Question about Kenneth Cole KC1662 Watch
Kc4733 need to know how to set the time. - Kenneth Cole KC1662 Watch
My watch is turned on, but I need to set the time and don’t know how!
Setting the Time Manually
  1. Hold the touchscreen to view the menu.
  2. Select > Manual.
  3. Select or to adjust the time of day and date.
  4. Select to confirm each setting.
https://www8.garmin.com/manuals/webhelp/vivosmart/EN-US/GUID-4503FF46-4FFC-493A-BCBD-C2102F2A5AAE.html
Mar 14, 2018 | The Watches
I need to know how to set my skmei watch
I need to change date and time for skmei 1065 pls help me ;)
May 07, 2012 | Watches
My On Time Atomic watch was shipped 1 hour ahead. How do I get it on the correct time?
You need to set the correct timezone. Your watch doesn't know where it is geographically so you need to set it manually.
May 22, 2011 | Watches
Hi i have just now received a new watch and i want to know how to set analog time. thanks, Abhishek
Hello.
To give a more precise instruction, I would need to know the watch model. But the standard procedure to set analog time would be to pull that little pin on the side of the watch, and than turn it. You should see the handles turn accordingly. Notice that the pin may have two different "heights", one for adjusting time, and one for adjusting the date.
Let me know if that solved it!
Mar 01, 2011 | Watches
I just purchased a Heritage Mint Ltd Timepiece Quartz Regulator wall clock but it chimes two hours slower than the actual time. Need to know how to correct it. There is a red push button on the back of...
I have the same clock. Here's what I did to re-set it after changing batteries: After replacing batteries, use the turn dial to set the correct time. Press the RED button 6 times, wait for it to go through that series of chimes, then press the button again to set the time.
Example: Press RED button 6 times. Wait for it to chime. Press RED button the correct number of times for the hour to be set. For 5:00, press the button 5 times, etc.
I lost the directions to my clock, and I am posting this from memory and also just had to re-set mine and it works OK now.
Hope this helps!
Feb 07, 2011 | Watches
Need to know how to set the time on my watch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all RELIC watch manuals.Rate me, please
Mar 27, 2010 | Watches
I need to know how to set the time on a g shock watch G-314RL the digital display at the back is the right time but i'm wanting to know how to get the hands to show the right time aswell.
push bottom left button until you see H-SET use right hand buttons to go back or forward (finger will ache like hell)once done push bottom left once more to go back to date. good luck
Dec 01, 2009 | Casio Watches
Setting the time
There are two positions for the setting crown all the way out is to set time,one click out to set date.To set the date you must first set the time by moving the hands around clockwise until you see the date change(midnight) then continue around to the correct time.Then push crown in on click and set the date
Sep 23, 2007 | Rolex Daytona 116520 Wrist Watch
Setting analog time
go to; http://world.casio.com/wat/download/en/manual/ and enter the module number code on the back of your watch - hopefully will tell you what you need to know. Hope this helps :)
Mar 13, 2007 | Casio AW80-1AV Wrist Watch
Kenneth Cole KC1662 Watch Logo
63 people viewed this question
Top Kenneth Cole Watches Experts
Ansel Alberto
Ansel Alberto
Robby Otts
Robby Otts
Level 1 Expert
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
