Question about Hayward H Series Electronic Ignition 250,000 Btu Pool Heater H250ped2
I have an h250 heater for in ground pool. When I set the temp it ignites for about 5 seconds then shuts off???
  • 5,568 Answers
That brief delay is likely the window allowed to heat the thermocouple and it is probably defective. After that delay expires, it shuts down for safety to avoid unlit gas from escaping. If the TC is bad, the controller doesn't know if the gas flame ignited or not.
Posted on May 27, 2011
  • pccmyoung197 May 27, 2011
    How do I change it
  • Steve Allison
    Steve Allison May 27, 2011
    Since I have not had the need to do this on a pool heater, the internals aren't known to me but I'll try to give you some guidance. Thermocouples in gas heater & water heaters are rod-like devices with a closed end and what appears to be a thick wire attached to the other end. This is actually a tube containing one or two wires. If only a single wire, then the metal housing is acting as the second. These are carrying a very small voltage (to small to measure with a standard meter) that increases as the temperature rises. They terminate at a pressure regulator which may be combined with a controller or be separated. The tube on those other devices is attached to the regulator/controller and the gas flow is kept alive as long as the thermocouple is producing this small voltage. If the TC fails or is not positioned in the burner flame correctly, the regulator will shut down the gas flow. You can see several at the following link, just keep in mind they are sold coiled and then straightened during installation.
    http://www.nextag.com/gas-heater-thermoc...
What does lo mean on my h250 hayward pool heater
LO standss for limit open. the most common cause is lack of adequate water flow through heater. other causes are high temp limits.
Jun 10, 2014 | Hayward H Series Pool & Spa Heater 400k...
Hayward h250 ed2 failure error code IF
ignition failure check gas source if ok check ignitor
Aug 03, 2012 | Hayward H-series Electronic Gas Pool...
Haward H250 dual therm, heater lights then shuts off after 5 to 10 seconds,even with pressure switch bypassed
it sounds like a flame sensor.its located in lower end of burner box,remove it and clean with fine steel wool or emory cloth.
Sep 02, 2009 | Hayward Pool Products HAYWARD H-Series In...
H250 inground pool heater turns on 5 seconds shuts off flsahing 1f
This is a code for ignition falure. If you are getting a pilot then it means your Ignition module is not sensing the flame and shuting the gas down. This could be pilot wire burnt and grounding or a pilot flame not reaching the sensor or a bad ignition module. This is the expensive part so look into the other things first. Good luck.
Jun 26, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Hayward H250 FDP Pool heater won't stay lite
sounds like a flame sensor.remove ignitor assembly and clean with fine emory cloth or steel wool.when properly cleaned it should feel smooth for entire length of sensor
Jun 20, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Hayward h250, wont heat
Sounds like it could be the flame sensor.
Apr 04, 2009 | Hayward H Series Electronic Ignition...
Hayward H Series Electronic Ignition 250,000 Btu Pool Heater  H250ped2 Logo
314 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
