Question about Kenmore Dryers
Kenmore 600 electric dryer doesnt heat - Kenmore Dryers
    Problem Solver:
  • 17 Answers
Start by checking the thermal cutoff fuse part #3398671 substitution 279769 for the heater element. Most of the time those will go out before the element does. If these are blowing frequently, then you should check your dryer outlet hose for lint and other blockage. This will also cause your dryer to not dry properly. While out on a service call, I found a packrat's nest inside the dryer vent hose.
One way of checking if its the fuse, is to take a jumper and bypass the fuse, and run juice directly to the heating element. If it works without the fuse, then it's ok. If not then the heater element is bad.
I hope this helps
Posted on May 27, 2011
    Brigadier General:
  • 3,301 Answers
Kenmore 600 series electric dryer runs but wont heat
There are several things that could cause this problem but the most common can be can be checked by following this guide:
Electric Dryer Runs But Dont Heat
Jan 11, 2014 | Kenmore 600 7962 Dryer
Dryer wont heat. cleaned exhaust duct still problem exsists. Model 60 series kenmore gas
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 09, 2011 | Kenmore 600 6965 Electric Dryer
Kenmore 600 series gas dryer not heating
heatman101
Jun 26, 2011 | Kenmore 600 7965 Dryer
Kenmore dryer will not heat up
I couln't bring anything up using the model number you gave, but generally an electric dryer will have heat if the heating element gets the signal from the switches and it is not open.
If everything works beside the heat, then I would make sure that the heat selector switch is operational and if it is then to replace the heater element.
Jun 17, 2011 | Kenmore 600 6963 Electric Dryer
Our kenmore gas dryer is starting but after 1 minute the heat shuts off what could it be
heatman101/,./'
Mar 27, 2011 | Kenmore 600 6965 Electric Dryer
Kenmore 600 Electric dryer won't heat up. I have replaced the Thermostat and Heating Element. No heat. What should I do next.
You could have a timer problem or an electrical problem. Unplug the dryer. Find the wire that connects from timer to heating element. Disconnect it from that terminal and clamp a lead from an ohm meter there. Then test for continuity from that terminal to any other terminal of that timer while turning the dial to various spots. If you cannot get a reading then you have a bad timer.themobilian_859.jpg
The motor is a 120 volt one. The motor runs off neutral and one side of the 30 amp two pole circuit breaker. You might be fooled into thinking you have power to the element but you may not have it.
I have a service manual and more HERE
Bonus tip: Help my dryer won't heat
More here
Thanks for using FixYa
Jan 12, 2011 | Kenmore 600 6965 Electric Dryer
Electric dryer want heat up
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 08, 2010 | Kenmore 600 7962 Dryer
My kenmore 600 gas dryer dont heat up. gas is on electricity its fine it turn on it works fine but just not heats up.
Disconnect the rear vent off the dryer itself and try again. If heat does work the vent tubing is clogged
Oct 06, 2010 | Kenmore 600 6962 Dryer
Kenmore electric dryer, 600 series, runs but does not heat.
check you're thermostats for continuity, they are normally 3 thermostats, reset stats have a button on them please press, if not thermostat its your heating element
Jun 20, 2009 | Dryers
Dryers Logo
197 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
