Question about Broan-NuTone Allure III QS330SS Kitchen Hood
Changing fuse on Nutone Allure Ws2
Lights and fan just stopped working one morning. I have light on fan come on but fan does not work. According to manual it sounds like to change this 3/4 inch fuse. But where is this fuse??
  • 1 more comment
  • Anonymous Dec 13, 2008
    I have a CDA kitchen chimney hood that stopped working suddenly after causing a sudden spark on starting it that led to circuit break and the hood is not orking any more. I manege to put power back to the kitchen but the hood is still not working both fan and light. I couldnt locate the fuse of the device to check it. could you please help me. my email is mypcjob@yahoo.co.uk .. thank you in advance for any help and support.
  • Greg
    Greg May 11, 2010
    It's the 'remove lightwire harness and air cute' part that seems a tad baffling. Near as I can tell this means disassembling 95% of the entire range hood!?
  • Anonymous Mar 27, 2014
    The lights of my NuTone WS2 went off but the fan still works. Can you tell me what is the problem?
Hi Mertl, I sure hope you found the solution since, but I am posting the answer for other people like me (and you) who need to find it !
The service manual says:
To replace the fuse:
1. Disconnect power at service entrance.
2. Remove filters, bottom panel, light wire harness, and air chute.
The fuse is actually right behind the fan controls, so to access it you need to disassemble everything that's in the way.
BTW, for anyone wondering if it's the fuse that's faulty, here's a clue:
If the fuse has opened (blown), the green fan-level indicators
will operate properly when the fan buttons/switches are pressed
- but the fan and lights will not turn on.
The fuse is a 5 x 20 mm, 10 Amp, Fast-Acting, 125V (min.).
Good luck all !
Posted on Oct 05, 2008
Last night both fan and lights worked on my hood fan and lights. This morning neither are working. Checked house fuse box - everything ok there. what could be the problem does the allure have a fuse inside...
could be simething as simple as a disconnected wire, prior to calling for help, check these items if you feel okay with that , first turn off the circuit breaker and where the house wires come into the unit,, remove the wire nuts and check for burned areas,, if thats ok, reattach them and move to the switch or switches, unhook the wires, ( make note where each one goes ) and check them with a meter , this is probably where your problem will be,
Jul 10, 2011 | Broan-NuTone Allure QS130SS Kitchen Hood
Lights won't turn off - everything else works fine
I have a NuTone Allure WS2 range hood. The fan works fine, so does the control board seem ok, but the lights work only intermittently. NuTone tech support said to replace the control board, which I suspect is its kneejerk response. The board costs almost $200--and for two lights???
My problem is similar to the one whose lights work, fan doesn't, but I have a feeling my problem is different.I hope simpler.
Thanks in advance for help (light) on the problem anyone can offer.
Larry R
Apr 23, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
My broan allure turns on by itself
Isn't it suppose to turn on automatically? The broan has a heat sensor!
Jan 08, 2009 | Broan-NuTone Broan Range Hoods Allure II...
Nutone Allure fan has disco lights.
Its definetly the control board!!!
Part #R111632
Price $110.00
Definetly not cheap...
Dec 22, 2008 | Broan-NuTone Allure III QS330SS Kitchen...
No power
you have to take off the bottom part of the smoke hood and the lights and then you can look inside..the fuse is on the back of the push button panel...which is the control panel it is really small and hard to get out...you need some kind of wire that will hold its shape...to snake behing it aND PULL IT OUT...
Dec 16, 2008 | Broan-NuTone Allure® I WS136BC Kitchen...
ALLURE II STOPED WORKING ??
If nothing is working Lights/Motor Nothing, Its the small transformer. Theres 2 transformers. you will see blue and yellow wires coming out of it. I do service calls for broan & Nutone
We have the part: www.inventex.com
Jean-Marc
Mar 20, 2008 | Broan-NuTone Allure II QS230SS Kitchen...
Broan Allure QS2 Range Hood
Had same problem & fuse fixed it.
Before buying a new control board (approx $160), check the 3 amp fuse located on the inside of the vent on the control board. You have to take the light/bottom housing & black plastic air chute off to see control board/fuse.
Feb 21, 2008 | Broan-NuTone Allure II QS230SS Kitchen...
Random fan speeds and light levels???
I have the same issue. Have to reset the breaker to make it stop. Bet it is a bad controller (design fault).
Nov 13, 2007 | Broan-NuTone Allure III QS330SS Kitchen...
Broan-NuTone Allure III QS330SS Kitchen Hood Logo
1,406 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
