Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
I have a Hitachi Projection Color TV which is about 4 years old and when I push the on button nothing happens. I tried unplugging it for over 2 hours but nothing happens. What should I do?
  • 1,591 Answers
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on May 27, 2011
On hitachi ultravision when you turn on the power button blinks green and lamp button blinks red. What is wrong?
When was the projection lamp last replaced in this tv?The projection lamp in the tv now is about 1 1/2 or 2 years old and the tv been on and watches like 4 or 5 hours a day?The projection lamp life is over.Require a new projection lamp.
Sep 04, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
My TV is almost 5 years old. Barely used more
Howdy,
Sounds like the TV has lost the VIDEO and only has color. Make sure all the cables are secure and good. 2) Reset the TV by unplugging the TV or any BOX you have attached to TV. Unplug both from a/c for 3-5 minutes, plug back in and turn both on.
If no fix. Go to service Company that is Authorized and get an estimate, possible cost $450.00 +. Too many areas of concern to help you with particulars.
Good Luck, Big Irish.
Dec 02, 2009 | Hitachi 46F500 46" Rear Projection...
Have a hitachi 51f59a rear projection set that has no video in antenna, video 1,2,3,4,5. Have tried dvd and cable. the OSD works and displays on the screen. Have tried unplugging and the G2 screen...
I have owned this model for 4 years now. 2 years ago this same thing happened to me. I think the repair man said the transformer went out and he replaced that. It has happened to me again so I will try and do this myself, and let you know if I succeed. This TV has been terrible, I will never buy hitachi again. If you ever use an hdmi cable the tv does very weird things like changes color or distorts for about 30 secs then goes back to normal. P.O.S.
Oct 20, 2009 | Hitachi Televison & Video
50 inch Hitachi Ultravision LCD Rear Projection Television
Hitachi has had problems with their light engines. Very expensive. Contact Hitachi as they may give you consideration even if this is out of warranty.
Apr 15, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
TV will not turn off with remote or manual have to unplugged
I suspect the unit might need service. If it were only the remote, new batteries would, of course, be in order. But that part about the manual power button being ineffective suggests something else is affecting the set. Sorry.
Sep 27, 2017 | Hitachi 46GX01B 46" Rear Projection...
Hitachi 60UX58B will not turn on
I think there could have been a power surge... ask the repairman if the power supply is blown. :)
Jun 18, 2008 | Hitachi 60UX58B 60" Rear Projection...
Color fades
HELLO. it sound's like you have a cold solder problem.!!! what that mean's is that when the set get hot .!!! it lose's it's contack.!!! you might try going over the chassis .!!! soldering the conteck's.!!! with a low watt. solder gun.!!! not over 40 watt's.!!! and use 40/60 rosin core solder.!!! hope this help's you .!!! "GOOD LUCK"
Mar 14, 2008 | Hitachi 50UX58B 50" Rear Projection...
No picture for 3-4 minutes after start up
Roger,
Could be as simple as a software upgrade if the picture looks okay after it come on... What software version are you currently running?
SOFTWARE VERSION CHECK Step (1) Turn the TV ON. Step (2) Using the TV Remote, Select Antenna C. Step (3) Press the MENU button on the Remote. Step (4) Menu will appear
(Figure 1)
Step (5) Press the Cursor Down button and Highlight SETUP
(Figure 2)
Step (6) Press SELECT on the Remote Control. Setup Menu will appear
(Figure 3)
Step (7) Cursor Down and highlight UPGRADES
(Figure 4)
Step (8) Press the SELECT button on Remote Control. Upgrades Menu will appear
(Figure 5)
Step (9) Read the Software Version
Let me know!
Bill
Dec 12, 2007 | Hitachi 53SDX01B 53" Rear Projection...
Hitachi model 55ux58b
how many times does the light blink?
Dec 10, 2007 | Hitachi 55UX58B 55" Rear Projection...
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
56 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
