Question about Coby LEDTV2226 22 in. TV
I got a Coby LEDTV2226 tv recently on eBay and performance is o.k. except for green over-emphasis. User menu does not offer solution. The t.v. is no longer under warranty so this isn't a problem. Would like to access service menu on this tv to correct white balance. Coby tech support no help (take to repair shop). Procedure on my other Coby tv (TFTV1022): push INPUT then 2,5,8,0, doesn't work on this one. I consider myself technically adept and am confident I can effect a satisfactory adjustment. It would be a waste to have to bring this to repair shop just to perform a minor adjustment. Any help would be greatly appreciated. Thanks.
4 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: Coby 32" Model TFTV3225 can
Just white glowing screen/ It can be bad T-CON (blown fuse) board or it is not getting the 5 or 12vdc from the main board. Check the caps in the power supply module also.
Please read my guides first:
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Jun 26, 2011
tvtek
  • 1284 Answers
SOURCE: my coby tftv4028 has major
In most cases there are NO scanning adjustments. More likely check the "picture size" or "format" button on your TV remote control or on your cable or satellite remote control. Good Luck : )
Posted on Jul 26, 2011
motor1258
  • 6674 Answers
SOURCE: I installed a coby tv
If you've tried all positions with antennae, booster switch is on, and are sure you have all settings on TV correct, try running an alternate cable directly from antennae head to back of current plate where your co-ax from antennae is attached. That will tell you if you have a bad cable or connection from antennae to plate inside. Just get a piece long enough to go through door or window to current spot where connected. If that doesn't cure it, then it's a head or booster switch problem. You can even by-pass the booster and go direct to TV to see if any better.
Posted on Oct 16, 2011
How to softwhere reset GTX75 airtyme torrid mobile
Try this: The web interface offers a simple way to reset to factory defaults. It is necessary to login to the phone`s admin account to perform a full reset. Go to the "Advanced" screen. Click on "Factory Reset" then "Submit" and "Reboot phone". Early manufactured phones can be reset to factory defaults, including admin and user passwords, using the undocumented ATE menu feature. 1) Invoke the ATE menu and wait for the "Func No:" prompt. 2) Enter 37 and press the green key. Wait for "Success" and press red key. 3) Enter 38 and press the green key. Wait for "Success" and press red key. 4) Enter 41 (=Clear User Data) and press the green key. Wait for "Success" and press red key. 5) Turn the phone off and back on - it should be totally cleared and the default passwords will be set. WARNING: Performing the ATE reset will also clear the phonebook entries and all user-specific settings.
Apr 16, 2016 | Cell Phones
How do i reset factory settings on coby mid 8042
Steps on how to do the restart. -You have to turn off the system. -Then press and hold the power button until you will see a message that will popup in a window that saying "Device Options"Appears on the screen. -Then select the power off again then you can see it again.You can be able to check that it first. -Then just select okay And while holding down the -Back -Button -Then Press and hold the power button. -Until you see the Coby`s Logo -Then wait until it change to Android Logo. - Then press the Back button.And Then the system menu will appear in the screen. -And then choose the wipe data/factory reset. >Home >Menu Buttons >Press the back,the button once you select the wipe data/factory reset then just click option. Then the confirmation that you will see in the screen Is a "yes" "Option". Then Choose "yes"-delete all user data,option by using the "Home"and "Menu"buttons. Then it will perform the factory data reset. -wait until it done. -Then once your done the main system menu has to appear in the screen. -And then reboot the system. -Then you have to press the back button to reboot the system. -The system will reboot the initial factory data setting. -All the user data will be lost. -Then Give the reboot,at least for 5 minutes. -Then Do not assume the unit has frozen.
Sep 07, 2014 | Coby kyros Tablets & eReaders
Hello how do i set the convergence manualy on a pioneer elite pro-710hd projection tv i dont have the remote and dont know how to bring the menue up on the tv
You MUST have the remote to perform service operations on the Elites. Look on ebay or do a google search for Pioneer 710 remote.
There is no way to manually do convergence without a remote, and no way to call up the convergence menu.
Feb 05, 2014 | Pioneer PRO-710HD 64" Rear Projection...
No red led on front panel & wont power on at all
Check the wall outlet to see if you have power going to the TV. Next, the case will need to be opened; look inside for a fuse near the power wire. Beyond that you will need someone with TV experience to help you.
