Question about Panasonic Car Audio & Video
Hello, I have a Panasonic dvd combo unit out of a stock '03 chevy cuad cab truck. Model #CN-SG0360ZC Ref. #15191409 Serial #177239 Its having problems ejecting the dvds, so I'm replacing it with another dvd player cause nobody around seems to want to tackle it. I need to know the plug wires so that I can wire a new dvd player to the existing screen. Can you help me? thanks, stereo steve
sgregg
  • 133 Answers
SOURCE: Is this considered clipping in marine boat stereo help!!!!
if your radio is puiing more power your ground might not be good enough, use the same spot but remove the ground and rough it up a little on the base with some sand paper or add a metal o ring to get a better ground.
Posted on Jul 30, 2007
SOURCE: '05 Chevy Z-71 w/ BOSE stereo upgrade. How can I wire the BA-200 ?
Unfortunately, it's not as simple as a crossover. Bose gets its name from making complete systems - meaning - Bose speakers work right because the amplifier is custom built for those speakers, and the deck is custom built for the amplifier- all Bose from beginning to end. The only way to bypass any part of a Bose system is to bypass the whole system, including amp, deck, subs, speakers, eq's, and start over from scratch, unless you are an electrical engineer and can meter components and evaluate them. Bose often has 1 or 1/2 ohm speakers which will not work with after market systems.  If you go to a Bose store, the only system that sounds good is the lifestyle system because it is Bose from beginning to end, just as an example. They are either cheaters or geniuses
Posted on Oct 17, 2007
SOURCE: I have the factory wiring
Car stereo need only POSITIVE & NEGATIVE wirings look the ground sign for negative, mostly body ground or negative supply. Then trace the positive line mostly series a fuse and fuse holder.
Posted on Apr 29, 2008
wdwbusiness1
  • 4 Answers
SOURCE: car stereo installation speakers
Yeah, rewire that.
Posted on Aug 19, 2008
SOURCE: car stereo wiring
http://www.clarion.com/us/en/MungoBlobs/752/342/VRX755VD-English.pdf
Posted on Apr 01, 2009
Hi I have a Panasonic cn-h500d I would like to know if I can change the language from Japanese to English
It appears to be made for the Japanese market.
Panasonic will launch two new GPS systems in the form of the Strada CN-H500WD and CN-H500D. These in-dash car navigation systems feature "Motion Control" user interface, allowing you to manipulate the map with hand gestures. Both navigation gadgets also provide an integrated DVD/CD player, a 7-inch (800 x 480) LED-backlit touchscreen display, a 1Seg TV tuner, SRS WOW HD, a 60GB of internal HDD and the Panasonic PEAKS image processor. The Panasonic CN-H500WD and CN-H500D will be available in the Japanese market in August 2011.
Putting that model number into Panasonic Support search only brings up details in Japanese.
http://vftr.panasonic.co.jp/en/search.x?q=cn-h500d&searchIn=&_charset_=utf-8
Oct 22, 2015 | Panasonic Cameras
I have a PANASONIC NSDN-W59 MODEL : 08545-00S61 REF : CQ-US0901CJ SERIAL: 76043 in my car and i change my battery now its need a code to unlock it. now what do i do?
Apr 04, 2013 | Panasonic Car Audio & Video
DVD player won't eject and an u99 error code is displayed.
Hello
It is an internal circuit problem.
The unit fails to operate properly. Press [POWER] on the main unit to switch the unit to
standby. Now press [POWER] on the main unit again to turn the unit on.
OK
Jun 10, 2011 | Panasonic DMRES30V DVD Recorder/VCR Combo
Panasonic DMR-ES30V DVD / VCR Combo Recorder - where can I buy another? If I have to buy latest model, will it finalise DVD's made on the above model?
You may be able to find an identical model for this combo unit on eBay or similar, otherwise if you do end up purchasing a new unit (for example a DMR-EZ48V which is a Panasonic) - you cannot finalise discs recorded on one model in a different one, and I doubt you would be able to even on an identical model, since there would be variations in their digital control circuitry.
This is why recorded DVDs must be finalised in the drive they were written in to enable compatible playback in standard players. You cannot change recording models or drives prior to finalising.
Apr 09, 2011 | Panasonic DMRES30V DVD Recorder/VCR Combo
My panasonic dmr-ez475v has a dvd stock inside and will not open or eject the cd. what to do?
I had the same problem. It would not release the DVD because it was not ready. What worked for me, was to insert a VHS Movie and play it for a few seconds, than stop it using the remote, then Eject with the remote, and then after removing the Tape, I pressed the Open/DVD button on the unit and now it worked, it released the DVD
Jul 31, 2010 | Panasonic DMRES30V DVD Recorder/VCR Combo
Unable to access most functions....
Hi !! If you dont plug park brake and light switch, some options will be blank. Turn off power supply conect those plugs (im advice you to do not conect speed cable). Turn on them reset the unit.
P.S. The park brake cable can be conected with tre ground. This way you can watch dvd with the car in moviment...
Go to the panasonic web and download the last update for your unit !! http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/Mobile-Navigation/model.CN-NVD905U
I hope it helps yous... sorry my english....
Nov 21, 2007 | Panasonic Strada CN-NVD905U GPS Receiver
Cannot access Address, POI, and Nearest POI.
Car Audio & Video Logo
122 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
