Question about Speed Queen Dryers
My speed queen dryer (model 170) is over heating. Clothes are extremely hot to the touch and wrinkled.
    Brigadier General:
  • 3,301 Answers
Check the dryer vent to make sure nothing is blocking it, Hot clothes and wetness is usually caused by venting problems,, if the moisture and air can't leave,, you end up with your problem
Posted on May 27, 2011
5 Suggested Answers
watugot
  • 290 Answers
SOURCE: dryer too hot
You will want to make sure the lint screen and vent are free and clear.
If the dryer is blowing out the vent outside the house as it should, then you have a thermostat problem.
If the operating thermostat does not open properly then the element will cycle by the hi-limit thermostat which will cause the dryer to heat more than normal.
Posted on Nov 24, 2007
MNTECH
  • 1543 Answers
SOURCE: Dryer Heats - Drum Turns - Clothes Don't Dry - Dryer Seems To Over Heat
Before ripping into the dryer, with the dryer running, check the vent outside. There should be a rather strong air flow. I'll bet you have little or maybe no air flow. Check behind the dryer to make sure you don't have squished flex duct. If you have flex pipe, try running the dryer for a few minutes with the dryer pulled out into the room to stretch the vent out, and check outside airflow again. Try to eliminate all or as much of the flex stuff as you can, replacing it with aluminum dryer vent pipe. (tape joints with foil duct tape) Clean out remaining dryer vent. (there are special brushes you can buy to clean out vents, but they really only work on ridgid pipe.)
Posted on Sep 27, 2008
erpaalai
  • 999 Answers
SOURCE: coin operated speed queen gas dryer works some
Check the coils on the gas valve. Sounds like an intermittent one. Eric
Posted on Jun 20, 2009
SOURCE: Dryer heats up but clothes won't dry
I have an amana electric dryer. Changed out thermal fuse and cleaned out vent. Thermal fuse is blown again, but I noticed that it is not cycling. The dryer is very hot on the outside on top.
Posted on Sep 11, 2011
Wrinkles clothes terribly. Solutions.
Check your settings on your dryer. See if it's on a longer duration of time to dry. Dryers have different wording depending upon the make and model. If you're trying to dry smaller loads the heat settings s
does not have to be set for very long. Heavier, loads with thicker clothing will need to dry a little longer. When you take the clothes out of the washing machine, do you shake the clothes before putting them in the dryer? And do you use dryer sheets? Believe it or not, they're not only used to help make your clothe's smell fresh but they also help elevate static and a few wrinkles.
Mar 23, 2015 | Washing Machines
Kenmore dryer MOD# 110.61402310, Dryer heats up and is SUPER hot. Clothes are to hot to take out after. Seems like timer is messed up because it will run until you open the door. Only has one heat set
OVER HEATING HAPPENS ONLY IN ELECTRIC DRYERS NOT GAS DRYERS.... HERE IS A VIDEO FOR HELP ON THIS..
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Oct 28, 2014 | Dryers
Speed queen electric dryer heats for about 8 minutes then heat goes off and does not come back on
The duct may be clear but the exhaust on the back of the dryer may be blocked. You have to take the back off the dryer and check where the blower is. Good luck.
Mar 25, 2014 | Speed Queen AES28AWF Electric Dryer
Hi I have a dryer (Speed Queen) and I took off the front panel and cleaned everything and even in back, When I turn it on, I see the flame, But it does not get hot enough inside to dry the clothes, Is...
Clothes not drying, but dryer runs & heats
1. Defective operating thermostat---test thermostat,, replace if defective
2. Fan or it's pulley loose on shaft--tighten set screw
3. Incorrect heat or timer setting--reset timer
4. Clothes too wet when placed in dryer--wring clothes before putting them in dryer
5. clogged lint screen or duct ( little air motion)---clean
Sep 21, 2011 | Speed Queen AGS68AWF Gas Dryers
Speed Queen Heavy duty Dryer appears to shut down because of over heating. We have had this dryer for quite awhile and the kids are all gone now so we actually don't use it as much. It doesn't...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 14, 2011 | Speed Queen AES28AWF Electric Dryer
I have a GAS Speed Queen clothes dryer. I can't locate the model number. It says "Heavy Duty, Multi Cycle, All Fabric Automatic Dryer". I bought it new in September 1972. It has always...
It could be the vent chambers in the bottom of the machine from the front filter to the vent output to the rear exit vent ducting tubes....or the ducting itself. Flexable ducting, if you are using it, are well known to glog due to the multiple ringed wires inside. Flex is not recommended.
Also the gas line should be replaced with a gas flex line....it's the law here in CA.
Jun 26, 2011 | Speed Queen ADG4BR Dryer
My speed queen dryer model st0300 has no spark
The dryers do not spark, but light with a hot surface ignitor. This is often the cause of no heat for gad dryers...
Checkout this tip that I wrote about this problem..
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Mar 30, 2010 | Dryers
My dryer runs but does not heat up or dry clothes. What could be the problem?
I have a Kenmore dryer and it runs but won't heat up and dry the clothes. I don't hear the ignition even turn over. Please help. I can't afford to buy a new dryer at this time.
Feb 16, 2010 | Kenmore 62602 Electric Dryer
Our LG dryer doesn't get completely hot until the clothes are mostly dry.
heated air enters the dryer at 140 degrees farenheit,
a portion of the heat energy raises the temperature of the water in the clothes.
When the clothes are cold and wet, the difference is large transfer is rapid
a lot of heat transfers to clothes and the exhaust air is damper and colder
As the clothes get warmer and dryer, proprtionally less heat is extracted from the incoming air, and the exhaust air is warmer and dryer.
When the clothes are dry, and at 140 degrees, the same temperature as the incoming air. no heat is removed from the incoming air
the dryer should then stop heating, draw unheated air through the drum and clothes to cool, and reduce wrinkling
then switch off
the dryer appears to be operating correctly
Oct 31, 2008 | Dryers
Dryers Logo
166 people viewed this question
Top Speed Queen Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
danoyachtcap
danoyachtcap
Are you a Speed Queen Dryer Expert? Answer questions, earn points and help others
