Question about Cavalry Storage (CAXA3701T0) 1 TB USB 2.0 Hard Drive
My computer is not reading the e: drive when I plug in my Calvary external drive. I may have unplugged it before I was supposed to when I last used it but the computer should still read the drive right?
  • Cavalry Storage Master
  • 27,725 Answers
If your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Posted on May 27, 2011
My black calvary external hard drive won't turn on.
Would be great if the next time you also place the model number, because Cavalry makes dozens of different drives.
When the bleu light does not go on, you have to assume the drive is not getting power.
If the drive has only one cable, (small drives like 2,5 inch most of the time only have one cable) it could be the USB cable is defect and can't give through the 5 Volt coming from the computer USB connector. It also could be the 5 Volt supposed to be in the computer has gone.
If you have to connect an external power supply, with a small cable to the drive, I would check the power supply. A 5 Volt 2 A supply, with the round plug can't be that expensive.
If both don't work, it also could be inside the housing of the drive is something defect.
If you need to have the data on the drive, you always could but an universal USB connection for hard drives. I have one for IDE and E-SATA, in the box came a set power cables and a power supply, but that one was almost 50 dollar. There are cheaper ones on the net.
Be aware drives don't live forever and make sure you always have at least two backups. (that is more than one origin; and one back up)
Jun 16, 2014 | Cavalry Storage Computers & Internet
I can't see driver calvary caum3701T0
Make sure you have the external power supply plugged into it.. that there is power, and that you have the drive turned on. After that make sure your USB port and cables are functioning properly.
Mar 19, 2011 | Cavalry Storage CAUM3701T0 1 TB USB 2.0...
My computer (HP Pavillion p3101) won't see my external Calvary drive (500 gbcaue37500) It worked a few times and now I can't access it.
Press the start button and right click "my computer"-> Manage -> Storage -> disk management. It can take up to a minute before displaying your discs. Rightclik your 500 gbcaue37500 and and depending on what's avaible;
Change from offline to online
initialize
Assaign a drive letter to the drive
  • If my solution helped, feel free to rate it!
Jul 30, 2010 | Cavalry Storage Cavalry 500GB 3.5 7200RPM...
PC won't boot some external devices attached/on
some computers need to have all external drives unplugged before they will boot up because it cant tell the difference between which drive to boot from.
hope this helps.
Apr 30, 2010 | Computers & Internet
My LG slim external drive worked a few days ago but now I guess the usb port doesn't read it. It's supposed to be plug and play but no matter how many times I unplug it and plug it in my computer no longer...
I gives you a suggestion. Please scan your laptop. I guess virus corrupting your usb drives thats why its happend. every time u have got the same things. If you follow slowly slowly u have lost all of your external connectibity via USB or bluetooth also. if not found any virus and the same thing happend then i suggest you formet it and reinstalled your OS.
Jan 30, 2010 | LG SecurDisc 8x External Double-Layer DVD...
My Calvary external 500GB hard drive is not being recognized
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Sep 21, 2009 | Cavalry Storage Cavalry 500GB 3.5 7200RPM...
I have a calvary 1tb external hard drive and my computer is not recognizing it
I have found that computers 5 years and older often have problems recognizing Terabyte hard drives. If you know what motherboard you have i can look it up for you, but if it is an older computer, the motherboard likely wont support the size.
Sep 13, 2009 | Computers & Internet
Calvary 1TB USB 2Bay external hard drive problem
The problem could be the enclosure, not the drive.
I would take the drive out of the Calvary enclosure and install it in another one. Hopefully it will come up and you can access your data.
Jun 15, 2009 | Cavalry Storage Cavalry CADB001U32 1TB...
My computer stopped reading my external hard drive
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Kind Regards
Andrea
Nov 13, 2008 | Seagate Free Agent Go Small 12 GB USB...
CAlvary 500 GB CAXE37500 not switching on
Kind Regards
Andrea
Jun 04, 2008 | Cavalry Storage EXTHD 500G|CAVA U2&ESATA...
Cavalry Storage (CAXA3701T0) 1 TB USB 2.0 Hard Drive Logo
145 people viewed this question
Top Cavalry Storage Computers & Internet Experts
gary433
Glenn Smart
Glenn Smart
shahid_ptv
Are you a Cavalry Storage Computer and Internet Expert? Answer questions, earn points and help others
