Question about Watches
Needs batteries lionel collectable train watch need user guide and battery size
The Lionel Collectable Train Watch has 3 batteries in it. Two are for the whistle and one for the watch. All of them are V377 or 377 disk batteries. Gently pop off the back cover as most watches come off the same way. The battery by itself toward the middle is the train timepiece watch battery and is installed with the + side up toward you. The two batteries toward the edge are the whistle batteries, and you have to be very careful in changing them. Thee us a rotating contact that is plastic coated, over the batteries. NOTE: THE BATTERIES ARE NOT BOTH IN THE SAME DIRECTION. ONE IS UP AND ONE IS DOWN. (LOOK VERY CAREFULLY FOR A + AND - SIGN ON RIGHT NEXT TO EACH BATTERY.) For this reason, it is recommended to only change ONE battery at a time, so you will not get them mixed up. Gently spin the contact one direction, and one of the batteries will be clear and come out. Change that battery. Now rotate the contact back to the original position over both batteries, and continue rotating in that direction until the second battery is clear and can be removed. Change that battery. Now you can confirm that you still have one battery up and one down. Rotate the contact back to its original position, centering it on each battery. This contact has a layer of plastic material covering it on top so that it will not contact the watch case. If this plastic coating is damaged, it can damage the watch. If it is damaged, you might put a small piece of tape over the contact, to prevent other damage. NOTE that close to the edge of the watch is a very, very small spring sticking up. Make sure that spring is still vertical, as it is very delicate and can be damaged easily. That spring as well as the metal arm sticking up are part of the speaker circuit and must be in their place when the cover is replaced, as the speaker is in the cover. Now gently replace the cover until it snaps down. You will see the train moving around the dial and you can push the button and hear the whistle. Incorrect changing of these batteries by persons in jewelers departments of stores like Walmart and Target, have damaged more of these watches than you would like to believe. Hope this helps. (By the way, I do not have a brochure for the watch at this time.)
Posted on May 19, 2013
5 Suggested Answers
SOURCE: watch battery
i dont know how i change the battery to a hugo boss watch
Posted on Mar 13, 2009
escapement
  • 2334 Answers
SOURCE: dont know battery type for ecclissi watches?
Measure your original watch battery (diameter and height).
Compare with the cross reference list and find exactly what you want.
List is here: www.battery-info.co.uk/watch-battery-cross-reference.html - 19k - Cached - Similar pages
Posted on Dec 21, 2008
night71
  • 328 Answers
SOURCE: BATTERY SIZE
If you do not have the manual for it, you may need to remove the back cover in order to see th battery type. If removing the back proves too hard, a jeweler may do it for free or minimal charge. I got my battery from a dollar store and is a good name brand.Easy to install yourself.
Posted on Oct 28, 2007
SOURCE: how to replace the battery in a kenneth cole watch kc3346
I have not figured out how to open the casing lid to replace the battery, but the number for the battery you need should be engraved on the lid. Double check your own lid, but mine says that the battery is an SR621SW. I'm sure there are different brands that would match this number.
Posted on Aug 04, 2010
Lionel collectable watch , size batteries ?
Take the back of the watch off and look, we have no battery charts here.
Feb 17, 2017 | Watches
What battery number needed for this watch?
Take your watch to a jeweler who will open it, identify battery type, and perhaps install a replacement.
Need watch battery size for a fossil blue watch model number Tl-5073
  • Remove back
  • Find battery mounting. Note for later battery installation
  • Read battery type (not size)
  • Obtain exact battery replacement
  • Remove old battery; install new
  • Check operation
  • install back
  • Set watch
Sep 09, 2016 | Fossil Watches
What size battery does Tommy bahama RLX3005 watch require?
1.800.677.8278 All I can find is a phone number. Hope this helps.
Aug 09, 2014 | Tommy Bahama Watches
Can I replace the battery or does a jeweler need to do that?
You can do it yourself, but getting to it can be tricky, to nearly impossible!
Sometimes you can go to a Walmart jewelry section and they will show you how to take the back off, often there is a particular tool.
The batteries are different, and once you get it open,. you can see which one it takes.
God bless your efforts.
Mar 18, 2014 | Callaway Golf Collection Series Two Tone...
What size battery do i need for this watch ?
there are two batteries inside your watch one is for analog sr621 size of battery and the other one is for the digital cr2016 size of battery, i hope this will help you.
Sep 25, 2011 | Fossil Big Tic watch #BG1006 Watch for Men
Need to know what battery is needed for Gucci 1500L.
The battery requirements are: 364 / LR621 / AGI 13mAh - these are the same battery with different names. Hope this helps.
Nov 12, 2010 | Gucci 1500 1500.21531 Wrist Watch
What size battery do I need for armitron digital sport watch 40-8117 m-690
If the watch #/size is not printed on the back of the watch, you will actually have to remove the battery to figure out what size you need. Best regards.
Aug 21, 2010 | Armitron Compass Bezel Chronograph Sport...
I left the battery in my watch for a long period. when ihad the battery reknewed it would not work
This could be due to several things. 1) if the battery leaked it could have damaged the circuit or gear train requiring a watchmaker to repair this.
2) the person replacing the battery could have damaged the coil, battery contact, gear train or gotten dirt in the movement. Again a watchmaker would be needed to repair this.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Nov 01, 2009 | Watches
Dont know battery type for ecclissi watches?
Dec 20, 2008 | Watches
Watches Logo
3,773 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
