Question about Price Pfister Plumbing
Price pfister pull out kitchen faucet starting leaking suddenly and profusely at base, from joint segments along handle base, directly under handle and possibly at base of faucet. Understand I need to replace O-rings, at minimum, or possibly cartridge. Don't know age of product. Was in ktichen already when I bought house 3 years ago. Immediate problem is that I do not know how to disassemble the faucet as I can't find the set screw anywhere on fixture -- front, back, side. Could it be under the price pfister label on the underside of the handle? It's not a paper label, though. Or does this disassemble differently
  • 3,053 Answers
Most likely it is under the label , it is normally put on with light adhesive. That is where the set screw is most cases. As far as leak goes, your on right track with 0 rings/gaskets. Be careful however, some time you can just get one at hardware store ( whole unit) already together almost as cheek as repairing this unless it is just a couple 0 rings.
Posted on May 27, 2011
Testimonial: "The set screw is indeed under the label. Thank you. Appreciate the tip to check out hardware stores too. for the whole assembly."
We just installed the Price Pfister Hanover Single Handle faucet in our kitchen. (Series T529). We find that it doesn't have the same pressure as our previous faucet. Is there a reason for this? We have...
Hey,
We have the same problem. Just called Price Pfister with the same question, and she offered to courier replacement parts free of charge. She was much too accomodating. My suspicion is that she gets this question quite regularly. Love to know if anyone has solved this problem as we like the look of the faucet.
Apr 22, 2011 | Price Pfister Hanover Single Handle...
Dripping faucet price pfister kitchen
Very nice kitchen faucet. I like Price Pfister's products. To repair it you will need a phillips screwdriver to remove the handles and crescent wrench to remove the cartridges. If it is dripping then one of the faucet cartridges need to be replaced. Its best to replace both cartridges as inevitably the other one will start to leak after you've replaced the troublesome one. Your local hardware store or plumbing supply store should have a replacement cartridge for this model. Remove one of the cartridges and take it with you to ensure you get the correct part. There is an exploded diagram of your faucet on the Price Pfister site at that shows the part number for the cartridge. Good luck and let me know how it turns out.http://www.pricepfister.com/www/ImageAssets/mirror/model/kitchen/savannah/savf8h6-85/ex-036-01.pdf
Jul 25, 2010 | Price Pfister Savannah Two-Handle Kitchen...
Faucet leaks at base of spray handle when water is turned on. How can I fix this leak?
most of the the pullout sprayers need a rubber washer were it meets the hose chek for cracks and replace.
Oct 31, 2009 | Price Pfister 532-7PCC Marielle Pull-Out...
533-50 kitchen faucet leaks above base mount at pivot body when water is on and the faucet is pivoting to fill other sink.It dribbles out on counter top.Seems not to leak if faucet stays stationary.The...
There are O rings that seal the various body parts of this faucet. I would try turning off the supply lines, removing the handle, and unscrewing the faucet and the housings. Look for O rings that seal each part. Could be a broken, or maybe some foreign material has gotten in the O ring grooves. Best bet would be to replace any O rings and tighten it all back securely. It should not have any Up and Down play, should only swivel side to side. I'm thinking O rings. While there, you can replace the seat seals and springs, so that you preclude any leaks from the faucet itself. Lowes, Home Depot, carry the repair kits for these faucets at a reasonable price. And they usually include the allen wrench and wrench to remove the handle and the body parts. And they are relatively inexpensive. Around 4 to 6 dollars. Its an easy fix.
Sep 27, 2009 | Price Pfister 532-7PCC Marielle Pull-Out...
How do you take apart the price pfister 533 50?
On the under side of the handle is a plastic plug its either red and blue or its a logo about 1/4" dia., remove that and there is a set screw that attaches the handle. Loosen that screw just enough to pull the handle off. Then you can disassemble the faucet for repairs. Price Pfisters have a lifetime warranty, if the cartridge is bad you should contact them for a replacement part.
Sep 16, 2009 | Plumbing
I have a price Pfister Marielle kitchen faucet. The valve body leaks when handle is in off position.
There is an o-ring around the valve body inside the outer shell. This needs replacing -- sometimes you can match these at hardware stores.
Shut water off, remove handle, pull up outer shell, you'll see the o-ring.
More info, let me know.
Charlie
Aug 28, 2009 | Price Pfister Marielle Kitchen Faucet with...
Kitchen Faucet Leak
The stem and washers inside the faucet need to be replaced.
If you Do it yourself the parts typically will cost you less than 20 bucks.
Most plumbers will charge 75 to 100 for this relatively simple Job.
You can order parts directly from the manufacturer, or from a local plumbing supply house.
The faucet may still be under warranty and the parts would be free. Here is ther number for Price pfister.
1-800-PFAUCET (1-800-732-8238)
Aug 23, 2009 | Plumbing
Installed a new price pfister two knob kitchen faucet and the cold faucet turns off backwards. How do I make it shut off in the right direction ? Thanks !
you will have to remove the faucets and turn the base around, that is the only way to make it right you installed them backwards
Jun 28, 2009 | Price Pfister Savannah Two-Handle Kitchen...
Kitchen faucet leaking pull down sprayer spout type
try tightening the nut that attaches the flex line to the pull out spout
May 04, 2009 | Price Pfister J103-BC 100 Series Kitchen...
Plumbing Logo
789 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
TED
Level 1 Expert
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
