Question about Sony Cyber-shot DSC-W120 Digital Camera
My camera comes on and then the lens retract and go back into the camera. The camera never fully comes on. The batteries are fully charged and there is plenty of memory. Please help.
  • 643 Answers
Could be one of the ribbon cables is loose. If you can open the camera and reseat all the ribbon cables. If the lens makes an ugly grinding noise the gears to the lens are chewed up. You can go to esupport.sony.com for a flat rate repair quote. Hope this helps.
Posted on May 27, 2011
Turns off right after startup chime lens does not retract
This can happen when you use a battery that is almost without charge. Please remove the battery and charge it, before placing it back. Then be careful not to touch the lens, till the camera has a chance to retract it.
After you place the battery the lens should retract.
If the battery is really charged. You should not think it is charged, because you had it on the charger till the light indicated battery full.
There is also a chance you stopped the lens while it was coming out. A sensor detected this. To avoid damage to the lens construction, the camera switched off automatically. Also remove the battery and after a few seconds replace the battery and switch on the camera. Careful you don't touch the lens again.
Dec 26, 2013 | Sony Cyber-shot DSC-H5 Digital Camera
Tip
Lens Error
Try removing and replacing batteries to reset the camera. Ensure that batteries are fully charged.
If that does not clear the problem, then the lens error is usually caused by mechanical faults concerning lens assembly. This happens because there is dirt inside the lens (sand dust), or one part in the lens assembly is bad or went out of place.
Because of this he lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
If if does not extend tapping gently the back of the camera, and if it does not retract helping lens back in while turning camera respectively on and off.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
on Jul 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
When I power up the camera the lens opens and immediately retracts and the camera shuts off. I've attempted to push every button while turning on the camera to no avail. I also held onto the lens when it...
Have you made sure that the batteries are LiIon and fully charged? I had a similar problem with a Kodak Easyshare camera that required the higher voltage LiIon battery pack rather than alkaline AAs which will fit in there but is not exactly right.
Feb 09, 2011 | Kodak EASYSHARE M763 Digital Camera
My camera will not stay on is off and stuck with lens out
If the lens doesn't retract on most digital camera the camera also will not turn ON. It is connection or wiring between camera power and camera lens.
What Kodak Rep will ask you to do are:
1. Remove the battery and the memory card of the camera
2. Check if your using a recommended battery and if its new or fully charge. batteries for Z1275 are Ni-MH rechargeable; CRV3 Lithium; 2AA Lithium
3. Insert the batteries back in the camera in correctly
4. Set the camera in Auto mode (its the camera icon on the dialing mode of the camera)
5. Try to turn it ON
If still will not turn ON and the lens will not retract
6. If your using a rechargeable battery Kodak Rep will ask you to charge the battery until its fully charge.
If your using a disposable battery they will ask you to try to use a new battery out from the box.
After all those steps still the camera failed to work, it will be send for repair. The number of the Kodak support line is 1 800 235 6325 (23KODAK)
Nov 20, 2009 | Kodak EasyShare Z1275 Digital Camera
Lens won't retract. Camera powers off immediately after powering on without retracting lens. New battery didn't help.
Are you using the recommnded battery KODAK Li-Ion Rechargeable Digital Camera Battery KLIC-7004
first you need to do make sure the battery is fully charged., now if you if this solution will not resolve the issue it means that the Gear Lens is defective thats why your Lens will not retract and camera will not stay On. you need to call kodak to send your camera for repair call toll free 1 800 235 6325., Gudluck!
Oct 31, 2009 | Kodak EASYSHARE V1253 Digital Camera
Samsun sl201 lens will not extend, then camera shuts down
If the camera's lens will not retract out, then eventually shuts down, here is what you try to do.
Hold the camera from your right hand with the lens facing down. Then tap the base of the camera to your left palm while turning the camara on; do this several times until the camera's lens retracts out.
This problem often occur when the camera was taken outdoor or in the beach. Sand or a tiny granule of dirt might got stuck in the base of the lens.
Sep 25, 2009 | Samsung SL201 Digital Camera
Hi-- my canon SX110 won't switch on properly. it keeps telling me there's a lens error and to restart. when this has happened in the past, i've just switched it off and then on again and it's worked. not...
Jul 16, 2009 | Canon PowerShot SX110 IS Digital Camera
Lens will not retract after being
the problem is that the lens is out of alignment. if its not making grinding sounds try manually help the lens to reseat itself. if that doesnt work its not ecomical to repair unit cuz parts and labor are about 120-130 dollars.
Jun 03, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
NO LCD IMAGE / LENS STUCK
hi ban ive same problem bloody nusience lens wont retract what did u do with urs?
should i return it?
thanks leeanne
leeannehutchinson@btinternet.com
Feb 17, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Lens wont retract, makes noises, error code on blue screen D:1E 1A
I posted the same problem on the 15th June and in the meantime I have been playing around with the camera. After holding the camera upside down and gently tapping the back of it, the lens decided to work and retract back into the camera. Not the most technical advice I know but it seemed to work.
Nov 18, 2006 | Olympus Camedia C-60 Zoom Digital Camera
Sony Cyber-shot DSC-W120 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
