Question about Yamaha RX-V1600 Receiver
About a month ago my speakers started humming-does't matter if the cable/dvd are on, as long as the receiver is on it hums. Figured out it was the receiver since I plugged other speakers into my Rx-V1600 and they starting humming as well. I've had the system for about 4 years. Thanks, Adam
    Brigadier General:
  • 3,301 Answers
Normally a Hum is caused by a bad ground,, if it only happens when the unit warms up it could be the output drives are failing. , check the grounds to the unit first, then the wires to the speakers themselves, if they all check out ok,, you need to take it to a repair shop dealing with receivers
Posted on May 27, 2011
Testimonial: "Thanks for your prompt reply!"
2 Suggested Answers
SOURCE: Receiver humming momentarily when turned on
i have solved thsi problem. The reseller suggested that probably a earthconnection was demaged and indeed that was the problem. by heating the earthconnections, specially the wired ones this problem disappeared.
Posted on Feb 02, 2008
My tv won't stop humming. I have only had the tv for 2 months
make sure you have it and the other electronics plugged into a surge protector strip and all cables wires & connections are fully seated (fully plugged in).The problem is in how the electrical current is being received and it is manifesting the humming sound / " GOD BLESS "
Apr 08, 2013 | Televison & Video
I have an older model Harman Kardon AVR and have started hearing humming from the speakers that are attached to it. Is my receiver going bad or is there something else I need to do to fix this problem?
you may have a bad Earth power 110 V AC cable connection which makes such hum / buzz even nothing connected..
Check the connections between components and make sure they are secure before proceeding to the next Step. Sometimes, loose connections can cause a hum.
  • Separate the audio cables from the power cables; electromagnetic interference from the power cables can cause stereo hum. Use cable ties to secure the audio cables away from the power cables.
  • Plug in a surge protector to the outlet, and then plug all the components into that surge protector
  • Connect a ground plug to the surge protector and then plug the ground plug into the main outlet. A ground plug is available at any hardware store, and turns a three prong connection into a two prong. Ground plugs help eliminate 60 cycle hum.
  • 5 Connect the ground wire from your turntable to the ground wire connection on the receiver. If this doesn't work, looking on the back there should be a grounding point,
    Unplug your receiver.. Split a wire and attach one of the splits to the receiver where you will see the text, "ground" or something similar. Attach the other end to something metal such as a pipe that goes into the ground. Secure with electrical tape. Plug in.
    connect the ground wire to a screw on the electrical outlet.
    Read more: How to Fix a Hum on a Stereo Receiver ' eHow.com http://www.ehow.com/how_5183193_fix-hum-stereo-receiver.html#ixzz1PpFHs1Mv
    Take care and please remember to rate "AS THUMBS UP" Thanks
  • Jun 20, 2011 | Harman Kardon AVR 85
    Humming sound when watching tv,but not when watching dvd's
    It wounds like you are getting interference from you tv to the receiver. You can try a few different things here.
    1. Connect the tv output into another input on you receiver to see if it isnt the channel on the receiver.
    2. Try a different set of cables between the tv and receiver. Faulty cables can give you problems.
    3. Connect the cable from you tv to a different device. (another dvd vcr blue ray etc.) This will tell you if its the receivers or the tv.
    Sep 13, 2009 | Yamaha HTR-6030 Receiver
    Pioneer Receiver SX-750: Getting a loud hum through the speakers
    The hum you hear from the speakers and from the unit itself originate with 60hz AC power. They may not actually be related. Sometimes a transformer will hum slightly and unnoticeably. That you're getting a loud speaker hum says there is an electrical leak or a grounding issue somewhere.
    Do all sources produce the hum or, say, just the phono? How about on headphones? Try rotating the AC plug. In those days they weren't keyed with one large blade as they are now.
    May 17, 2009 | Pioneer Audio Players & Recorders
    Humming noise
    Usually Humming noises come from frequency interferance.  In this case it is being caused by your input sources.  A smiply solution is to replace the cables and or seperate the source cables away from any electircal cords or sources.
    Jan 07, 2009 | Harman Kardon AVR 225 Receiver
    60hz hum
    I sent a solution to this already. If you did not receive please let me know. Thanks for using Fix Ya.
    Dec 06, 2008 | DISH Network DVR-625 DTV Receiver /...
    X-230 Speakers Hum
    bad brain in it or u can try to see if its pused in all way cables in back dl latest sound card drivers
    Jan 16, 2008 | Logitech X-230 Computer Speakers
    Speaker hum on playback with tape or dvd
    Any cable? Hum is generally a bad ground. If you use cables and speakers that have no hum elsewhere, and more than one set has hum on this machine, then the unit has a grounding problem, and requires repair on an 'open up the unit' basis.
    Jan 11, 2008 | RCA DRC6300N DVD Player/VCR
    Hum from speakers
    I suspect an open ground or bad cnnection in your hdmi cable to the amp from the sat.A hum is very indicative of that situation
    Dec 11, 2007 | Onkyo TX-SR604 Receiver
    Yamaha RX-V1600 Receiver Logo
    236 people viewed this question
    Top Yamaha Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Electro Med Services...
    Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
