Question about Samsung SGH-A707 Cellular Phone
Dropped Samsung A737 Slider
Hi there. I have had my phone for only 2 months. I waited too long to get insurance through at&t & low & behold I drop my phone. the phone works and the slider works BUT before i dropped it, it auto locked the keypad when slid down & auto UNlocked when slid up. Now it doesn't do it. and the camera is still functional on it, but it doesn't recognize that the slider is up to take the photo. It's like that sensor was knocked loose.
I need to know if there is a way I can take this apart & fix it myself w/o paying more than what the phone is worth for repair fees.
Would this be an easy self fix? or will i need to shell out the cash for repair service?
(my phone wasn't listed so i used the closest model number, sorry for confusion)
  • 4 Answers
If you are not good at repairing small electronics (taking apart and putting back together) then get a pro to do it. I found out the hard way that trying to pry off the cover around the display (with the tools that came with my replacement LCD for my samsung a737 ) is the wrong way.
Under the battery are two very small screws that come out. Remove these first, they should be very short and have a very wide and flat head.
Then with the phone closed pry up the bottom the of the top slider and then push the slider top down (some what hard to pry and slide). You only need to move it about 1mm then you should be able to lift the whole top off. This is the hardest part of the job.
Then disconnect the the ribbon cable by flipping up the little gard along the top of the ribbon at the connector. This guard rotates to a 90degree angle straight up. Be carefull to not rip appart the flip connector. then slide the ribbon out.
Then flip the top over and remove the now exposed screws on the top along the edges.
and now you should be able to figure everything else. Three more ribbon connectors to the display to finally remove.
To put back together again just do the same in reverse.
I charge $30 plus shipping to do this for you.
Looking towards the future with you,
Rob a_t pcmedic d_t net
Posted on Feb 21, 2009
    Master:
  • 377 Answers
JUST TO AVOID AFOR SUCH A BIG PROBLEM, AND RESULT A BIG EXPENSE.. I ADVISED THAT U SHOULD SERVICE THE PHONE INTO THE QUALIFIED SERVCE TECH..
Posted on Aug 16, 2008
Need manual for Samsung Slider Phone Model #S6H-A737
You can download the complete instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
May 23, 2010 | Samsung SGH-a737 Cellular Phone
How to remove samsung a737 slider?
After spending several hours and a trip to Lowe's for the right screw driver n needed to take the phone apart. I still couldn't figure out how to remove the lcd screen. Therefore, I decided to buy the lcd screen online and I will take my phone to a professional for repair.
Aug 30, 2009 | Samsung SGH-a737 Cellular Phone
Dropped phone into water
You can try to disassemble the front cover and clean the joystick.
The ultimate solution is to replace the joystick yourself or at a repair store, since samsung probably wont accept the phone for warranty effects
Good luck
Jun 21, 2009 | Samsung SGH-a737 Cellular Phone
Problem with samsung sgh-a737 cell phone
try a battery pull, then be sure to leave it out for a full minute! emp or emergench download procedure is when a slider phone isnt recognizing the keypads so it trys to redownload the driver, has the phone suffered a drop recently? please let me know some more info! thanks.
How to remove the slider portion of a samsung model sgh-A737
I have a U600 phone, but maybe this is a similar construction. I was able to detach the slider by removing 6 tiny screws hidden behind the sticker which you can see when you take out the battery.
Jun 10, 2009 | Samsung SGH-a737 Cellular Phone
My Samsung sgh-a737 won't turn on. I have tried everything. Taking out the battery. I mena everything. I have dropped it a few times.
I would suggest to replace the battery first. That is usually what the problem is. If you have done this and you still have same problem then it is very likely you have a loose capacitor or resistor that may need to be re-soldered
Apr 15, 2009 | Samsung SGH-a737 Cellular Phone
Changing the LCD screen on a Samsung A-737
I had to take my sons phone apart when it got wet. I believe the screen was held in with some type of double sided tape. But you have to take the phone completely apart to get to it. I took it apart about 6-8 months ago and it is still working.
Mar 10, 2009 | Samsung SGH-a737 Cellular Phone
Samsung delve screen
your know the lock button up top make shure you hols it down long enough.....you could have your brightness setting messed up? have you dropped it? if so dont tell the people ..thats dum...get insurance on the phone right away and if it is broke they will replace it for no cost...but remember the insurance takes a couple of days to become active dont get it then be like o my phones broke they wont put it on there just be like can i get insurance wait a week or so and say your phones broke ..in the mean time step one/ get insurance step 2/ switch the num to a razor/ step 3/ let the insurance take effect on that number then when so switch back over then file the claim on your delve hope it helps that how i do my phones when there broke
Dec 18, 2008 | Samsung Cell Phones
Instructions on how to replace the slider part of the phone
1. take off the battery cover and take off the battery
2. take off the sticker hiding 2 screws that used to be behind the battery
3. unscrew every screw that you see on the back
4. take off the back
5. gently take off the chip. its safe unless your force it off
6. gently take off the slider part
7. unscrew the screws on the slider part
8. take off the 2 parts that are both beside each side of the LCD screen
9. now you can do anything you want
Oct 24, 2008 | Samsung SGH-a737 Cellular Phone
Samsung SGH-A707 Cellular Phone Logo
106 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
