Question about Watches
It's the same gasket from the wacht I open the wacht and when I tried to put back looks bigger and don;t fit
  • 1,555 Answers
Sorry but these gaskets are made of such material which would fit only once and once they are opened. You need to replace them with a new one just like oil seals in automobiles. gaskets are made to secure the watch from water. Once opened they would loose their firmness, hence they are made to be replaced once opened.
Posted on May 27, 2011
How do I remove the back cover of a Fossil JR-8096 (Big Tic) wristwatch?
when you look at the back are there three small rectangular indents evenly spaced on the edge on the back? If so you'll need a special tool for opening waterproof watches. the tool adjusts to fit the three indents then press down as you turn counterclockwise. you can find the tool on amazon.com or your local jewelry store. make sure the gasket is in place and not damaged before screwing the back on.
here is a link to the tool
http://www.amazon.com/Pavilion-Professional-Waterproof-Adjustments-Caseback/dp/B000K3SK0Y
Jul 31, 2012 | Fossil JR8096 Wrist Watch
Can the plastic band be opened? It won't fit over
you can ask for the instruction from the authorized retailer of your watch even that you don't have any proof that you don't purchase it to them. being the dealer of the watch brand it is their responsibility to assist all customers that need to know everything about the watch they selling.. now don't hesitate to ask them..
Jul 13, 2011 | Anne Klein 10-9119WTSV Watch
How do I change the battery in my Casio F-105
When I didn't see an answer, I tried it anyway since I already had the battery and little to lose. Undo the 4 small screws holding the back on (careful - don't drop them). Be careful to keep the small rubber gasket around the edge in its grooves. Do not take the workings out of the watch. There is a small silver arm running across the back over to a cream colored plastic piece with 3 grooves in it. Pieces of the arm are in the outer 2 grooves. Use something small to pry open the arm using the middle groove . Peel it back just a little and replace the battery. The watch should now be working. Snap the arm back in place, be sure the gasket is in place, put the back on,
and screw in the screws. Simple when it works.
Jun 19, 2011 | Casio Watches
How do I open the back of the Acqua Indiglo watch so I can change the CR2016 battery?
Your watch has a snap-fit case; the back is simply pressed back into position with firm pressure. The problem is that modern snap-fit case backs are often very tightly fitted to increase their water-resistance--they're tough to get off, and even tougher to push back into position. I would not be surprised if you will ultimately need a jeweler's case press to get the back of this watch back into place (more on this later).
A snap-fit case back often has a small (very small) raised section at one spot of the rim; this is so you can insert a tool called a case knife and pop the back off. Many Timex watches have a small triangle / pointer etched into the case back to suggest where you should fit a case knife to pop off the watch. If you don't see that small raised section or a marker (Aqua is a discount brand of Timex), you'll need to choose a location to wiggle the blade of your case knife under the edge and gently apply leverage from there--it's usually easiest by one of the watch lugs, as opposed to near the watch crown. If you don't have a case knife, you can often use a thin (but tough!) knife blade to do the same thing. Remember, though, that applying this much force through a knife blade can distort or take a chunk out of your edge, so be prepared to sacrifice a knife or be prepared to re-sharpen it after this exercise. A screwdriver does not work very well; the blades are typically too narrow to provide good leverage without distorting the case back, and they may even cutt a gouge into the watch body. Avoid using them for this purpose.
If you can't press the back on securely after replacing the battery, you will need to use a case press to complete the job. A case press is just what it sounds like: a device for clamping watch cases back together. It's designed to provide an equal amount of force around the edges of the watch back without putting that same pressure on the watch crystal (which could cause it to crack or break). I'm aware of two basic styles. One style looks vaguely like a big pair of pliers, but with two swiveling plates instead plier jaws. The other style, which I prefer, sits on a table or workbench and uses a lever to push down the top plate. In both cases, nylon jigs are inserted to match the size of your watch.
You can find case knives, case presses, and other watch repair tools at many jewelry supply stores, mail order supply houses like Otto Frei (http://www.ottofrei.com/store/home.php?cat=296 will take you right to the watch repair tools), and on eBay. However, if you're near a Harbor Freight store, they sell a "watch battery changing kit" and jeweler's press for an extremely reasonable price. These aren't the ultra-high quality tools that a professional jeweler would use, but they'll be perfectly fine for changing the occasional battery for many years. I've probably closed 100+ watches using the inexpensive press I got from there.
