Question about Seagate (ST3500601CB-RK) (ST3400601CBRK) 400 GB Hard Drive
I have a Seagate 3.5 inch pushbutton backup external hard drive, M# ST3400601CB-RK that states that it needs to be formatted. I would like to remove the hard drive and put it as a slave on another PC. How do I remove the cover to access the hard drive inside the shell?
    Novelist:
    Champion:
  • 224 Answers
Attaching it to another PC will just move the problem to the other PC. USB drives frequently have the problem you are seeing.
You can have your partition and data restored remotely by this guy. http://FreeDataRecovery.us
Posted on May 28, 2011
How to recove Seagate external hard drive data?
Probably, the new operating system cannot recognize your Seagate external hard drive. You can connect the Seagate external hard drive to another computer to copy data to another device. If the problem still exists, you might need to perform data recovery. You can free download the data recovery software: http://www.icare-recovery.com/seagate-recovery/seagate-external-cannot-be-recognized.html
May 14, 2014 | Seagate FreeAgent Pro 500GB External USB...
I only want to backup new information but the drive is backing up the entire hard drive each time. How do I change this?
Set your backup program to only backup the folders you need. You have it set to backup the drive. If your set up is to backup only "New" info, then the program needs to scan the drive to find out what is new.
Sep 08, 2013 | Seagate Expansion 2.0 TB USB 2.0 Desktop...
Seagate Drive is asking to be reformatted?
Yes your assuumtion is correct, you WILL loose all your data.
I have been there before.... and the outcome was not good.
If your PC will recognize the drive and give it a drive letter, you can run chkdsk (Check Disk) from the Run prompt to verify that the drive does not have damaged sectors. many times chkdsk will fix minor errors allowing you to access the drive again.
Click Start, Run CMD, enter, then type: X: (X being the drive letter of the Seagate) then type chkdsk /r and hit enter. If it completes 100% try accessing the drive again.
If you cannot acquire a drive Letter when you plug in the Seagate try going to Disk Management and assigning a drive letter.
Click Start, then Right click on My Computer and click Manage, then click Disk Management. See if your Seagate drive shows up in the list. If it does, right click on the larger box on the right and see if it will allow you to assign a drive letter.
Another option you may have is taking the hard drive out of the Seagate enclosure and either connecting it as a secondary drive in a desktop PC, or installing it into another external enclsure USB device, and try again to access the drive.
If none of these options work, your last option is to contract a Disk Recovery Service to acquire your data. They are usually very expensive.
Jun 15, 2009 | Seagate (ST3500601CB-RK) (ST3400601CBRK)...
I reformatted my C: drive and ever since Windows will not recognize my Seagate External Free Agent hard drive. It shows up under ?My Computer? as Removable Disk (I: )? It used to be listed as Seagate...
Try connecting it to another computer. If you can see your data then back it up etc.
After you have recovered your data connect it to your computer, from Disk Manager, remove the partition, recreate it again and then format the drive, hopefully your external drive will be operational again.
There is a possibility that the hard disk has died and you will have lost your data. If you are desparate, hard drive data recovery companies charge an arm and a leg to recover data from dead drives.
Jan 10, 2009 | Seagate Free Agent Go Small 12 GB USB...
Help!
You have not yet formatted the drive to work with you MAC. You will need to use your MAC's Disk Utility to format the drive in order to write to the drive, but be aware that formatting will erase everything already on the external drive, so back up anything on the drive you want to keep first.
May 29, 2008 | Seagate 400GB 7200rpm External HDD Retail...
Power indication light flashing
Hi, you may want to try connecting it by USB if you're currently using firewire or the other way around and see if it works. If this fails, you are probably better off using diagnostics by Seagate @ http://www.seagate.com/ww/v/index.jsp?vgnextoid=7f4e19e0babfd010VgnVCM100000dd04090aRCRD&locale=en-US#. Try to use the Troubleshooting or FAQ or if you feel comfortable using their utilities, download SeaTools. Hope this be of help to you. Good luck.
Apr 23, 2007 | Seagate 300GB Pushbutton Backup External...
External case removal, Seagate ST3160026A-RK External drive
You remove the foot/stand unit, then the silver cover with the circular rubber ring can be carefully pried off. If you do this, you'll void the warranty, so if you want to do this because your unit is dead, then you should return it for a warranty repair. If you're doing this to put a larger capacity drive in the box, be aware that larger or faster hard drives might generate more heat which could adversely affect the new drive's ability to operate properly.
Dec 05, 2006 | Seagate (ST3160026A-RK) 160 GB Hard Drive
Seagate (ST3500601CB-RK) (ST3400601CBRK) 400 GB Hard Drive Logo
64 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
