Question about Sega Manx TT Superbike for Windows
Don't start manx tt game in windows 7 - Sega Manx TT Superbike for Windows
2 Suggested Answers
Magical Ink
  • 133 Answers
SOURCE: Is that possible to install Manx TT on Windows XP?
hey there welcome to fixya
im sure its possible put in the cd and see what happens please remember to rate this slution
regards
magical ink
Posted on Jun 26, 2010
Keep getting BlueScreen. Seems like it when it happens I am doing one the following activities: Playing an online computer game called Tibia, or watching an online video clip. I've noticed on several...
It's known as the "Blue Screen of Death" Because they usually require Formatting and starting over.
BUT, Not always. Write down the code that is usually along the top in white font. Google it and see if there is a cure. When I did I get several solutions like these. Be Careful you don't buy anything you don't want. Some sites are free. Note the first option below is from Micrisoft.
Good Luck.
http://answers.microsoft.com/en-us/windows/forum/windows_other-gaming/code-bc-124/ada35d3f-e0c5-4df7-a904-a990663fcad4
http://www.sevenforums.com/crashes-debugging/56347-bsod-bccode-124-a.html
http://www.techspot.com/vb/topic144923.html
Aug 14, 2011 | HP Pavilion dv5-1004nr Notebook
Purchased Doom II, Ultimate Doom and Final Doom, but switched to new computer with Windows 7. Now these programs don't work.
The only thing you can try is the "Compatibility Mode" option in windows 7. Right click the executable for your game and choose properties. Go to compatibility tab and choose a lower version of Operating System (e.g. Windows XP SP2) that supports your game. Save the changes you made by clicking on OK and try the game again. If this won't work, there is no other way but to use another computer with a compatible OS or downgrade your OS to a lower version that works.
You might also want to check your game manufacturer website for any update or patch that you can use to make the game compatible for Windows 7.
Hope this helps.
Jul 30, 2011 | Computers & Internet
Hey! so i recentley remembered the game Hype: the time quest in the back of my head and i brought back the cd from 1999 and tried to install it on my new windows 7 64 bit computer. it was a failed...
64-bit versions of Windows can't run the CD installer due to it being a 16-bit application. Trying to run the installer in Windows 7 x64 will cause the process to freeze in the background and require the task manager to close. One workaround is to install the game on a 32-bit copy of Windows and transfer the installed game to a 64-bit computer. A virtual machine will also work such as VirtualBox if you don't have another computer available. When installing the game select 'Full Installation'. The game installs to three locations:
  • Your specified install path. The default is C:\Ubi Soft\Hype - The Time Quest . This is where the game data is stored and the two executables for Direct3D and Glide mode.
  • C:\Windows\Ubisoft . This has an application called SetupUbi that shortcuts point to to play the game, various *.dlls, and Ubi.ini, the settings file for the game.
  • The registry key location is HKLM\Software\Ubi Soft\Hype - The Time Quest . Only a version string is stored here.
Copy the game data folder to your 64-bit windows and place the Ubi.ini folder into a C:\Windows\Ubisoft folder. The other files in the Ubisoft folder are not needed to play the game and SetupUbi has the same problem as the installer on the CD. The registry key is also not required to play the game.
The executables to play the game are MaiD3Dvr_bleu and MaiDFXvr_bleu for Direct3D and Glide mod respectively. Neither will work with default settings in Windows 7 x64. Set the compatibility mode for the executables to 'Windows 2000' to get the game to run without immediately failing. To change the game settings run 'UbiAssistant' as an administrator or edit the Ubi.ini file in the C:\Windows\Ubisoft folder. There is a patch available at Ubi.com labeled 'Voodoo 3 and Direct3D'. It is uncertain if this is required but is recommended to install. The patch is ~4.01 MB if the Ubi.com link goes down and a replacement download needs to be found.
The Direct3D mode will suffer serious graphical glitches that render the game unplayable by the end of the intro. There is no available fix for it. nGlide is a Glide wrapper available at Zeus Sooftware which does support Hype - The Time Quest. Download and install it and then download the patch for the game. The patch is in the compatibility list at the bottom of the nGlide download link and then search for the entry for Hype - The Time Quest. The patch says to turn videos off but this is not a required step but it is recommended. The game will still play with videos but besides the Ubisoft logo video at the start of the game there are only two others at the start and end of the game and playing the video may cause future issues. Turn it on when you start and finish the game but turn videos off at all other times.
Run MaiDFXvr_bleu.exe to use the glide wrapper, remember to set compatibility mode to Windows 2000, and Hype - The Time Quest should run on Windows 7 x64!
Jul 06, 2011 | Ubi Soft Entertainment Hype: The Time...
I can't play the game Heroes 4 with Windows 7. I loaded the game. When I started the game it said " Microsft C++ Runtime library Runtime Error Abnormal Program termination " . I can play...
Run the game in compatibility mode it will help surely.
Right Click the game then choose TroubleShoot Compatibilty then click Start Program
Don't forget to click the like button
Thank You friend
Jun 22, 2011 | 3DO Heroes of Might and Magic 4 for...
Will Heroes of the Pacific run on Windows 7? When I click on 'play', it reads the disk, but then nothing else happens. Any thoughts?
Looking around google this game is old and it only works on windows XP. When am looking at the list of compatible games for windows vista and 7 it don't even have the game listed.
Jun 08, 2011 | Codemasters Heroes of the Pacific
Is that possible to install Manx TT on Windows XP? Any Solution.>?
regards
magical ink
Jun 23, 2010 | Sega Manx TT Superbike for Windows
Getting the following message from windows live mail, any help appriciated Unable to send or receive messages for the email account. The connection to the server has failed. Server: 'mailin.manx.net'...
The most likely explanation is that your ISP (manx.net?) server is temporarily down. You can connect by webmail?
If it is manx net then you can try accessing your e-mails by logging in on here.
If you can access through web browser, but want to set up windows live mail click here.
Settings for manx.net - for Windows Mail but same will apply in Outlook.
Hope it helps.
Mar 21, 2010 | Microsoft Computers & Internet
Sega Manx TT Superbike for Windows Logo
231 people viewed this question
Top Sega Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
Reggie brown
Frank Zabroski
Frank Zabroski
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