Jan 12, 2013 | Coby LEDTV2226 22 in. TV
Coby kyros mid 7022 is stuck on lock scteen, how do I get around this? Also goes into hibernate for seemingly no reason. Very new android user, no clue what I'm doing
Here is the instruction on how to do the factory data reset when a customer locks the system and lost his security password/pattern. This instruction works for MID7016 and MID7022. An end user must follow each step precisely. Otherwise, he/she will not access to the system menu mode.
  • Connect the AC power adapter.
  • Turn on the system.
  • Press and hold the power button until the popup window of "Device options" appears on the screen.
  • Select the "Power off" option from the popup window. You will see another popup window of "Power off".
  • Select the "OK" option. The unit will turn off.
  • While holding down the "BACK" button, press and hold the "POWER" button until Coby logo appears on the screen.
  • Release both buttons once you see Coby logo on the screen and wait for a while. The Coby logo screen will change to Android logo.
  • Wait about 15 seconds after you see Android logo. (Do not press any button while waiting. If you do, you will not be able to access to the system menu.)
  • Press the "BACK" button once. The system menu screen will appear on the screen.
  • Choose the "wipe data/factory reset" by using the "HOME" and "MENU" buttons. (The "MENU" button will allow you to browse down through the option list, while the "HOME" button will allow you to browse up through the list.)
  • Press the "BACK" button once you select the "wipe data/factory reset" option. The confirmation message will appear on the screen with YES or NO option.
  • Choose the "Yes - delete all user data" option by using the "HOME" and "MENU" buttons.
  • Press the "BACK" button once the "Yes - delete all user data" option is selected. It will perform the factory data reset. Wait until it is done. Once it is done, the main system menu will appear on the screen again, and the "reboot system now" option will be selected as a default. If not, you will need to select the "reboot system now" option from the list.
  • Press the "BACK" button to reboot the system. The system will reboot with the initial factory data setting. All user data will be lost.
Give the reboot at least 5 minutes. Do not assume the unit has frozen
Sep 02, 2011 | Coby Kyros Tablet
19" Coby TV not listed
Hi, your only option is to do a code search to see if another code works for your tv. Instructions below.
If you were unable to find the code for your brand of TV or component, you can try a code search. This process may take up to 30 minutes.
1. Turn on the TV or component. Insert a tape or disk if applicable.
2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1-1
5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
6. Point the remote at the TV or component and press CHAN+. Repeatedly press CHAN+ until the TV or component turns off. NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV or component turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
Feb 12, 2011 | Directv RC32RFK Remote Control
Poor picture quality
Hello Paul. I have this same monitor, but rebranded, Access the service menu with the remote control:
With user’s RC
1. Power TV On
2. Press Menu button and call up User OSD Menu
3. Select Sound-> Balance
4. When Balance value is “0”,Enter 0->5->3 ->2 in sequence.
Note: If necessary, re-do number keys.
5. Factory OSD appears.
6. Press the standby button then AC turn off and restart the TV, which can exit factory
OSD menu.
Now you will be able to change the values for Red Green and Blue channels. I also hated this TV, but after adjusting the colors it's looking great! Hope you could fix it too! :)
Nov 16, 2009 | Televison & Video
MIT WD-62525 DLP TV blinking green light on front won't stop
Hi!
It means your TV needs to reset. Although you have reset it previously, now again reset the TV as per procedure given below:
Please press the SYSTEM RESET button on the front panel with a pointed item such as the point of a ball point pen or end tip of a paperclip.
The TV will turn off and the green LED will flash quickly for about one minute. After the green LED stops flashing, turn on the TV again. The changes you made while the TV was most recently on, before you used the SYSTEM RESET button, may be lost; the changes you made previously, however, are not lost. Only those changes since the last power on may be lost when the system reset button is pressed. All other settings are retained.
TV Reset Menu
Read on-screen warnings before proceeding, as some user data or settings may be erased.
1. Press TV MENU and then 1, 2, 3 to see the RESET SERVICE MENU to reset the TV.
2. Select Reset System Defaults (CAUTION: All settings, except V-Chip, will be reset to the original factory defaults.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 20, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blue, green, and red colors all off
I would suggest having a repair person come out to your place to fix this problem. I believe the convergence IC are going or have gone bad. I would estimate a $300 - $400 dollar repair bill.
Sep 22, 2007 | RCA P46921 46" Rear Projection Television
Coby LEDTV2226 22 in. TV Logo
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
