones) and I think they're far superior to the Turtle beach headphones +++ My setup is 100% wireless which also makes it better than any turtle beach setup on the market.
    Jan 07, 2010 | Audio Players & Recorders
    Volume lock of philips vardan tv
    I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
    Sep 10, 2009 | Philips 20DV6942 20 in. TV/DVD Combo
    I have a sony PS3 and a Bose 321 gs series 2 sound system... how do i connect them to my Phillips 52pfl7403d/f7? I can get the PS3 connected just fine but I cannot figure out how to get the audio to play...
    u have to go to radioshackand get a 1/8 to dual rca y-adapter then u plug it in to ur tv , if its a philips like u say itis it has a audio out put for headphones on the left bottom corner on the back of the tv, just plug it in and then lower the volume on the bose system and on your tv remote press menu, tv menu will come on on the tv screen go to it, or press ok on the remote, on tv screen will say tv setting press ok on remote, go to sound, go to headphone volume, put it on 60 its the perfect setting on for your tv DO NOT go over 65 it will distotion the equilizer on the bose, well this work for me but if i find out an other way ill let you all know
    Mar 05, 2009 | Bose 3·2·1 II System
    Home theatre but TV without audio outlet
    I would suggest that you smash
    Philips HTS w/a hammer!
    I had better sound from TV alone! Only 2 speakers put out sound from TV. Recordings from DVR can not be heard very well w/all volumes at max. System sucks! You get what you pay for! $2500 LCD TV sounds worse w/Philips HTS than my son's $300 TV! ALL cables hooked up as instucted!!!!
    Dec 17, 2007 | Audio Players & Recorders
    Sound gone on tv big screen guideplusgemstar
    this you forget the MUTE buttom on the remove control?
    Dec 01, 2007 | RCA P52926 52" Rear Projection Television
    TV has no sound
    Just a thought...does the set have a headphone jack? When you plug in most headphone jacks it disables the internal speakers. If it does have a headphone jack trying plugging in some headphones to see if you have sound there. If you do, plug/unplug it a few times...worth a shot.
    Nov 18, 2007 | Philips 25PS40S 25" TV
    No sound
    Check first if theres a speaker cutoff in the menu of the set or the back of the set. Next see if theres a headphone jack and plug in a set of phones to see if you get sound. If you do a connection on the jack is bad. if you put youe ear right next to the speaker and hear a little background noise or a little sound then its probably in the volume control curcuit. if you hear nothing at all its the audio output IC or the speaker itself is defective. Good Luck
    May 17, 2006 | Philips 21PT6818 21 in. TV/DVD Combo
    Televison & Video Logo
    232 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
