Question about Tatung L17AMTN 17" Flat Panel LCD Monitor
My Tatung L71 keeps turning off The colour is not quite right either I'm not sure if this is a driver problem or software that I'm missing I don't have any disk with the moniter so can't reinstall
Kyocera Domino 1300 keeps restarting and won't go past the start up screen that says Kyocera, then shuts off and turns back on again and does the same thing over and over. I tried removing the b
quit messing with the battery for starters. you want to startup into safe mode. If you can get into safe mode then its a software problem, if not then it is a hardware problem. also if the power cord is plugged in and the battery is out of the computer and the problem persists then it has nothing to do with the battery.
Aug 25, 2012 | Computers & Internet
I can't install my Documate 632 on my Dell laptop running Win 7 64 bit. It was working in the past, but quit working. I uninstalled all associated software and started over. It just won't install,...
For that first you need to uninstall old driver and software with revo uninstaller. Click here Download from above link and install then uninstall old driver and software with it. Also go to device manager right click on my computer then click on property then ->device manager uninstall all usb drivers then it will automatic install all usb drivers download driver from your printer's manufecturer web sites then install. Make sure there is not any incompatible driver or software on computer. Let me know if you need further assistance. Thanks for using FixYa..
Aug 18, 2011 | Xerox DocuMate 632 Scanner
Sir, i want to scan a colour matter , i have 2570 cannon printer copier, please tell me or send software
it does not require any software just on the printer and keep the document on platen and click the colour button a green colour button.
Oct 17, 2010 | Office Equipment & Supplies
My Tatung LD23HL Flat screen will not turn on. Is there a reset? When plugged in the power light blinks Orange.
check the monitor to computer cord, sounds like it might be loose or disconnected. swap another monitor in and go to display properties to see if the tatung is a 2nd monitor. using the replacement monitor redownload the drivers and reinstall. turn off and hook the tatung back and it should recognize it
Oct 09, 2010 | Tatung LD23HL Monitor
Just want the L71 software to install...supplied CD from the vendor does not work!
plz follow these links, i hope u will get the solution by different different softwares.
http://www.nodevice.com/driver/company/Motorola.html
http://www.nodevice.com/driver/MOTO_SLVR_L7i/get39406.html
http://www.giveawayoftheday.com/soft/83509/
Nov 02, 2009 | Motorola Mobility L7I Cellular Phone
Prints light purple instead of grey
I think your Black Cartridge is Empty. Check it and replace it with the new one.
Your Printer is trying to produce Black Colour from your Colour Cartridge with a mix of Cyan, Magenta and Yellow.
Apr 23, 2009 | Canon PIXMA MX850 Multifunction Printer
Cannot get CPU to recognize Tatung LCD Monitor
When you reinstalled the drivers, did you reinstall the video card drivers? The drivers for your video card should be sufficient to power your display.
Mar 24, 2009 | Computers & Internet
Tatung wont turn on
I have v30dmtt 29 inch tatung and had the same problem. I took the power supply out and took it to repair man. He told me it couldnt be fixed. I contacted the manufacturer and had a new one sent. The phone # is 915-771-7554 but you need to call 1-888-482-8864 to get a case #. It costs 70.00 for a new power supply unit.The part # I needed was 6693006610. I hope this helps.
Sep 08, 2008 | Tatung V23CLTT 22.92 in. LCD Television
Software for motorola L71
Sir,
It is a mobile virus problem. plz give me the additional details which OS is used in mobile. for ex. symbian or java based. U can install any mobile anti-virus software program to clear this problem. okz bye.
Good luck
Don't forget to rate the solution
Mar 10, 2008 | Motorola Mobility Mobile PhoneTools 3.0...
Tatung L17AMTN 17" Flat Panel LCD Monitor Logo
67 people viewed this question
Top Tatung Computers & Internet Experts
David Payne
David Payne
Are you a Tatung Computer and Internet Expert? Answer questions, earn points and help others
