Question about Dell Dimension 2400 PC Desktop
Hello? i need help, none of the lights on the back of the computer (diagnostic lights) all of the are off, the light on the front of my computer is orange, i have a Dell 2400 and im not sure what the problem is
    Sergeant:
  • 231 Answers
Check here - http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/advtshoo.htm
and here - http://support.dell.com/support/edocs/systems/dim2400/en/F75560LRs.pdf
Sounds like it could be:
1) Power supply - still sending some power but wrong - hence the light on the front
2) Motherboard
3) RAM - take the RAM out and try again - see if it acts differently
4) Hard Drive - sometimes a faulty HD will keep it from booting - as before, unplug and try again.
Hope that helps.
Good Luck
Posted on May 27, 2011
Hello I have a 1994 maxima manual transmision,it have a check engine light on,when I start the car and beguin to drive it,runs perfect the a few minutes later the car gets very lazy almost want to turn...
Hello! I'll need the trouble code to fix your vehicle...Below is procedure with a code list...Guru...saailer
Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.
  • Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.Observe the red and green LED lights on the side of the computer. The red light flashes to indicate the "Tens" digit of the code and the green light flashes to indicate the "Ones" digit of the code. For example, if the red light flashes two times and the green light flashes seven times, this would indicate code 27.
    Turn the ignition key off for two minutes to exit diagnostics. The computer will automatically return to mode one for normal operation...
    Code 11 Crank sensor angle
    Code 12 Mass airflow sensor
    Code 13 Engine coolant temperature sensor
    Code 14 Vehicle speed sensor
    Code 21 No ignition reference
    Code 22 Fuel pump
    Code 31 Engine control unit
    Code 32 EGR sensor
    Code 33 Oxygen sensor
    Code 34 Knock sensor
    Code 35 EGR temperature sensor
    Code 43 Throttle position sensor
    Code 45 Injector leak
    Code 51 Injector circuit
    Code 54 Automatic transmission signal
    Code 55 No malfunction recorded
    I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
    May 04, 2012 | 1994 Nissan Maxima
    Hi there,pls help I have problem with this. Power not come at all..it was working fine till the we had a power outage then while the computer was on then the outage went back on my monitor just didnt work...
    Hello derick, Unfortunately power surges have been known to have some pretty nasty effects on your computer hardware. If you turn on your power (may have to toggle the power button behind your computer before pressing the button, worth trying in each position just in case) and your computer doesn't come on at all. This means that if none of your lights come on AND none of your fans come on, then your power supply may have blown out in the surge. If this is the case then you can't even begin to try and diagnose the rest of your PC to see if it's working. You need power to attempt diagnostics on your other components. Even if you replace the power supply, there is no guarantee that it was the only thing that was ruined by the surge. I hope this helps you out derick, and wish you better luck in the future :(
    May 15, 2011 | Computers & Internet
    HP Pavilion a767c Desktop blue power light want come on. Have unpluged the power cable and held the power button in for a short peroid of time with not results. Can you help?
    Hello Chris, If you turn on your power (may have to toggle the power button behind your computer before pressing the button, worth trying in each position just in case and make sure the power cable has been plugged back in) and your computer doesn't come on at all. If none of your lights come on AND none of your fans come on, then your power supply may have gone bad. If this is the case then you can't even begin to try and diagnose the rest of your PC to see if it's working. You need power to attempt diagnostics on your other components. Another thing to check is to make sure the fuse on that outlet has not blown, if other things are plugged into that exact same outlet, are they receiving power? Also if you have the same standard power cable that you use from your monitor to the power source, maybe try switching it out and using it on your PC to see if it makes a difference. Hopefully this helps you with your problem Chris, have a great day!
    May 07, 2011 | HP Pavilion a767c (82916052406) PC Desktop
    IBM xseries eserver x236 Bios problem: a yellow light( !) like this is on and IBM server can not start
    Try this:
    Light path diagnostics
    Many errors are first indicated by the illumination of the system-error light in the operator information panel on the front of the server. One or more lights inside the server might also be lit that can direct you to the source of the error. The system information LED lights to alert you that there might be important information recorded in the system-error log. 2. Removing the left-side cover and look at the light panel. These LEDs indicate the type of error that has occurred.3. Once you know the general type of error and the general location of the component involved, the next step is to check the system service label on the outside of the server. This label gives an overview of internal components that correspond to many of the LEDs on the light path diagnostics panel and can help to view lit LEDs inside the server. Note: Some of the LEDs on the light path diagnostics panel will not have a corresponding LED lit on the system board.
    Good Luck
    C2Solutions
    Dec 31, 2010 | IBM eServer xSeries 236
    Front brakes went out on my 1999 ford super duty.. the dash brake light and anti light came on.. I replaced rotors and pads bearings etc... brakes work great lights in the dash still on? I have a anti...
    Hello there:
    also if you take you car to autozone and they can hook up the diagnostic handheld computer and clear the fault from the onboard computer thus this will clear the lights ok ?
    best regards michael
    Sep 25, 2009 | 1999 Ford F250 Regular Cab
    5100 problem
    Hi
    To help you troubleshoot a problem, your computer has four diagnostic lights labeled "1," "2," "3," and "4" on the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights display solid green. If the computer malfunctions, the color and sequence of the lights identify the problem.
    Reply with the Power Button light and the Diagnostic lights color and sequence for further assistance.
    Advanced Troubleshooting and Owner's Manual
    Mike
    May 30, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
    Dell Dimension 5100 Won't start up
    Hi
    First disconnecting the power cord and re-seat all connections (Keyboard, Mouse espercially). Connect up the power cord and try powering the PC.
    To help you troubleshoot a problem, Dell Dimension 5100 has four diagnostic lights labeled "1," "2," "3," and "4" on the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights display solid green. If the computer malfunctions, the color and sequence of the lights identify the problem.
    If the computer failed to start up check the diagnostic lights color and sequence and Check the link below for more info (Assuming you have another system that can access internet)
    http://support.dell.com/support/edocs/systems/dim5100/en/sm/tshoot1.htm#wp1120147
    Alternatively, contact Dell Support with the diagnostic lights color and sequence to raise a service call if the system if under warranty.
    Mike
    Mar 31, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
    Dell Dimension 2400 PC Desktop Logo
    81 people viewed this question
    Alun Cox
