Tape stuck inside. child put it in upside down.
    Master:
  • 377 Answers
Take the top of your VCR off keeping mind of where the screws came from, by the front of the tape there will be a gear wheel called the elevator wheel. After you have carefully unlooped the tape from the head, turn the elevator wheel, and you will be able to remove the tape then. Simply spool the tape back up and replace the cover.
http://www.fixya.com/support/t931883-tape_stuck_in_vcr
Posted on Aug 16, 2008
I experience problems with my VCR. A tape got stuck. After I removed the tape, it comes up with an error message F03
If you have children who can access the machine, unplug it, turn it upside down and listen for any rattles or loose bits inside. Kids are notorious for 'posting' coins, half eaten snacks and the like into the 'letter box'. Any loose objects, particularly metal, MUST be removed before switching on again. If a tape has become damaged, bits left inside the machine, it will have to opened up to remove the debris and ensure that the tape transport path including all rollers etc are cleared.
Jul 04, 2014 | Panasonic Televison & Video
Tape keeps ejecting
You can check tape player for any type of object lodged in it. Maybe unplug and turn upside down to here anything inside. Or even any broken tape that come off inside. The only other thing is that the belts inside are worn and will not put device back in play mode.
Dec 22, 2007 | Sony SLV-N55 VHS VCR
How to eject stuck tape
might have to remove bottom of vcr and manually move the drive motor by the belt or the pully. if the bottom doesn't come off, you'll have to remove the top. usually screws on the side bottoms and one in the back. you can reach the motor from there.
Feb 27, 2014 | Mitsubishi Televison & Video
I accidentally inserted a tape in backwards and/or upside down, and it appears to be stuck in there. I can't get the metal casing that encloses the tape to raise up and open. When i push the 'open/eject'...
You should open the tape holder meatal ther may be 4 screw! take it off! and release your tape! don't do it again with the power on it might get damage inside! enjoy man n try it!
Oct 29, 2010 | Sony Handycam DCR-TRV350 Digital Camcorder
Child put dvd in upside down and it won't eject the dvd. Any suggestions.
if you dont mind scratching the dvd you could try inserting another dvd to try and push free the stuck one i have done this and it usuly works for me
Sep 28, 2009 | Rosen A10 ALL-IN-1
Tape seems to be stuck to itself, I can't free it up
I think you are refering to the tape itself in the VHS cassette and it not being stuck inside the Video itself!
So if you are... don't use the spray... video cassettes have a brake system inside them. It sometimes breaks. If you turn the cassette upside down so you can see the white reels, inbetween them near the bottom (where the side label goes) you will see a small hole. If you put a pen inside it should release the reels so you can turn them with your finger. If they don't turn it may be broken. In which case... Get hold of a blank tape, the same length as yours. Carefully remove the screws (5) on the bottom. See how it's put together. Once you understand how the tape moves etc. Take out the reels with the tape, then dismantle your video and put the reels with the old tape into the new holder. It should work as good as new.
PS try not to touch with fingers the tape.
Sep 27, 2009 | Panasonic AG-1330 VHS VCR
Video tape stuck in machine VT-M610EUK I think there may be something wrong with the mechanism, it is possible it has got damaged by the little one putting bits in there. Can I take it apart and...
HELLO
It is very possible that damage has been caused by your child putting things inside the cassette flap - they love to do things like this!
As for your tape being stuck in the mech my advice is don't try to remove the cassette yourself as it will do more harm than good and there is quite a few faults that cause this problem. It could be a mode switch fault, or loading motor problem - it's hard to say.
Depending on how old the VCR is (6-10 years old) it may be cost effective to replace the machine as a repair will cost £30 plus.
I hope this helps!
Sep 03, 2009 | Televison & Video
Paper stuck inside cd slot
There is no need to open up the console! Get someone to hold the PS3 upside down (so the disc slot is facing down) then get 2 butter knives insert them carefully one on the left and one on the right of the disc slot. Now gently push the knives away from each other so that the one on left goes left and the one on the right goes right. You will feel them push the brackets that hold the disc in. As you push the brackets you will release the mechanism that holds the disc in and it should just drop out. I did this with mine when my little boy decided to put a credit like card in it!
Jul 06, 2009 | Sony Playstation 3 (PS3) Console
My child stuck something in ps3 and now my game is stuck as well
There is no need to open up the console. Make sure the power is off! Get someone to hold the PS32_bing.gif upside down (so the disc slot is facing down) then get 2 butter knives insert them carefully one on the left and one on the right of the disc slot. Now gently push the knives away from each other so that the one on left goes left and the one on the right goes right. You will feel them push the brackets that hold the disc in. As you push the brackets you will release the mechanism that holds the disc in and it should just drop out. I did this with mine when my little boy decided to put a credit like card in it!
Jun 06, 2009 | Sony Playstation 3 (PS3) Console
My canon mp220 printer is not feeding paper through and there is no paper jams
try turning your printers upside down as it may have something stuck inside it!!! i had a crayon inside mine which caused the same problems as you.
Sep 16, 2008 | Office Equipment & Supplies
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
