Question about Cub Cadet Op's Manual Model Lt1042 Lt1045 Lt1046 Lt1050
Engine will not crank on lt 1046. New battery. Seat switch is working. Seems like the clutch safety switch. Any ideas. thanks. Bill
    Brigadier General:
  • 3,301 Answers
Both the seat and clutch safety switches must be working for the unit to start, ( or at least for checking purposes be Jumpered) but for your unit check this link for a breakdown of your machine (Lt1045 anyway ) http://www.partstree.com/parts/?lc=cub_cadet&mn=LT1045+Tractor+%282007+%26+before%29
Posted on May 27, 2011
  • Mark Trotnic Jun 08, 2011
    Everybody don't over look the common sence answer to some startting trouble with the starters on your engines. My cub cadet won't start, the relay on starter would only click. Thought the motor was locked up and had big trouble. Looked into it more, when I took the cover off motor there was a pack rat that built a nest on top of the starter and when the motor turned over it wedged the nest between the flywheel and the starter gear. the motor would not turn over until the material was removed. replaced the cover and starts fine. It had only been a week before that I had just used the thing, that quick it made the nest and it had babies in alive too. This can happen on any kind of unit not just the cub cadet's. My father bought his first new one in the late 60's and in 1970 traded it in for a newer one and we still use it today along with three others that we own. Talk later From the Kansaspicker
Why won't it start?
When I turn the key nothing happens.
There are several elements that go into cranking (turning over) the engine.
  1. Battery
  2. Fuse
  3. Key Switch (and wiring)
  4. Starter Solenoid and wires
  5. Starter motor
To begin with check the fuse. It's a 20amp car style fuse located under the hood near the battery.
If the fuse does not fix the problem let's move on to the battery. The quickest way to make your initial check of the entire starting system and particularly the battery is to get a jump. Yep, get some jumper cables and jump the mower off your car. Turn the key and try to start it in the normal fashion(normal meaning YOU in the seat, PTO off, BRAKE pressed all the way down). If it starts cool! It is likely a bad battery.
  • Charge the battery for a few hours, on a charger.
  • Then perform a voltage measurement of the battery.
  • Switch a volt meter to DC Volts and clip it to the battery. It should read between 12-13 volts. If not the battery is suspect. If it is 12-13 volts see if it will crank, but continue to watch the volts. If they drop below 10ish volts, the battery may have a bad cell.
Now let's check the starting system while bypassing all the safety switches and wiring. How? You can perform this test simply by jumping the starter solenoid. Hold a wrench or fat screwdriver across the two large posts of the starter solenoid. This bypasses the key switch and all safety devices and directly drives the starter. Your starter will crank if the battery and starter are good, the wires and connections are good, and the engine is not locked up. Don't crank it for more than a couple seconds. You just want to verify the battery and the starter are both in good shape. (The engine will crank but not start during this test as long as the key is off, or if the safety switches or wiring are damaged, or if the safety switches are in the no start/run positions.)
If the starter cranks try one more test. Run a small jumper wire from the positive post of the battery to the little terminal on the solenoid. You may have to take the small wire off the positive terminal of the starter solenoid, in order to do this. When you apply this current from the battery to the positive terminal it should make the solenoid activate and the starter crank. This test bypasses the key switch and shows you the starter system is working. You could do this test first; if it works you do not need to do the basic jump test.
If these tests cause the engine to crank, but it will not crank with the key, then you know you have a problem somewhere in your starter wiring, safety switch system, fuse, or in your Key Switch. Of course you did check the battery terminals for tight, clean connections, right?
Most modern riding mowers have the following 4 safety switches:
  • Seat switch
  • PTO switch
  • Reverse switch (RIS) and Reverse Relay (RIO)
  • Brake/Clutch switch
If you need detailed instruction for testing your wiring and safety system, I will need your complete machine info.
  • Make
  • Model
  • Year
  • Engine Model
  • Transmission Model
  • Deck Size.
