Question about Dryers
Replaced broken dryer belt. Drum now spins, except when there is too many clothes in drum. Its like the weight is too much. After I remove several items, it spins again
  • Dryers Master
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly.
This symptom sounds like you installed a belt for a 29 inch dryer on a 27 inch dryer. It happens more often than one would think. If you provide your model nunber I can provide you with the proper belt routing diagram around the idler and the correct belt part number.
Thanks for choosing FixYa,
Kelly
Posted on May 27, 2011
Dryer won't spin
Was the belt shredded ( normal wear & tear ) or burnt through which could be a drum bearing or support problem .What does the drum feel like when you turn it by hand is it grinding & lump ? The fact that the motor runs with no load could by the start device faulty these are reasonably cheap to replace this is the small cylinder attached to the side of the motor with two wire connections . if your motor has not got one of these then its the start windings in the motor
Jan 11, 2013 | Maytag Dryers
Inglis clothes dryer heats up but drum doesn't
The way to visually see if the belt has broken or not is to 1) unplug the dryer. 2) Remove the lint screen on the top of the dryer. 3) take the two phillips head screws out where the lint trap is. 4) with a flat head screwdriver pop the top of the dryer up by sliding the driver inbetween the top and front of the dryer and pry upwards a little. 5) You'll now see the drum, if the belt is not around it its broken, and if it's visible try to lift it. If it taught, its good. IF THE BELT IS BROKEN OR LOOSE CONTINUE TO NEXT STEPS 6) on the left and right upper inner sides of the dryer you will find two screws, one on each side, remove these and the front should be easlily remove. 7) once off you'll be able to easily see the motor, the belts idler pulley, and everything else.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 28, 2012 | Whirlpool Dryers
My Whirpool dryer Mod. LEN 2000LWG, type DWSR-ELE-2406028-CV54, Imperial Series, was working fine, but after the second medium sized load it stopped drying the clothes. I finally noticed that the inside...
The Hum most commonly means that the drum belt on your dryer is probably broken
There is a simple way to test for this.
1 remove the clothes from the dryer.
2 put your hand inside the drum and turn it. If it is easy to turn, the belt is broken. If it is difficult to turn, the belt is good. You may be looking at motor problems.
Almost all of the time, it is a broken belt.
The link below has the full procedure for changing the belt.
Hope this helps,
Best Regards,
Mark
http://www.fixya.com/support/t6322596-get
Jan 19, 2011 | Whirlpool Dryers
Maytag Dryer drum not turning properly after cleaning
Make sure the drum belt is positioned properly. You may have disturbed it when you removed the front door panel. It should be a tight fit on the drum. You should see the wear pattern on the drum where the belt was. Check the condition of the belt and make sure it's not cracked or stretched and slipping. Did you disconnect any wires when you opened it? Double check that you didn't rehook the wires wrong and make sure the door sensor switch is in proper position. Hope that helps.
May 14, 2010 | Maytag Dryers
Dryer wont tumble when loaded.
check for a "glazed" drum belt or a broken "idler" pulley near or on the motor that keeps the belt tight on the drum
May 10, 2010 | GE DBXR463GB Gas Dryer
How do i fix the tub from not spinning
You did not say if it was broken or not...
If it is broken then it must be replaced.
If it is not broken, then it must have came off the pulley or the drum.
you have to pull the front of the dryer off and remove the drum to reinstall the belt on the pulley and the drum
Sep 25, 2009 | AEG Dryers
Would not dry clothes to original dryness. Now drum is making a whinging noise at the drum spin as though its catching on something every time it rotates. Also made a very loud clattering noise as it...
I had this same problem. The drum spins on two small wheel which with the help of the drum belt support the drum. The wheels or their brackets may be broken and need to be replaced. These are accessable by taking the back off the dryer. Best to take the old/broken ones in to insure you get the exact replacement.
May 01, 2008 | Washing Machines
Maytag MDG3000AWW drum moving slowly
If the belt looks worn you should replace it. But it sounds like the idler pulley has gone out of position or possibly broken. The idler pulley adds tension to the belt and keeps it from spinning on the drum surface. Check the path of the belt on the bottom of the dryer. That is where the idler pulley is.
Feb 01, 2008 | Dryers
Replaced idle pulley but drum wont spin when clothes are in it
Ok, when you removed the front cover to gain access to the idler pully, did you make sure that the drum didnt slip off one of the two roller wheels in the bottom rear of the dryer. If you get one of those roller wheels jammed and not in the track right, they will jam up. Look down at the bottom, grab the rollers, and pull them forward to be sure they are in the groove of the drum. Also, are you sure you relooped the belt correctly back around the idler pully? The best way to loop the belt is to place the idler pully in the correct position, then drop the belt down in front of it, loop the belt under the idler pully, push it back to tension everything, then take the loop and go over the motor pully (should be pretty tight). See if one of those solutions will help. Also be sure that you are properly getting the drum in the right position over the front seal (front should go on pretty easily, if not, reach your hand in the door, and lift up on the drum to center). Thanks and good luck!!!!
Jan 25, 2008 | Dryers
Dryers Logo
Top Dryers Experts
