Question about Fedders A1B12W7B Air Conditioner
How do i open the my Fedders A1B12W7B to clean the filter? can i buy a replacement filter?
My Mom has a Fedders Window Air Conditioner Model # A7T12F2A Serial # CP961286 075E
Switch off, press reset and switch back on. Keep reset pressed for 10 secs. Check the bit behind the filter is also clean and check the drain isn't clogged.
May 16, 2012 | Fedders Heating & Cooling
Clean filter light on my Fedders model sfpeb08f2b is on. I have cleaned the filter in the back, is there another filter that I am missing? The light will not go off...
I had the same problem, remove the filter and wash with water and some soap, rinse well and dry well.
Place it again and turn the unit on, if the light does not turn off, unplug the unit and wait about 10 seconds, reconnect the unit and should disappear the red light.
This worked for me, hope it works for you ...
Good luck ...
Jul 05, 2011 | Fedders SFPEB08F2B Air Conditioner
I have a Fedders dehumidifer model # A70145D2A-A-R. It is a few years old and it's worked pretty great but now it just runs continuously and no moisture is gathered. What can I do to fix it? I was...
You'd be hard pressed to find a Fedders like yours. They've been out of business for several years.
There are several basic things that can cause what you described.
1. The humidity extraction level is improperly set. Lower the level to 32-35%
2. A dirty of clogged air intake filter. Turn the unit OFF unplug it and remove the filter for cleaning.
3. Obstructed air space. A dehumidifier requires a minimum of 12" clear air space around the entire
unit.
4. The ambient air temperature at floor level is between 40 & 60 Degrees F. Dehumidifiers do not work well in that temperature (Except low temp models). This especially true in a basement application, because the air temperature at floor level is colder than say, chest level. Raising the unit up off the floor onto a sturdy table, cabinet top, etc, that can handle the weight of the unit, plus a full tank of water, will normally resolve that problem.
5. The cooling coils are dirty and need to be cleaned.
Critical problems:
1 The humidity sensor has failed an needs to be replaced.
2.The compressor is low on refrigerant gas and needs to be recharged.
Sometimes the repairs (Time spent finding, the Parts & labor), if necessary, can cost almost as much or as much as a new unit, which would have a full warranty.
Hope this helped you troubleshoot the basic and solvable problems and you won't need to make any critical repairs. Please let me know. Thanks.
Jun 16, 2011 | Fedders R6DH45X Dehumidifier
I have a fedders ac unit that does not put out cold air only for a couple of minutes. model # A2Q06F2BG-D can i add freon
Hello, you can add freon by installing a piercing valve on the low side of the system. Before adding freon I would check and make sure the air filter and both coils are clean. If everything is clean then most likey the unit has a leak and is low on freon.
May 26, 2011 | Fedders D Chassis AED24E7E Air Conditioner
My fedders ac window unit turns on and gets cold for ten minutes then the compressor turns off and dont turn on until i turn it off for about 20 minutes
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
The outdoor coil is plugged with ****....
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 03, 2010 | Fedders D Chassis A6D24E7A Air Conditioner
Fedders a3qo5f2agaa air smells urine (pissy)like? makes me cough. what to do? thanks
Clean/change the filters and clean the coil with a brush and soap. Do this gentle and avoid damaging the fins of the coil.
Aug 19, 2010 | Fedders Heating & Cooling
I have this ac unit, clean filter light on ??
The filter light comes on buy hours of run time, it's just a reminder to check /clean the filter. There should be a filter reset button on the thermostat to rest the hours counter and the light will go off. If the t-stat doesn't have a button for that, it's somthing like push UP & DOWN at the same time. need t-stat model and serial number to get info, If the installers left the manual for it, look in the index under filter or maintenence. if you're not able to locate the manual, let me know and we can go from there.
Sep 14, 2009 | Fedders SFPEB08F2A Air Conditioner
How do you clean the air filter?
Hi, in most small A.C, remove filter, either from side or bottom, and you wash with water until clean, you could use a little detergent, let it drain for a while, then put back. you can also replace them after a while, check your appliance store for new filters. good luck
Aug 03, 2009 | Fedders A6Q10F2B Q Chassis Room Air...
Problem with reset switch on fedders split unit
This indicates a fault within the unit. Call a service technician and have the system repaired.
I take the time to help you with your problem, so please rate me.
Thankyou Mat
May 18, 2009 | Fedders C36ACD1VF Split System Air...
Heat doesn't work on ac unit
u have to be more specific. is it gas or electric. If electric check breaker first. Gas check thermocouple
Apr 01, 2009 | Fedders Y Chassis AEY12F7E Air Conditioner
Fedders A1B12W7B Air Conditioner Logo
43 people viewed this question
Top Fedders Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Mike
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
