Blue screen when left idle for period of time
  • Syllamo May 27, 2011
    This needs a LOT more information:
    What operating system?
    What service pack level?
    What drivers?
    What hardware?
  • 1,591 Answers
Disable all power saving features in both Windows and in the BIOS (CMOS) setup.
Without knowing what operating system you are running or which laptop you own, that's the best advice I can give, as I cannot give step-by-step without that information.
You should be able to do this yourself though given the information I have provided.
In the BIOS, there may be a setting to simply disable DPMS completely.
Posted on May 27, 2011
  • 23 Answers
Ouch, the Blue Screen of Death most likely. This can mean a lot of different problems, mainly in the hardware, either your C.P.U. is overheating, or your C.P.U., Mother Board or CMOS/BIOS has a short circuit. It can also mean your Hard Disk Drive is damaged. But you're here for solutions, not reasons:
1) Backup all your data from your Disk Drive in any method you can, then format your Disk Drive and reinstall everything.
2) Get a new computer, sounds harsh and expensive,but if the problem lies on the hardware, it will not be easily or cheaply repairable (if at all). A new C.P.U. is almost as expensive (if not more) than a new computer, a new Mother Board might not be compatible with your current hardware (HDD, RAMs, ROMs,etc) and the CMOS/BIOS is irreplaceable (embedded in the Mother Board). So buying a new computer might actually be cheaper.
3) Get a new Disk Drive, install everything in it,copy the data from the old Disk Drive and use the new one as your main Disk Drive. This is recommended only if the problem is found directly to be in the Disk Drive.
Runs slow,the entire laptop
Step 1:
Hangs When Idle for a Long b> Normally your computer will turn on a screen saver or enter sleep mode after a certain period of idle time, to protect your monitor from suffering a "burn in" of an image that appears on the screen for extended periods of time. This also helps to save electricity during periods of inactivity. Vista owners report via Internet tech help forums a seemingly rampant "bug" that causes the machine to freeze after being left idle for long periods. No single factor seems to cause this, and instead requires troubleshooting and trial and error to find a fix that works.
Screen Saver Failure
When your computer freezes after a long idle period, it could be due to a malfunctioning screen saver. Turn your screen saver off, by clicking "Start" and then "Control Panel." Under "Appearance and Personalization," click "Personalization" and select "Screen Saver." Select "None" under the screensaver drop-down list and hit OK. Pay attention next time your computer goes idle for reappearance of the problem. b> Power Saving Options b> Windows Vista provides users a way to select how their computers behave after sitting idle for a certain amount of time. In many cases, the hard drive and monitor are instructed to enter sleep mode or even shut down after they've been idle for a specified time frame. To check or alter your settings, click the "Start" button and then "Control Panel." Under the System and Maintenance icon, click "Power Options." Under this tab you can change the amount of time before your system goes to sleep, and the actions it takes after reaching the idle time. Malware b> When mysterious things begin happening to your computer for no apparent reason, there's a good chance a malware program is behind it. Malware are nasty, hidden programs that download themselves onto your computer to cause havoc and even steal your personal information. These invaders monopolize your CPU, clog your RAM, and generally make using your computer unpleasantly slow and frustrating. Their presence can affect everything from program operation to operating system functionality. Always update and run malware protection software regularly to keep these pests out of your computer. b> Update Windows and BIOS b> Your computer's operating system and BIOS files are responsible for proper operation and functionality. Over time, these files can become outdated, requiring patches, fixes and other updates to correct compatibility and security problems in your computer. Microsoft provides regular updates for its Vista operating system to correct reported problems. The BIOS in your computer is programmed into the motherboard, so the board's manufacturer may have an update available for your version. In many cases, the brand that sells the computer may offer a link to the BIOS update, so check with Microsoft for any updates available. b> Too Many Processes b> Your computer will register as "idle" if you haven't used it, even if you have programs open on the screen. After a certain amount of time, the system will send the data you were working on to the RAM as the system settles into sleep mode. When trying to wake the system after this idle period, it may have a hard time resuming the programs that are open, causing a freeze. Close down any program you are not actively working in to save the CPU from unnecessary work, and lessen the load placed on the RAM when it's left idle. right mouse click in the bottom toolbar select task manager applications if you see something running that should not be running select end now you might even uninstall that specific program if its no longer needed also in the processes tab see whats ticking over in the background might be a virus or malware. Download and install at least one of these all free depending on your operating system http://download.cnet.com/avg-antivirus-free-2013/3000-2239_4-10320142.html avg free 2013 http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html microsoft security essentials your operating system must be registered Win7/Vista/XP 64 bit http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7 http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information malware protection http://100-downloads.com/download.php?p=615 windows xp microsoft security essentials http://100-downloads.com/download.php?p=614 windows 7 microsoft security essentials
Feb 24, 2013 | Microsoft Windows XP Home Edition
Can i chat to someone about my hp pavilion 23?
