Question about InFocus Proxima UltraLight LS1 Multimedia Projector
Proxima Utralight LS1 does not display what is connected to it. The bulb is good, the projector displays its own menu, but it does not display anything from any computer connected to it.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 88 Answers
Make sure you're on the correct source on the projector. now i'm not sure if you're using a laptop, if you are, then you're gonna have to press FN and F5 (depending what type of laptop you have, sometimes it's F8) buttons on your laptop. this activates the computer port of your laptop.
Posted on May 27, 2011
  • mjrhyne May 28, 2011
    Sorry, I guess I should have specified that I have 20 years of computer repair and service experience, and 10 years working with audiovisual equipment. Now, other than the obvious, is there a circuit board in the back of the unit that could need replacing? Or swollen capacitors rendering it unusable? Can that part be replaced? Thanks.
Reset lamp timer on proxima dp9250+
1,Turn the projector on,press the Menu botton
2,Press the Left ,Right,Up or Down to find the "lamp usage" and the reset option.
3,select "Lamp replacement counter Reset ?"
4,select "Yes"
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color
wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Jul 09, 2014 | ASK Proxima Replacement Lamp Projector...
My ask m3 projector powers on but doesnot display anything. No light comes out of the bulb. Is it possible that the projector's bulb hours are finished?
Very possible. Replacement lamp:
http://www.shopvsc.com/Ask-Replacement-Projector-Lamps-s/135549.htm?searching=Y&sort=7&cat=135549&show=50&page=1&f-M2+=135515
Oct 03, 2010 | ASK Proxima ASK M3 projector lamp...
Bought a new Dell Vostro laptop with Windows 7. Does not pick up a Proxima dp2000x projecto. Any suggestions
the resolution doesn't match. the dp2000x is a relatively old projector that can't handle the laptop's signal.
Feb 08, 2010 | InFocus Proxima UltraLight LS1 Multimedia...
Proxima ls 1 fan is to loud
the bearings are going. time to replace it before it stops working and the projector overheats. av solutions in ny might be able to get it. they're an infocus service center. www.avsolutionsny.com
Jan 13, 2010 | InFocus Proxima UltraLight LS1 Multimedia...
I have hooked up the input jacks but the screen only shows the menu but no picture of channels
what are you hooking into it? there's no tuner in this unit. if it's just straight video, reset the settings in the menu to factory default and select the video input.
Dec 11, 2009 | InFocus Proxima UltraLight LS1 Multimedia...
Proxima dp100x projector shows red background. Is
the colorwheel or the dmd chip may be bad. but first, go into the menu under service and reset the settings to factory default.
Aug 21, 2009 | InFocus Proxima DP1000X Multimedia...
Have an old proxima, adjusted the focus and still the display is a little fuzz Is it new bulb time?
Phoned the Infocus people and they said, the len was out of place. Len repair in this case would be costly. Could buy a newer projection unit for the price of the repair with great amount of lumens than the current proxima unit. Yet if anyone, knows of a cheap fix, please post it.
May 07, 2009 | InFocus Proxima UltraLight LS1 Multimedia...
Hy, having problem with to conect projektor to the computer Anybody can help
The projector should have a cable similar to the monitor cable that would normally be hooked into the computer. The cables work the same and the one coming from the projector will use the same port as the normal monitor cable. Make sure that there is a good connection on both ends -sometimes one or the other get moved and the connection is lost.
Once the cables are hooked up, the projector should be turned on. Normally the projector will soon begin a startup routine and will cause an image to be shown on the screen. You can focus the image during that time.
After the image goes away you should be able to display whatever you want from your computer's software.
Normal problems in doing this are: leaving the lens cap on the projector, having a burned out bulb - once the power is turned on for the projector, it should cause the bulb to come on. Some models have a power on switch and a display on switch that must both be pushed to make the bulb light up.
Hope this helps.
Dec 26, 2008 | ASK Proxima C160 Multimedia Projector
Display shows dark shadow around the center
Have you checked your lens assembly? maybe loose, or the bulb may not be seated correctly giving on out of focus image.
Feb 01, 2008 | ASK Proxima C180 Multimedia Projector
Screen has vertical lines in the display
either the power supply or the main board (eca).
Sep 21, 2006 | ASK Proxima Proxima DP2000X Multimedia...
InFocus Proxima UltraLight LS1 Multimedia Projector Logo
118 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