If you can't close the watch case with your bare hands and don't have access to a case press, your safest bet may be to go to a jewelry store or jewelry counter in a department store and ask if they could close the back for you with the proper tool. You may have to tip them a few dollars, but that is still far cheaper than the cost of replacing a broken watch crystal.
May 29, 2011 | Watches
CANNOT GET BACK OPEN TO REPLACE BATTERY
The back of your watch is attached in one of two ways. Look at the watch back. If it's smooth all around the circumference of the back, you have a snap-fit back. If, however, you see little notches cut into the edges--if they were extended, it would make the back look like a pizza that's been cut into slices--then you have a back that screws on and off. Pictures I've seen of your specific watch suggest to me that you have a snap-fit case back, though I'll include instructions about a screw-on back, just in case I'm wrong.
A snap-fit case back often has a small (very small) raised section at one spot of the rim; this is so you can insert a tool called a case knife and pop the back off. If you don't see that small raised section, you'll need to wiggle the blade of your case knife under the edge and gently apply leverage from there--it's usually easiest by one of the watch lugs, as opposed to near the watch crown. If you don't have a case knife, you can often use a thin (but tough!) knife blade to do the same thing. Remember, though, that applying this much force through a knife blade can distort or take a chunk out of your edge, so be prepared to sacrifice a knife or be prepared to re-sharpen it after this exercise. A screwdriver does not work very well; the blades are typically too narrow to provide good leverage without distorting the case back, and they may even gouge into the watch body. Avoid using them for this purpose. To increase the water resistance of watches, modern snap-fit case backs are often very tightly fitted--they're tough to get off, and even tougher to push back into position. I would not be surprised if you would need a jeweler's press to get the back of this watch back into position.
If, on the other hand, you have a case back with notches in it, you will need to unscrew the back of the watch. You'll need a special wrench to do this. There are lots of makers and models from a basic $5 "watch crab" to a $100 workbench-mounted device that works on all kinds of watches, including Rolexes. Again, because screw backs are usually tightly fastened to increase water resistance, simply using a pair of needle-nose pliers in the ridges probably won't work. Nor will using a screwdriver in one notch--these backs are designed to move when equal pressure is applied around the edges, and applying force in one area only locks things up. Under no circumstances try to pry off the back if you have a screw back -- this will damage the threads, and you'll probably never be able to get the watch back together again.
You can find case knives and case wrenches at many jewelry supply stores, mail order supply houses like Otto Frei (http://www.ottofrei.com/store/home.php?cat=296 will take you right to the watch repair tools), and on eBay. However, if you're near a Harbor Freight store, they sell a "watch battery changing kit" and jeweler's press for a pretty reasonable price. These aren't the ultra-high quality tools that a professional jeweler would use, but they'll be perfectly fine for changing the occasional battery for many years. I've probably closed 100+ watches using the inexpensive press I got from there.
How to open
The back of your watch is attached in one of two ways. Look at the watch back. If it's smooth all around the circumference of the back, you have a snap-fit back. If, however, you see little notches cut into the edges--if they were extended, it would make the back look like a pizza that's been cut into slices--then you have a back that screws on and off. Pictures I've seen of your specific watch suggest to me that you have a snap-fit case back, though I'll include instructions about a screw-on back just in case I'm wrong.
A snap-fit case back often has a small (very small) raised section at one spot of the rim; this is so you can insert a tool called a case knife and pop the back off. If you don't see that small raised section, you'll need to wiggle the blade of your case knife under the edge and gently apply leverage from there--it's usually easiest by one of the watch lugs, as opposed to near the watch crown. If you don't have a case knife, you can often use a thin (but tough!) knife blade to do the same thing. Remember, though, that applying this much force through a knife blade can distort or take a chunk out of your edge, so be prepared to sacrifice a knife or be prepared to re-sharpen it after this exercise. A screwdriver does not work very well; the blades are typically too narrow to provide good leverage without distorting the case back, and they may even cutt a gouge into the watch body. Avoid using them for this purpose. To increase the water resistance of watches, modern snap-fit case backs are often very tightly fitted--they can be tough to get off, but they're even tougher to push back into position. I would not be surprised if you would need a jeweler's press to get the back of this watch back into position.
