Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
Gas igniters all try to lite on their own - Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
Did you spill water before hand adn did problem clear up whne everything dried?
Posted on Aug 16, 2011
Gas igniter on N604 3F fridge does not ignite gas, how do I fix this. Thanks
when starting on Lp does board click or light on board lite up see if voltage to ignitor if no voltage bad board if voltage to ignitor bad ignitor if lites check burn tube
Jun 30, 2014 | Thetford Refrigerators
All pilots ignite when 1 gas knob is used on one burner
All igniters will spark when you turn on any burner but only the one you have turned on will allow gas through to ignite.
May 04, 2014 | GE Kitchen Ranges
Jandy LXi gas heater error message "ignition control failed
if ignitor is glowing try changing position of the shutter 1/2 to 3/4 open should lite
Dec 22, 2012 | Jandy Laars LX Pool Heater / 250,000 BTU /...
Jandy lite 2 heater model lj325n - code fl4 - hot surface igniter problem- I tapped the gas valve and checked the fuse , still getting the same code.
Igniter circuit is open. Check fuses on igniter wires. Identify and correct loose or broken wires.
Element has a fine crack in it. Replace
Igniter fault. Replace igniter.
Aug 31, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
Burners on top of stove does not ignite. You smell gas and you have to lite with match. The ports are clean . thanks
what's the model number?if you smell gas and it doesn't lite you could have a bad spark module,when you turn the knob to lite does it click,check to see if any spark is coming to ignite the gas
May 14, 2011 | Kitchen Ranges
Goodman gms80903bna light blinks once fan runs all the time,
I believe this code is ignition failure.
Turn power off and after 20 seconds turn power on with thermostat calling for heat. Vent blower should come on first. After a bit igniter should lite up. You should hear click noise of gas valve open up. If igniter does lite and you hear click noise, flame should come on for a few seconds minimum. If igniter doesn't lite and you hear click noise from gas valve, igniter is bad. If flame lites and then goes out, flame sensor probably needs cleaned. Both igniter and flame sensor are in metal plate under burners. Igniter has 2 wire going to it and flame sensor has one wire. If you think it is flame sensor you can remove with taking it out with 1 1/4" hex screw. Flame sensor will have white film on it if it needs cleaned, clean with steel wool or a dollar bill. If it isn't weither of these it is gas valve or circuit board.
Jan 27, 2011 | Goodman Heating & Cooling
Ignition problem with furnace
hi igniter could be in the wrong postion or its not heating up all the way down or its got a crack in it
Jan 22, 2010 | Heating & Cooling
Electronic ignition tries to lite, clicks 5 times, then goes POOF
Gas burners go "poof" when they have too much gas in the area upon lighting. This is normally due to the ignition source not being close enough to the initial source of gas. This is normaally corrected by ensure the main burner is clean so that it distributes the gas correctly and having the ignition source at proper strength and location. I would have to have good schematics of your heater to be more specific. I hope this helps.
Sep 09, 2009 | RTO Atwood Water Heater - 6 Gal LP
GE Gas Kitchen sealed burner
I unplugged the wires from each end and re-attached the wires. Stove working great, no more clicking.
Dec 29, 2008 | GE Kitchen Ranges
Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
42 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
