Question about Microsoft Xbox Console
I hear no sound from headset - Microsoft Xbox Console
Cant hear anything when I make a call
The phone may be in headset mode. If you can hear sounds through the headset but cannot hear sounds from the earpiece on the phone, it's in headset mode. Power down the phone and restart it. Otherwise no sound from the earpiece mean a bad earpiece.
Oct 07, 2013 | Cell Phones
How to pair nokia bh-104 with iphone
Ok.. you need to do the following:
1. Turn the headset off. 2. Turn on the Bluetooth on your iPhone (it will automatically start searching for Bluetooth devices) 3. Press and keep pressing the power button on your BH-105 Nokia Headset until you hear two sounds, the first is the one that notify's you that the Headset is turned on, keep pressing and you will hear another sound (like a beep), once you hear that second sound release the power button on the headset and voilaaa... your iPhone detected the Headset... Cheers...
May 23, 2010 | Nokia BH-104 Bluetooth Headset
5530 XpressMusic Smartphone: I can hear the sound through the headset only when...
hey man, i have the same problem too. i tried using 2 brand new headsets for my 5530, but still, it didn't work. and the person i talk to during calls can't hear me with my headset. :' it sucks :'
May 16, 2010 | Nokia 5530 XpressMusic Smartphone
Cyber Acoustics AC-201 Micrphone Problem
i have cyber acoustics headset and i cant hear anything but my Mic works, my sound is all fine, when i plug my headset out i can hear but when its plugged in, i cant hear anything.
Mar 09, 2010 | Cyber Acoustics AC-201 Consumer Headset
Can't hear people on the other end
Make sure your headset is set to your default device on sound playback in the Sounds and Audio Devices Properties dialog box which is accessed through the control panel. Also make sure the application your using is also set to your headset.
Jul 15, 2009 | Logitech 250 Headset
I can make outgoing calls but receiver can't hear me
test on sound recorder in windows if the sound work there contact software developer.
Jun 16, 2009 | Logitech ClearChat Stereo Headset Headset
Cannot hear but people can hear me with 330, No sound.
This may be a broken or loose wire in your headset that prevents you from hearing them.
Or the headset is not turned on. Press the call control button for 2 seconds until you hear a beep or see the indicator light glow blue to turn headset on. Your headset is out of range. Move the headset closer to the phone or Bluetooth device.
Good luck from Headsets Direct!
Jan 17, 2009 | Plantronics Explorer 330 Headset
I have speekers but when i am in a chatroom i dont get to hear what people are sayin how did it get to be able to hear them????
1. go to control panel
2. choose "sounds and audio devices"
3. choose the "audio" tab
4. there are "default device" for "sound playback" and "sound recording", change both to logitech usb headset"
you then effectively enable the headset and disable the speakers. and the sound will remain on the headset after unplug and replug.
Dec 17, 2008 | Logitech 250 Headset
Logitech Microphone Not working
Hi, I have a skype approved logitech headset. I can hear sound, but I cannot record sound or communicate on it. I cannot even find the headset as option as Preffered Device in Sound and Multimedia. I am using Windowsxp
z. Please help.
Feb 21, 2008 | Logitech (980174) Headset
No more sound from speaker
I had a similar issue on mine. The easy fix was to insert a headset jack and pull it out quickly. I think something got stuck that turns off the speaker after I put the headset in the jack once. If this is the problem, I think you should also see a headset icon when making calls, even though no headset is attached.
Jun 15, 2007 | Sprint Vision PPC-6700 Smartphone
Microsoft Xbox Console Logo
19 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
