Question about Samsung 250GB HD250HJ SATA II 300 7200rpm 8MB cache HDD Hard Disk Drive oem HD250HJ 250 GB SATA Hard Drive
Windows XP will not pickup my 2nd hard drive (intermittent fault)
Running XP with all updates installed to this date.
I have the OS on my primary hardrive - never had any problems.
I purchased, installed formatted and partitioned a second disc being the HD250HJ many months ago. On SATA port 2.
Depending on the mood of the computer Windows will not detect the drive, it does not appear on my computer, device manager, of disc management.
BIOS detects it every time and will happily run scans which have found no problem.
It powers up fine every time and when it does appear on boot up the data is fine and there are no problems.
I have not found a similar problem posted anywhere.
Your help is appreciated
    Problem Solver:
  • 29 Answers
Most likely it is getting ready to crash, remove your files and replace the HD very quickly.
Rmatheson@wowway.com
Posted on Sep 30, 2008
Inspiron 570
Safest is way to install a removable drive tray such as Welland EZStor ME-751 Trayless HDD Rack 5.25" Bay for 3.5" SATA HDD/SSD - Anti-Shock, Scratch-Proof.
Then you can swap HDD anytime.
You can also install new (now upgrade) Windows 8.1 on a 2nd HDD internally. But sometimes the 2nd OS can damage the first OS if ou are not careful with C: drive letter.
Jan 06, 2014 | Computers & Internet
Multiple OS problem[Primary corrupt]
Windows XP Professional SP2
http://www.microsoft.com/downloads/details.aspx?FamilyId=535D248D-5E10-49B5-B80C-0A0205368124&displaylang=en
The Windows XP startup disk allows computers without a bootable CD-ROM to perform a new installation of the operating system
http://windows.microsoft.com/en-US/windows/help/learn-how-to-install-windows-xp-service-pack-3-sp3
if you have a copy of windows service pack there is a program that allows you add service pack 3 to it so you have a copy of xp sp3
http://www.nliteos.com/changelog.html
if you need more help with this post a reply
hope it helps
May 25, 2012 | Microsoft Windows XP Professional SP2 for...
New larger hard drive can only be detected as Primary Slave
Floydage, some ribbons are different in the orentation of pin#1. try a differnent cable...but you said that you tried that right.? have you tried to make sure you have the latist BIOS. It could be this paticuler drive have a different bios it self...and yes drive's do have chip's and software in them. If nothing ells just load the OS to that drive anyway and than change the drive letters in windows.
Feb 16, 2010 | Computers & Internet
HOW DO YOU INSTALL A SECOND OS ON A SLAVE DRIVE. I AM RUNNING WINDOWS XP HOME EDITION. I WANT TO INSTALL WINDOWS 98 SECOND EDITION ON A SLAVE DRIVE DISC. SOME PROGRAMS I HAVE WILL NOT WORK ON XP.
You cannot install 98 directly on your system slave drive, but there is a way to install it.
1) disconnect your primary drive
2) make your slave drive as primary.
3) install 98
4) Connect your actual primary drive again and start your system
XP records your mac id of your motherboard and 98 does not records, the other way is, you can install both the OPS on your one primary drive by creating different partitions, you will need to full format your drive first.
1) Full format your primary drive.
2) Create partitions.
3) Install 98.
4) Install XP in different drive of your same hard disk
You will be able to see both your OPS when you start your system.
Sep 18, 2009 | Computers & Internet
How to: Dual Boot system with XP & Vista on separate hard drives
If XP where your primary OS this would not be a problem. Since Vista is the Primary you are going to need to get a boot loader that will start before either OS does and use that to choose OS at bootup.
Sep 12, 2009 | Dell Studio XPS Desktop Computer
Dell Vostro 200 desktop with Windows XP is not able to handle two
Vista doesn't generally like to be installed on a hard drive that big. Well, Windows, in general doesn't.
And, from the sounds of it, you didn't install Windows on your new primary 1.5TB drive, you just copied it from the 500GB drive, which won't work.
Here's what you should to, to solve this:
1) Swap out your 1.5TB drive with the 500GB drive again.
2) Swap out your secondard 1.5TB drive, with the new one.
3) Create a partition of 120GB or less on that drive
4) Install Windows on the new partition.
5) Put the other 1.5TB drive back in, as secondary.
Once that's done, you can swap out the new 1.5TB drive with your Windows partition on it, in place of the 500GB drive.
When you boot, Windows may ask you to select which operating system you want, just select Windows Vista, and you should be good to go.
I had a similar issue a few years ago, when I tried to install Windows on a 1TB drive, and couldn't get it to work. Once I partitioned a smaller space, it worked like magic.
Mar 20, 2009 | Dell Vostro 200 Desktop Computer Intel...
Removing partial install of 2nd os
You should be able to do a SYSTEM RESTORE to a point before the XP Pro installation.
Start the machine and start tapping the F8 key until the boot menu is displayed. Use the arrow keys to highlight SAFE MODE and press enter. If you are given a menu to choose which Windows to boot into, choose the Home edition. Windows will load with the minimum drivers. Your screen display will be 640 X 480 and the icons will be large. You will eventually see a window advising you that you are in safe mode, click OK or NO. Click NO. That should open The System Restore function. Choose to restore the system to an earlier date. A calendar with be displayed. The BOLD dates are the ones that you can restore to. Choose a date that was before the date you tried to install XP Pro. Follow the prompts and the restore process will run and reboot your computer. Following the reboot, the installation will complete and Windows will open.
If you have installed a service packs or updates after the restore date you will need to install them again.
Good Luck! and please let me know how this works out for you.
Jan 16, 2009 | Computers & Internet
Hanging on detection of drive when installing Windows XP
Installing Windows XP on a SATA hard drive is not a straight-forward task as Windows XP does not recognize the SATA drive. In order to install operating systems such as Windows XP on SATA drives, the latest SATA drivers are required.Download SATA drivers for the motherboard from the website and integrate them with the XP installation CD using software such as nLite. SATA drivers can also be installed as third party drivers; you will be prompted during the installation process. Without proper SATA drivers, installing Windows XP on a SATA hard drive is not possible as SATA mode would have to be disabled in the BIOS to continue with the installation.
Installing Windows XP on a Serial ATA hard drive is not an easy task, because the system does not recognize SATA drivers at startup. Windows XP Pro SP2 fares a little better with SATA drivers, but here is what can be done in cases where the driver is not recognized.
Mar 31, 2017 | Excelstor Technology J880 Hard Drive
Install Fedora
If you are using 2 hard drives then install Fedora to the 2nd drive. When you boot up it will ask you which os you wish to boot into. Hope this helps.
Dec 22, 2008 | Microsoft Windows XP Professional
2nd HDD installed as slave but still unloaded with software
Simple, if your hardware is working all OK do this:
AND DO THIS CUZ WINDOWS XP HOME EDITION lacks of the needed administrative tools.
Go to the net and find PARTITION MAGIG or PARTITION MANAGER... download the windows version of any of those and partition the HD with them.
REMEMBER:
1. PARTITION MUST BE LOGICAL, NOT PRIMARY
2. PARTITION MUST BE NTFS (Windows XP version) that you will see in Partition Magic options...
3. If you format from Windows, disk must be intitialized as BASIC type.
if you do this and you suceed the HD will work, if not, it has a problem, either logical or physic.
Good Luck
Mar 10, 2008 | Maxtor Hard Drive
Open Questions:
Samsung 250GB HD250HJ SATA II 300 7200rpm 8MB cache HDD Hard Disk Drive oem HD250HJ 250 GB SATA Hard Drive Logo
131 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
