Question about Hoover Vacuums
I have a Nanolite that I purchased at a Walmart store last July and when you plug it in it won't start. I think there is something wrong with the cord that connects near the bottom of the vacuum. What should I do?
    Genius:
  • 1,126 Answers
The cord probaly is the problem,it needs to be taken apart and have a new cord install, and also while it is aprt check the switch.
Posted on May 27, 2011
Where can I purchase a replacement belt for this vacuum Many thanks for an answer Bob C.
Your best bet is to visit a vacuum cleaner repair store for parts such as bags, belts, etc. Maybe u can deal directly with the manufacturer but if you do I think they will just refer you to one of their "authorized factory Repair centers."
Aug 24, 2015 | Vacuums
Honeywell air purifier won't turn on
Hello, this is Ava with Think Crucial.
You may check to make sure that the power cord is correctly connected to the outlet. Test the outlet is functioning properly using another appliance or lamp. Also, check the fuse or circuit breaker. The outlet may be overloaded if other appliances are also in use. Establish and correct the cause of the overload. If none of these works, then there is something wrong with your purifier unit and contact the store where you purchase it or Honeywell for replacement. It is advised not attempt to repair the unit yourself.
You can purchase a wide variety of high-quality Honeywell replacement parts for your Honeywell air purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=honeywell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Apr 23, 2014 | Honeywell UV HEPA Clean Antibacterial Air...
I have Kirby sentria that shuts off while using the rug attachment and won't start until I change to the hose attachment. I have had it in Kirby repair store 5 times, cord replaced. Took it back t
power switch faulty, slow speed terminal inside switch is burnt,hence
intermittent fault, hose uses second speed different lever inside switch
Oct 12, 2012 | Kirby Vacuums
Motor making strange noise. How do you take apart a dirt devil featherlite bagged vacuum cleaner down to the motor. I can't get the red cover off the vacuum.
With most vacuums it's not necessary to completely dissassemble to the motor. Most rattles are either something stuck/jammed in, around the wheels and intake area. The rattle, if it's a knocking can also be the internal broken rod of the roller. Rollers can be purchased at hardware stores. Even Walmart and Target carry many models. There are screws in the back and front and guide tabs that the housing cover slips into in the front to remove the top cover as a last resort.
Try cleaning maintence 1st.
1) Unplug
2) Flip over and remove screws on the belt and roller face. Remove face-expose belt &brushes.
3) Slide brush out of grooves. If the belt makes you nervous, slide a large screw driver through it's loop to hold in place while you clean the roller.
4) See if the belt is in good condition free of cracks or tears. If it needs replacing, it slips over the motor spindle for simple change outs. The belt and roller part number should be listed on the vacuum if you look atround. Usually on a metallic plate installed during manufacturing.
You can take a 4' length of old garden hose and listen through it to the outside of the motor while running to see for sure if the noise IS coming from the motor, or infact it's the roller. I hope this helps you.
Sep 22, 2011 | Vacuums
My S5211 is 5 months old and was running perfectly. Last weekend I took it out to vacuum house but it would not start. I checked the fuse in the plug but it was fine. I replaced the dustbag but still it...
if you put everything back in place properly it should be working,check dust bag properly seated, and cover reseated, still not working do as planed, take it backto the shop, hope this helps
Sep 01, 2011 | Miele S5211 Deep Black Vacuum Cleaner...
My Hoover nanolite bagless vacuum has no suction.
12/14/2013 ... just fixed my loss of suction on my Nano Lite by making sure the hose was in the locked position (top of unit where hose does not come off for attachments, look for locked and unlocked symbols - make sure in locked position.
May 22, 2011 | Hoover Vacuums
We have the GE sensor microwave WES1358DN1WW. It was made in 5/2009 & bought in July of 2010 brand new. it worked perfect til last week. i put something in it & it started to make a loud...
It's really a pain to open them up but if your feeling up to it, it sounds like the magnatron has vibrated loose and probably disconnected a wire. Disassemble and take a pic if u need help. It's pretty straight forward once inside
Apr 02, 2017 | Vacuums
Dust is blowing out the front vent.
If dirt and dust are blowing out anywhere that they shouldn't be, it's a sure sign that something's plugged farther on up the line. You'll need to disassemble the unit and clear the clog before anything will go through to the dirt cup. Also, as long as you're going to be taking it apart, check all the filters. This is a notoriously neglected part of bagless vacuums, and a very large part of why they start to lose the initial level of vacuum power. Clean the ones you can clean, replace the ones you can't. Walmart and Meijer's are a couple of places where you might find replacements.
Apr 20, 2011 | Dirt Devil Featherlite Bagless Vacuum...
Vacuums Logo
27 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
