Question about Emerson MW8107WA Microwave Oven
Mircowave oven I have a brand new Emerson MW8991SB It shuts down after 2 Seconds Whats Wrong??
    Master:
  • 377 Answers
CHECK THE PROBLEM ON THE BURN THERMAL FUSE ON YOUR UNIT.
Posted on Aug 16, 2008
Replacement glass turntable
Go to www.ebay.com Type make and model of microwave oven, refine search to plate.
Jul 11, 2012 | Emerson MW8991SB Microwave Oven
Microwave is not heating, it seems as if is stuck in defrost mode. Two red lights are showing at the top of the microwave
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 '';
May 28, 2011 | Emerson MW8991SB Microwave Oven
On the Emerson MW 8992 SB microwave oven how does one change power settings,e.g., from 100% to 50%?
Emerson MW8991SB 0.9Cu.Ft. 900 Watt Touch-Control Microwave Oven, Stainless Steel has the same face as your microwave. I own one of them Look at the bottom three uo to the left it says (POWER) push the Power button it starts at 10 and goes to 1. 10 being the highest and 5 being half power and 1 being the least. then select the amount of time you will cook by punching in the numbers.
Jan 17, 2011 | Emerson Microwave Ovens
My turn table doesn't turn on my microwave (Emerson MW8991SB)
Replacement of the turntable motor should be carried out by a qualified appliance repair service.
But here is a basic methos if you are mechanically minded and have electrical safety knowledge.
The motor assembly is fixed to the base of the oven usually with two screws and access is obtained usually by removing the inspection plate directly beneath the motor. It is usally a plug in synchronus motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate, sometimes it must be cut out with sharp cutters, and disconnect the motor. Remove the motor and go and get a new one. Fit the new motor and fit the inspection cover back on the base by turning it to fit and using an extra screw fix it then put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Jan 04, 2011 | Emerson MW8991SB Microwave Oven
My MW clock is on, ligh goes on, keypad works,it counts down but it does not heating up.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Dec 31, 2010 | Emerson MW8991SB Microwave Oven
Microwave is not heating food it turns two red lights on when trying to heat food
Basic
heatman101
Nov 07, 2010 | Emerson MW8991SB Microwave Oven
Need a manual for MW8991SB
Hi
Thanks for using FixYa. You can view/download the manual for your Emerson MW8991SB Microwave from this link--
Emerson MW8991SB Microwave Manual
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 06, 2009 | Emerson Microwave Ovens
How to change a light bulb in a emerson mircowave model mw8115ss
If this is freestanding m/w:
1. disconnect from outlet
2. take the cover off.
3. light bulb located on right upper corner.
Nov 30, 2008 | Emerson Black Microwave Oven
Need plate inside
try partstore.com
or
microwaveglasstrays.com
Feb 22, 2008 | Emerson Black Microwave Oven
Emerson MW8107WA Microwave Oven Logo
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