You can find case knives and case wrenches at many jewelry supply stores, mail order supply houses like Otto Frei (http://www.ottofrei.com/store/home.php?cat=296 will take you right to the watch repair tools), and on eBay. However, if you're near a Harbor Freight store, they sell a "watch battery changing kit" and jeweler's press for an extremely reasonable price. These aren't the ultra-high quality tools that a professional jeweler would use, but they'll be perfectly fine for changing the occasional battery for many years. I've probably closed 100+ watches using the inexpensive press I got from there.
May 29, 2011 | Peugeot 194M Wrist Watch
I have changed the battery but cannot get the back panel fixes on to the watch. Tried pressing hard but the panel doesn't fit
The case-backs on some snap-fit watches are very snug in order to increase the sweat and water resistance of the watch. That means that you may need a case press in order to get the back put in place again.
Before you go heading off for a case press, check a few things first. Look carefully at the case back. On some cases, there's a cut-out for the set stem. Is that properly lined up with the stem? If not, that will prevent that case from closing. Next, look for evidence of a thin neoprene gasket that might be either around the case back or lying between the case and the case back. Is that properly in place? Even a little bit of gasket getting in the way will make it really hard to close the case back.
However, I'm guessing that you need a case vise--or that you'll have to give someone with the proper wrench a few dollars to close up your watch. Putting the watch in a regular vise and squeezing tight is a very fast way to wreck your watch--there's a very high risk of cracking the crystal, deforming the case back, or even putting too much pressure on the interior movement and damaging it. A case press puts pressure only on the outside of the crystal bezel and on the edges of the case back--flexing the parts that need to get flexed, but sparing the rest of the watch from that kind of pressure.
Case closing vises come in two basic flavors. The first, which I prefer, is a little tool that sits on a table. You fit in appropriate nylon collars, put the watch between them, and push down with a lever. The second, which I find doesn't always work, looks more like a set of salad tongs with a strange end (actually, parallel pressure points). With this tool, you also add appropriate inserts, then squeeze the handles together like a pair of scissors. It doesn't exert as much pressure as the table-mounted tool, but it's often enough.
Jewelry supply stores carry these case presses, but if you are near a Harbor Freight hardware, store, they also carry inexpensive versions of both of these case presses for a very reasonable $10-15. However, you can usually find someone to close your watch up for you for even less.
May 15, 2011 | Esprit Watches
What type of battery does the Fossil Ch2473 use? I called Fossil and they could not help me, instead they insisted I pay them $15 to replace the battery and wait 2-4 weeks for shipping. However, I...
The vast majority of Fossil analog wristwatches take either a #377 or #379 watch battery. The #379, being slightly smaller, is somewhat more commonly found in women's watches than in men's watches, but I have seen both types used in men's and women's watches alike. However, the Fossil CH2473 includes chronograph functions, which means that you can have multiple motors inside the watch running simultaneously. As a result, it's possible that this watch will require a different / bigger bigger. However, if it's not one of these batteries, or even if it takes a 3-volt lithium battery instead of a 1.5 volt watch battery, it will still be something pretty mundane.
In general, common batteries like the type I expect you'll find inside your watch are commonly found at many drug stores, jewelry store counters at places like Walmart and Target, and even at some dollar stores. Be aware that cheap dollar store batteries are usually alkaline, not silver oxide, versions of the same size battery. Alkaline batteries may work perfectly well in many watches, but they have a somewhat different energy performance curve over time, and, in general, they won't last quite as long as a comparable silver oxide battery. In addition, for reasons I've never been able to figure out, some of the Fossil watches that I've serviced would not function with an alkaline battery--but would work fine when I put in a silver oxide battery of the same size and voltage. I have not been able to see a pattern to predict when this will and will not occur. Lithium batteries, whether "brand name" or generic, should have the same performance curve.
If you do open up your watch to change the battery and don't recognize the battery type/code on your battery, don't give up. Watch batteries have different numbering schemes, depending on the manufacturer. Here's a link to a cross-reference chart that will help you "translate" one code into another. I would suggest starting by looking at the #377 line to see if one of those cross-reference codes matches what you have. However, you may need to look around the chart to get an exact match:
http://www.watchbatteries.com/custom.aspx,,id,,75
As a final thought, the backs of some Fossil watches are very snugly fitted to their cases. You can generally get them off without too much of a problem, but there's a good chance you may need a jeweler's press to get them to snap back on properly. I've noticed this most with round watch backs; I generally haven't needed a press to close oblong or tonneau-shaped Fossil watches (or some round watches, too). A jeweler's press spreads the pressure evenly around the edges of the watch back and watch case, preventing damaging pressure on the watch crystal, watch movement, and watch back. Clamping the watch in a regular vise to try to press on the back runs a high risk of damaging your watch, and I do not recommend trying that, no matter how frustrated you get. It's much safer (and cheaper, overall) to tip someone with a vise a couple of dollars to close up your watch for you.