On a John Deere (100 series) the starting current flows through the following items in this order:
  1. Battery to Fuse then to the Key Switch.
  2. With key switch in the start position, the current flows from the Key Switch to PTO.
  3. With PTO off, current flows from the PTO to Brake/Clutch Switch
  4. With Brake/Clutch Pedal all the way down, the current flows through the switch to the starter solenoid.
  5. If the Starter Solenoid is in good shape, the solenoid connects the battery to the Starter and the engine cranks. Cranking does not mean running; it just means the engine turns over. Running is dependent on many other systems.
Those components are all part of the cranking/starting system. They can prevent the Starter Motor from cranking when you turn the Key Switch. You can trace the voltage with a multi-meter. Connect the black lead to ground and look for 12 volts at each successive switch. If the voltage disappears at one particular step, there is your suspect.
Electrical elements that are NOT part of the starting system:
The RIO is the Reverse Implement Option. It is a switch that latches and stays latched under certain conditions. It is activated by the RIS. The RIS is the Reverse Implement Switch. It activates the RIO.These switches are called slightly different names by different manufacturer, but they all do the same thing. These two separate components work to allow the blades to cut while you are backing up (without killing the engine). They have nothing to do with the starting system.
The Seat and the RIO (the reverse latch not the button) switches are tied into the engine kill system. They provide a ground path for grounding the Coil. This same system controls the fuel shut off valve beneath the carburetor. The Seat and RIO can keep the engine from running but they will not prevent the Starter Motor from cranking. Therefore, if you turn the key and nothing happens, the problem has nothing to do with the Seat and Reverse switches.
Note: With the Key in the RUN position, power flows from the Key Switch to the Hour Meter, then to the RIO latch relay (not the RIS button), then to the fuel shut off solenoid. If you do not hear the Fuel Shut off Solenoid clicking on and off when you turn the Key Switch from off to run, there may be a problem in this circuit; including a possible problem in the Hour Meter. Of course none of this affects the cranking circuit. Your engine will still crank, it just won't start and run.
Apr 21, 2015 | Garden
The machine will not start. Absolutely nothing when I engage the key. Battery good
  1. Battery
  2. Fuse
  4. Starter Solenoid
  5. Starter motor
Let's start with the battery. The quickest way to make your initial check of the entire starting system and particularly the battery is to get a jump. Yep, get some jumper cables and jump the mower off your car. Turn the key and try to start it in the normal fashion. If it starts cool! It is likely a bad battery.
Now let's check the starting system while bypassing all the safety switches and wiring. How? You can perform this test simply by jumping the starter. Hold a wrench or fat screwdriver across the two large posts of the starter solenoid. This bypasses the key switch and all safety devices and directly drives the starter. Your starter will crank if the battery and starter are good and the engine is not locked up. Don't crank it for more that a couple seconds. You just want to verify the battery and the starter are both in good shape. (The engine will crank but not start during this test if the key is off, or if the safety switches and wiring are damaged, or in the no start/run positions.)
If the starter cranks try one more test. Run a small jumper wire from the positive post of the battery to the little terminal on the solenoid. You may have to take the small wire off the terminal, on the starter solenoid, in order to do this. When you apply this current from the battery to the terminal it should make the solenoid activate and the starter crank. This test bypasses the key switch and shows you the starter system is working. You could do this test first, if it works you do not need to do the first more basic test.
If these tests cause the engine to crank, but it will not crank with the key, then you know that you have a problem somewhere in your starter wiring and safety switch system.
Most modern riding mowers have the following safety switches:
  • Seat switch
  • PTO switch
  • Make
  • Model
  • Year
  • Engine Model
  • Deck Size.
  2. With key switch in the start position, Key Switch to PTO.
  3. With PTO off, PTO to Brake/Clutch
  4. With Brake/Clutch Pedal all the way down, the current flows to the starter solenoid.
This list of components are all part of the cranking/starting system. They can prevent the Starter Motor from cranking when you turn the Key Switch.
