Question about Pride Mobility Products Revo 3Wheel Travel Mobility Scooter Red
My compass rover beeps at me 5 times and the manual gives me no answers. battery is at full charge yet it still won't work.... Please help?
2 Suggested Answers
wcdoc1953
  • 280 Answers
SOURCE: when I turn the key
The beep code will begin with 10 very fast beeps, followed by 5 slower beeps. The 5 slower beeps is your actual code. The beep code 5 is a brake fault.
The scooter may be in freewheel mode or there may be a short in the brake.
Make sure the scooter is in drive mode with the rear brake lever in the correct position. If that does not clear the fault you need to check the electromagnetic brake.
To check the brake you need a digital voltmeter. The brake should read 30 to 65 ohms when you read across the pins. You need to measure the resistance at each successive point on the harness because there are 5 connectors. While you are inspecting these plugs, check for corrosion, loose pins, broken wires, and pins not making good contact. Disassemble the front and rear halves of the scooter when you do this.
If all the resistance checks are good up to the controller plug for the brake, you have a bad controller. With that being said, I usually see a bad connection at the multiple points in-between. Sometimes the wires for the brake will melt at the connector at the controller.
Inspect these areas visually, removing the rear cover of the brake/motor/transaxle and the controller. An experienced tech should charge you under 1 hour labor for the diagnosis. You may be able to save some money by checking the obvious areas for unplugged or bad connections first.
The brake will cost about $250, the interface wiring and connectors about $50 and the controller is about $500. For this reason, you should invest in a good tech to diagnose the problem first, before proceeding with any hit and miss do it yourself repairs.
Including a second visit to install the new parts, labor cost should not exceed 2 hours total.
This is a very popular model so you should be able to find an experienced tech in your area.
Posted on Dec 23, 2010
Testimonial: "Awesome detailed info on how to fis/diagnose the problem."
Why battery and engine light on 2009 land rover lr2
Most likely a bad battery. The batteries in the Land Rovers, as well as other batteries, are lasting about three to four years so if yours is now 5 years old, it's probably time for a replacement. Have you tried slow charging it to full capacity or having someone jump starting you to see if the veghicle will crank over? If that works, I'd look at having the battery replaced. I made a lot of short trips with a new 2013 LR4 and the Battery Low warning came on and I had to slow charge the battery overnight to bring it up to correct voltage. The difference between a good and bad battery is only a bit more than a half volt when fully charged,(12.6 or 12.7 volts full vs 12.00 less than 25% charged and 11.9 dead) so if your battery when charged doesn't show above about 12.5 volts it's time for a replacement.
Jul 25, 2014 | 2012 Land Rover LR2 Base 4dr SUV 3.2L...
Mobility scooter
Check the freewheel lever is not engaged.
Jun 03, 2017 | Health & Beauty
Battery shows fully charged and the horn beeps but it won't move.
I have the same problem in mine.. But the beep is continous. Mine is a fortress 2000 AT. anybody knows what's the trouble on this one?
Jan 12, 2013 | Electric Mobility Health & Beauty
2003 range rover hse new battery won't hold charge and key is stuck in ignition
was the key stuck in the ignition before you change the battery? Is it the right key or it a fresh cut key
Dec 27, 2012 | 2003 Land Rover Range Rover
Flat battery
suspect slack fan belt, therefore not charging battery.
Jun 24, 2012 | 2007 Land Rover Range Rover Sport...
My 2008 Land Rover LR2 HSE key fob won't
So did you fix your problem? I'm now having the same exact problem. The key simply doesn't work; HOWEVER, I know the key is not dead. I also have a 2008 LR2 and there is no "Battery" in the key fob. I compained countless times to the dealer that the key would just stop unlocking doors on me. They told me the battery charges when it is in the ignition but there is no battery to replace. They recommeded I rotate my main and spare key to make sure they're both always charged. Well, I do, and same problem.
This problem started one year ago and I complained that I should not have to spend $500 for them to replace the key... because a 3-year-old key SHOULD NOT be dying. And not to mention, a large chunk of that $500 is for them to "program" the key.
I have an appointment on Friday at a certified Land Rover repair shop but NOT the dealer. The shop I called said the '08 LR2 has "huge key issues." I have had it with Land Rover and their lack of interest in helping deal with the problem, which I might add is clearly THEIR problem, if so many are having similar problems.
I will post an update after my appointment Friday.
May 08, 2012 | 2008 Land Rover LR2
Charging batteries
at a minimum your batteries need to be charged for 12 hrs a day for the first month if not they will not build the capacity and will dwindle and die for example it is at only 25% capacity it says it fully charged but will die quickly this happens because it is charged to its full capacity but that is only 25% of the batteries true potential resulting in short battery life
Dec 21, 2008 | Golden Technologies Compass Electric...
Pride Mobility Products Revo 3Wheel Travel Mobility Scooter  Red Logo
139 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