May 15, 2011 | Fossil CH2473 Watch for Men
I have a vintage ladies wrist watch by CYMA. There seems to be no lip to catch on for opening the back. Does it unscrew?
If the back of your watch is completely smooth, the odds are that it has a snap-fit case. Screw-back wristwatch cases generally have small indentations in the case back into which you fit a case wrench. Rolexes have an elaborately ridged edge to their case backs and take a special wrench. A few early water-resistant watches have little screws that hold the front and back of the case together, but these are usually quite obvious, and you didn't mention them in your description.
Most "fancy" ladies watches of the 40s, 50s, and 60s, had snap-back cases. To open one of these without damaging the case, I recommend gently working a decent quality case knife into the crack where the case back joins the case and gently levering up. If the case is really snug, you may need to do this in a few places to gradually pry apart the case halves. Often, the best place to do this is at the lugs, because they offer a leveraging point. I don't recommend doing this with a sharp knife blade, as the resistance from the case will probably damage the knife edge, and if the knife slips, it can easily scratch the case. If you don't have a case knife, try using the rounded edge of a butter or table knife. Do not use a flathead screwdriver blade, as the short width of that tool can easily place so much pressure on a small section of the case that it deforms and can never be made to look good again.
May 13, 2011 | Watches
My battery is running dead . Can I have it replaced ?
Yes, the battery for this watch can be replaced. Timex estimates that the battery should last 2-3 years, but that assumes an "average" use of the Indiglo backlight. If you never use the backlight or audible alarms, your batteries would have lasted longer; heavy use of both would have run the battery down more quickly.
If you want to replace the watch battery yourself, you'll need a very fine philips or flathead screwdriver, the new battery, and a bit of patience. It would also be helpful to have a pair of tweezers, but that's not absolutely necessary. If you carefully look on the back of your watch, Timex usually lists the battery type so that you can buy a replacement battery without first opening the watch. If you can't figure out what the numbers mean, take it to a jewelry counter at Target or Walmart, and they should be able to help you decipher it. I don't know which battery this specific watch takes, but many Timex watches use a #1620 or #2016 3v battery. Look for a number like that on your watch back.
To open up the back of the watch, open the strap so that you have good access to the back. If you have a steel band, you might need to slip out one of the adjustment pins to separate the band into halves. Yes, you might be able to take the back off without this step, but it makes it a lot easier.
Place the watch face down onto a soft surface. I like to use a dark towel, so that if I drop one one of the tiny screws you'll be dealing with in a minute, they won't bounce and you can easily find them again.
Use your screwdriver to loose the back of the watch, one screw at a time. I find it very helpful to loosen a screw, then use the tweezers to pick it up out of the hole. These guys are tough to grab with your fingers! Put the screw in a safe place, then carefully remove the back of the watch. A little black neoprene gasket may be stuck to the back or be floating around--don't lose that!
You should be able to see where the battery is kept. On most Timex watches, there's a metal shield covering the watch and completing the power circuit. Using your screwdriver, gently pry the tabs of this shield away from the watch movement, one tab at a time. Try very hard not to snap off any of the little plastic anchors. On a Casio watch I recently serviced, I had to remove the movement from the watch to get at these little tabs; I don't remember ever having to do that with a Timex.
Once the shield is loose or removed, the battery should slide right out. Replace the battery, and gently snap down the metal shield. Turn the watch over to check whether it's working again. If it's not, you may have to push a little "reset" pin on the watch movement to clear the registries. The back of the metal shield usually has instructions on where that little pin is located. If the watch is already working, you won't need to do this.
Closing up the watch is the reverse of what you did to get it open. Make sure the neoprene gasket is back in place--that's what's keeping sweat and water out of the watch--and carefully set the cover back in place. Tighten the screws in an "X" pattern--i.e., top left, then bottom right, then bottom left, then top right. I get all the screws loosely screwed in before tightening them down in earnest. This watch has a plastic case, so you want to tighten the screws snugly, but not over-tighten them so that they strip out the screw hole.
May 10, 2011 | Timex Ironman 30 Lap 53952 Wrist Watch
Watches Logo
117 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
