Question about Nintendo Wii Console
Hi,my wii remote is not powering on nor blinking too.put full batteries but nothing.there is no sign of it working
    Problem Solver:
  • 17 Answers
Click here
Posted on May 27, 2011
I can't seem to sync my wii controller. All 4 lites are blinking and will not stop. I changed the batteries and tried to re-sync the controller w/no luck. It was just working a few minutes ago.
    Try these steps!
  1. Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
  2. Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
  3. After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
    1. With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
    2. Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
    3. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
    4. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
    5. This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
if nothing else works call 1-800-255-3700
Jul 12, 2011 | Nintendo Wii Remote Controller
My wii remote just stopped working in between games and now the 2 bottom lights stay on and the remote won't turn off
Try removing the batteries after you turn off the system. This will turn off the power to your Wii Remote. Once it's off, put the batteries back in and turn on your Wii. If nothing happens on the Wii Remote, then it needs new batteries.
If you're still getting weird errors, push and hold the power button on your Wii for ten seconds. If you have problems after doing this, contact Nintendo at 1-800-255-3700.
Jan 06, 2011 | Nyko Wand? for Nintendo Wii
Put new batteries in the remotes and the four lights blink twice when you push power
You might have to resync the remote take off the battery cover and push the red button under there to resync it with your wii, you will have to do the same thing with a brand new remote or when taking the remote from one wii console to a friends.
If this isnt working then your remote batteries are bad or you are having a hardware issue with the remote. Unless your trying to play a game cube game this is another issue and has nothing to do with your wii remote working or not.
post back if this dont fix your issue
Apr 23, 2010 | Nintendo Wii Remote Controller
Hi my wii remotes arent working please help
Possible scenarios:
Out of battery:
Solution:
Replace batterries
Connection has been intercepted:
Solution:
Take the back off of the remote and then go to the Wii and open the little compartment left of the Wii. Then press the red button on the Wii remote and console simultaneously untill something happens like, connection restored on the Wii screen.
Dec 30, 2009 | Nintendo Wii Console
My wii remotes wont pick up signal blue lights flash then just go back out again
Hi, check the batter level and then try re-synching the remote's.
Here's instructions for both:
f4bc8924da.gif A fresh set of alkaline batteries should last, depending on amount and type of use, up to 35 hours. This can vary greatly based on certain factors, such as Wii Remote Speaker Volume, Rumble, battery quality and age, and type of game being played.
Important Note: If you are using rechargeable batteries, the only type of battery recommended are Nickel Metal Hydride batteries. When it comes to using rechargeable batteries, you must follow manufacturer guidelines for safety and proper usage. Failure to do so could cause damage to the Wii Remote and void the warranty.
There are two ways to check the Wii Remote's battery levels:
  • Remove the battery cover and press the Red "Sync" button. The number of lights flashing indicates the Wii Remote's battery strength. Four flashing lights indicates full strength, with one light flashing indicating the lowest level.
    or
  • Use the HOME Menu to check battery level of each Wii Remote:
    1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
    2. Select the Wii Remote Settings option from the Home Menu.
    3. The battery level of all synced Wii Remotes is displayed along the bottom. Four bars indicates a full charge, with one being the lowest charge.
55851daefd.gif Note: Make sure you have placed batteries in the Wii Remote.
  1. Press the Power button on the Wii console to turn it on.
  2. Remove the battery cover on the back of the Wii Remote you wish to sync up, and press the SYNC button just below the batteries. The Player LED will blink.
  3. Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 to 4).
This procedure must be followed for each additional Wii Remote added to your system.
I hope this helps
Mike
Jul 30, 2009 | Nintendo Video Game Consoles & Games
Wii remotes blinks several times but doesn't work.
you see the little flap on the wii open it and the back of the wii remote then press both red buttons and wala good as new
Jul 21, 2009 | Nintendo Wii Console
Wii Remotes are not working.
Be sure to follow this procedure in order:
If that doesn't work, try putting fresh non-rechargable alkaline batteries in the remote and repeat the above procedure. The culprit may actually be your batteries.
Jan 25, 2009 | Nintendo Wii Console
Wii remote wont work after installing wii fit
From Nintendo:
  2. Turnthe power of the Wii console ON. When you see the Health and Safetyscreen, open the small flap on the front of the Wii console to find ared button labeled "SYNC." Press and hold the SYNC Button down for 15seconds. This will clear all the syncs on the Wii, allowing you to geta clean start to begin the process described below.
    1. Withthe first Wii Remote you wish to sync, remove the battery cover on theback of the Wii Remote to find a small red button just below thebatteries.
Jan 02, 2009 | Nintendo Wii Console
Wii remote not working
it sounds like it could be faulty but I got this info from nintendo's website and at the bottom there is a customer service phone number that will help with any other problems relating to remotes for the wii
Still having problems? If the basic guidelines above did not solve your problem, the more specific information below may help.
  • Wii Remote not being recognized by the Wii Console (lights on the Wii Remote flash when you press a button, but then go out) - Most Common:
    Getting the Wii console to recognize (or "sync" with) a Wii Remote, especially one that did not come in the box with your Wii console, may require doing a few additional steps before it can be synced. Additionally, a Wii Remote that was working, but is no longer being recognized (or has "lost its sync") may need to be re-synced. Please use the troubleshooting steps listed below, which our experience has shown can solve many Wii Remote issues.
      Try these steps!
    If you are still unable to get the Wii console to recognize your Wii Remote(s) after carefully following the steps above, please call 1-800-255-3700 for further assistance.
I know this says if your console does not recognise your remote, but they should be able to help you with your problem too
Dec 28, 2008 | Nintendo Wii Console
Wii remote will not work
Ok, glad it now works for you. Please rate this as fixed so it does not show up in the unsolved problems list.
Many thanks,
Mowcius
Aug 02, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
20 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
