Question about LG Washing Machines
LG DIRECT DRIVE 7/3.5KG WASHING MACHINE MANUAL
MNTECH
  • 1543 Answers
SOURCE: WHAT DOES ERROR CODE IE MEAN ON LG DIRECT DRIVE
IE = Inlet Error. Check for plugged screens where hoses screw onto machine (especially the cold side). Other possibilies are kinked hoses, valve shut off where hose goes to washer, or a bad inlet water valve (the part the hose screws onto), or even a bad control board or bad wire to water valve.
Posted on Nov 27, 2009
SOURCE: L.G DIRECT DRIVE 7 WASHER / DRYER U.E ERROR CODE
My machine is doing just the same! It is about the same age as yours. I cannot believe this is it working properly, but the manufacurers are no help.
I am seriously thinking of getting rid of it, and would be loathe to touch an LG again.
Linda
Posted on Oct 08, 2010
SOURCE: LG WM-1280 DD front loading washing machine
Be sure the unit is level, not just stable,with the four feet touching the floor. If the unit is not level the centrifugal force of the spin cycle will be distributed unevenly, causing more pressure to be exerted in one corner then the other. this causes the unit to slighty lift in the opposite corner, thus shaking or vibrating. Many people citing this problem have their washers in an upstairs laundry room. Some of these houses may lack the needed support to sustain these washers without the floor flexing. the quality of the building is a factor.
Posted on Nov 30, 2006
BADBOYJAY
  • 264 Answers
SOURCE: LG Direct Drive WM-16220FD loud vibration during spin cycle
the pump hose is knocking if you can unplug the machine and tilt the machine on its back you can see the hose get a cable tie big one you can cable tie it down that would stop it from moving that's why its knocking if the pump is not on that side then your suspension leg is on its way out meaning you will have to call your local second hand shop to have a look but be for you do have a loo your self save money
Posted on Jan 05, 2008
  • 5 Answers
SOURCE: LG direct drive washing machine
generally when a machine gets noisy in spin cycle it is due to bearings being worn open the door with the machine empty and try lifting the the drum upwards if it moves then it will be the bearings
Posted on Sep 21, 2009
LG front loading washing machine Direct Drive 7 3.5KG Trouble shooting Error OE
go to lg.com, enter your model number and manual will show error codes and fixed for some including OE
Aug 29, 2015 | LG Washing Machines
I need an Operating manual for LG 7kg Direct drive automatic washing machine please
They are freely available from www.lg.com look in support, you will need the model number off the detergent drawer.
Apr 19, 2010 | Washing Machines
What is the AE error code on LG steam direct drive washing machin
the AE code means that there is water in the base I found that the steam heater element in mine was leaking so after a quick repair using silicon and a good clean after drying the water out of the base it now works again
PS I used to be a washing machine repair engineer! I wouldn't suggest that you start opening up your washing machine!!!!
Dec 29, 2009 | LG Washing Machines
Lg wm-14445fds direct drive 8kg washing machine manual
You can get the manual here:
http://uk.lge.com/products/sidemenu/list/homeappliances|washingmachine|steamdirectdrivewashingmachine_PRD|MANU_manu.jhtml
Just curious - what happened when you tried to get in touch with LG? Also, did you call, email, what?
Aug 07, 2008 | LG WM-2277HW Front Load Washer
Washing Machine
http://us.lge.com/products/category/list/home%20appliances_laundry_washers.jhtml This link will take you to LG Products site for washers. Click on the model you have, then on the far side you will see owners manual and that should give you the information you should be looking for. Good Luck!!! Jim
Sep 07, 2007 | Washing Machines
Washing Machines Logo
623 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