No chat here, but check your screen saver settings for "On Resume Display Logon. Remove the check.
Feb 08, 2013 | HP Pavilion Computers & Internet
Hp freezes after it sits for long time
which operating system ?
When your computer freezes after a long idle period, it could be due to a malfunctioning screen saver. Turn your screen saver off, by clicking "Start" and then "Control Panel." Under "Appearance and Personalization," click "Personalization" and select "Screen Saver." Select "None" under the screensaver drop-down list and hit OK. Pay attention next time your computer goes idle for reappearance of the problem. b> Power Saving Options b> Windows Vista provides users a way to select how their computers behave after sitting idle for a certain amount of time. In many cases, the hard drive and monitor are instructed to enter sleep mode or even shut down after they've been idle for a specified time frame. To check or alter your settings, click the "Start" button and then "Control Panel." Under the System and Maintenance icon, click "Power Options." Under this tab you can change the amount of time before your system goes to sleep, and the actions it takes after reaching the idle time. Malware b> When mysterious things begin happening to your computer for no apparent reason, there's a good chance a malware program is behind it. Malware are nasty, hidden programs that download themselves onto your computer to cause havoc and even steal your personal information. These invaders monopolize your CPU, clog your RAM, and generally make using your computer unpleasantly slow and frustrating. Their presence can affect everything from program operation to operating system functionality. Always update and run malware protection software regularly to keep these pests out of your computer. b> Update Windows and BIOS b> Your computer's operating system and BIOS files are responsible for proper operation and functionality. Over time, these files can become outdated, requiring patches, fixes and other updates to correct compatibility and security problems in your computer. Microsoft provides regular updates for its Vista operating system to correct reported problems. The BIOS in your computer is programmed into the motherboard, so the board's manufacturer may have an update available for your version. In many cases, the brand that sells the computer may offer a link to the BIOS update, so check with Microsoft for any updates available. b> Too Many Processes b> Your computer will register as "idle" if you haven't used it, even if you have programs open on the screen. After a certain amount of time, the system will send the data you were working on to the RAM as the system settles into sleep mode. When trying to wake the system after this idle period, it may have a hard time resuming the programs that are open, causing a freeze. Close down any program you are not actively working in to save the CPU from unnecessary work, and lessen the load placed on the RAM when it's left idle. right mouse click in the bottom toolbar select task manager applications if you see something running that should not be running select end now you might even uninstall that specific program if its no longer needed also in the processes tab see whats ticking over in the background might be a virus or malware. Download and install at least one of these all free depending on your operating system http://download.cnet.com/avg-antivirus-free-2013/3000-2239_4-10320142.html avg free 2013 http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html microsoft security essentials your operating system must be registered Win7/Vista/XP 64 bit http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7 http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information malware protection http://100-downloads.com/download.php?p=615 windows xp microsoft security essentials http://100-downloads.com/download.php?p=614 windows 7 microsoft security essentials Hope this helps.
Dec 20, 2012 | HP Compaq d530 CMT PC Desktop
I have a dell studio 1745 laptop that is 13 month old. The display has very fine snow storm on it and there are fine lines going from left to right and slowly moving down the page. The colours are all...
This is due to loose connection which could happen after a period of time between the screen to the laptop.
Solution:
You can use another LCD screen as you secondary screen which you need to hook up to your laptop onto the blue connector (vga connection) or get the laptop screen replaced altogether
Feb 02, 2011 | Dell Studio 17 Notebook
What causes a blue screen
Blue screen occurs when the video port inside of your motherboard is not distributing its circuitry to the system. In laymans term, if the programs/ applications are not responding properly to its application for a very long period of time, the screen would turn blue..
Aug 19, 2010 | IBM ThinkPad i1200 1161 Notebook
Infocus DP8400x blue hazey line
this discoloration is the begining of the lcd panel being thermal damaged. this happens when the projector is being used for a long period of time and then being shut off using the switch on the rear of the projector instead of the on/off on top or the remote. to fix it it will have to be replaced. very expensive major repair.
Jul 11, 2010 | InFocus DP8400X LCD Projector
Picture is starting to turn blue at lower left corner of screen.
The Optical Engine is the probable cause of this. Check with Mitsubishi at 1800-332-2119 and see if they could assist you in getting a Authorised Service facility out to confirm this. If it is , they may help you with the repair cost.
Hope this helps,
skyassoc
Jul 18, 2009 | Mitsubishi WD-62526 Projection TV
Blue line problem with Sony Grand WEGA KDF-55WF655 Rear Projection TV.
We had the free repair from SONY for the blue dots and splotches. It works great now but you need to hurry and contact them as the offer expires I believe in December.
Sep 25, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
T.I 84 Plus Calculator
Well, this might not be right, but check the Brightness. Hit 2nd, then the down arrow. repeat this a few times. see if that works.
Sep 14, 2007 | Texas Instruments TI-84 Plus Calculator
Computers & Internet Logo
David Payne
David Payne
