Question about Kenmore Freezers
Upright freezer 253.24092101. Battery for alarm died. What battery does it use and where does it go? Can't find my manual since I moved. HELP
  • 62 Answers
SOURCE: Kenmore Upright Freezer Model 253-9280810
is it possible the door has not been closed at some point?
If so they can build up with ice in the evaporator which the defrost system cannot handle....Try a manual defrost.
Depending on where the unit is installed high ambient temperature can drop the internal temp enough to set the alarm off though they will still freeze sufficiently
Posted on Jan 06, 2008
22yooper
  • 828 Answers
SOURCE: Freezer won't run
There is no reset switch. There is a thermal overload protector mounted on the compressor. Does the compressor hum and then give a click sound. If so your compressor has failed. If the compressor is cold (Room Temperature) and it does not try to run your thermostat may be bad. If so remove the temperature control and jumper the two main wires that connect to the control. Unit should be unplugged to do this operation. Insulated the wires so they do not contact any metal surface. Plug the freezer back in. If it runs and cools replace the thermostat.
Posted on Jul 06, 2008
larryyb
  • 291 Answers
SOURCE: Kenmore upright freezer alarm sounds constantly
replace the battery in the grill or the hi-voltage control under the unit in the back
Posted on Jul 08, 2009
  • 389 Answers
SOURCE: Temperature Alarm beeping/buzzing Kenmore Freezer 26041
Just incase>>>>
Is your circulating fan working?
It may be slowing down.
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Posted on Apr 21, 2010
Testimonial: "Great advise, unfortunately wife purchased new freezer & this old freezer was removed from home."
  • 6 Answers
SOURCE: My kenmore frostless 16 upright freezer alarms
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Posted on Jun 14, 2010
I have a fridgerdire freeze that has not beem used in a a while. We plugged it in today and I have a power light and a temperture alarm. When I turn the freezer on I hear a buzzer alarm going off and the...
Hi James.
Most Kenmore upright freezers use a backup battery located at the lower part of the appliance. When the battery is low the freezer will beep continuously. If the unit has been off for a long time, and if the unit uses a battery, then the battery may need replacement.
Here a picture of the battery in its housing, located in the lower front part of the freezer.
Feb 19, 2012 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Just bought a used kenmore elite frost feee freezer model 3 253.26072100 with an alarm and in great shape however there is no manual and we do not know how or what the temp settings should be at. We have...
You can view/download the manual at
http://www.managemylife.com/mmh/owner_manuals/8259/KENMORE-ELITE-Upright-Freezer-L0603500
Jul 16, 2011 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Jun 05, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Just incase>>>>
Mar 17, 2010 | Freezers
Jul 02, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer alarm stuck on - can't reset
Hi: Does the freezer have a battery backup for the electronics? A 9v. battery in the grill down below. You won't have to remove the grill but pull a small rectangular panel to expose the battery. High end Kenmore freezers have a battery to back up the alarm. The six you see is actually supposed to be a "b" for battery most likely. L.E.D.'s are tough to tell the difference. Buy an new battery and all will be well. I hope this helps, Jeff
Jun 12, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Low temp alarm goes off on Kenmore upright freezer
The alarm is there for a reason. I wouldn't disconnect it. Maybe the compressor is low on gas. If your thermostat is on extremely low, try moving it up to a less cold position. Look in your owner's manual for recommended settings.
Failing that, get ready to shell out some bucks to the service man!
Mar 19, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore freezer depleting 9 volt batteries, setting off alarm
trojo50,
your defrost elements are not working or the water inlet for the evaporator tray is clogged. That alarm is to let you know something else has triggered it. This could be s imple DYI solution or require a service call. let me know if you are up for the DYI.
randy320sgi
Feb 11, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Flashing power light on Kenmore upright freezer
If the yellow light is flashing it may mean that the 9 volt battery is dead.
On my Kenmore there's a small battery compartment on the bottom right of the unit - under the door.
Aug 10, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore Freezer Alarm
You can take the batteries out that power the alarm system. They are located through a small access panel/door front bottom right of the unit. If you bought the unit at Sears, you should call 1-800-4MYHOME and ask a technician if a replacement manual is available, or if they can direct you to a website for it.
Jun 09, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezers Logo
37 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