The RIO is the Reverse Implement Option. It is a switch that latches and stays latched under certain conditions. It is activated by the RIS. The RIS is the Reverse Implement Switch. It activates the RIO. These two separate components work to allow the blades to spin while going backwards (without killing the engine)
The Seat and the RIO (the reverse latch not the button) are tied into the engine kill system by grounding the Coil. This same system controls the fuel shut off value beneath the carburetor. The Seat and RIO can keep the engine from running but they will not prevent the Starter Motor from cranking. Therefore, it you turn the key and nothing happens, it has nothing to do with the Seat and Reverse switches.
Note: In the run position, from the Key Switch, power flows to the Hour Meter, then to the RIO latch relay (not the RIS button), then to the fuel shut off solenoid. If you do not hear the Fuel Shut off Solenoid clicking on and off when you turn the Key Switch from off to run, there may be a problem in this circuit; including a possible problem in the Hour Meter. Of course none of this affects the cranking circuit. Your engine will still crank, it just won't run.
Apr 10, 2015 | Garden
Where is the safety switch for clutch on yard machine 16.5
under the tractor on the clutch peddle side the arm there is a ether a gray or black switch there is also a switch under the seat that goes bad that will also cause a no start state its for if you fall off the tractor it will shut down usually it is a good idea to replace these of it is a few years old. if you are talking about the clutch for the mower deck then it will be behind the battery at the back of the dash board. there is a shaft with a tang that activates the switch if you have a electric clutch then check your seat switch and brake switch as well there is a switch usually located by the transmission this is the neutral safety switch. all together they work in a series another words you have to be in neutral with the brake applied and the mower deck in the off position before the the tractor will crank and run. hope this helps.
Sep 02, 2014 | Yard Machines 13AN775S000 500cc 16.5 HP...
I have a john deere LT 150 that will not start. When you turn the key nothing happens. I've checked the seat switch , the mower engage switch and a new brake/clutch switch. Battery is good. You ca
you have a safty switch problem you have 4 to 6 switchs the easest way to test them ,startin with the seat get a ohms metter they are open or noramly closed
Oct 23, 2012 | John Deere Garden
Garden Trctor Model 917.273023 . Key switch broke, wore out. replaced it. started up great, tried to mow and the electric clutch would not engage, checked out wireing restarted engine. and engaged...
Bill, not sure, but, the engine will not crank with the clutch engaged, I don't know what happened, but sounds like the clutch switch went out and took the mower with it. Take the wires apart between the ignition and the clutch and hot wire them to see if the clutch jumps. If it is working, then make sure it is off, or disconnected and try to start it, then take it from there, if it starts, you know it is the switch. If it doesn't start, then you can go look at other safety switches. make sure it is neutral, mower off, driver in seat, clutch in, etc, Hope this helps.
Jun 29, 2011 | Craftsman Garden
Have a Craftsman Model # 917.276813. For reason when you crank up the engine and and go to either let the clutch out or move the lever in engage the blades the engine will die. Any ideas?
Check the wire connector under the seat to the seat safety switch, it may be partially or completely unplugged. If it is firmly connected, temporarily disconnect it and jump across the two terminals in the connector and see if everything works properly. If all works, replace the switch
Oct 11, 2009 | Garden
My 95 f3 will crank but wont start. everything was working fine replace a headlight now it wont start with the starter. battery is charged and i can push start it but the engine just cranks and cranks and...
Sounds like a wire or plug got disconnected while changing the headlight out, the harness that connects to the clutch safety switch, the one that lets the ignition fire when cranking only when the clutch is pulled in. A safety feature so you don't dump the bike if you crank it while in gear.
Sep 12, 2009 | 1997 Honda CBR 600 F(3)V
Older Craftsman 43" 17 HP Briggs
Check to make sure battery is above 12.3 volts, secondly bypass the solenoid to the starter by using jumper cables and see if the starter works, if so, you sureley have a safety switch problem, I beleive you have five on this model,
good luck
Jul 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Riding mower dies when releasing brake
the seat switch is the problem. the switch itself could be bad, but usually theproblem is that the connector is just not plugged in all the way [by the way, trying to bypass the switch by inserting the wire doesn't work because there is a "switch" inside the connector to prevent you from doing just what you did]
Mar 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cub Cadet Op's Manual Model Lt1042 Lt1045 Lt1046 Lt1050 Logo
508 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
