Question about Maytag Washing Machines
My maytag washer will fill and not stop filling. I did the pressure switch tests and it seems fine. The valves are not the problem. What is?
  • Syllamo May 27, 2011
    How old is the machine - there used to be a diaphragm based system to determine pressure - this would hook up to a water level switch somewhere on the controls (sometimes no switch)
    Genius:
  • 1,140 Answers
It has to be the pressure switchs then
Posted on May 28, 2011
Washer ran all over the floor after filling up and didnt stop filling
Well, there are two main possibilities: Inlet valves and pressure sensor system. to test the inlet valves, turn off the machine, do they stop? Dirt can keep them open.
If power off stops the water, I suspect the pressure system. There is a component outside at the bottom of the drum that measures the water volume, using pressure. This collector component sometimes gets clogged with detergent. If it is open, test the transducer at the other end of the plastic hose. The system is designed to stop the power to the inlet valves when the pressure builds.
Jun 11, 2011 | Maytag MAV8557 Top Load Washer
Maytag Performa washer overflows when filling on any size load. Will stop when I push in the timer knob.
Overflow is usually caused by a "stuck-open" fill valve, with the cold water half of the valve 'sticking' open from sediment buildup inside the valve.
This can also be caused by the fill system control components: pressure switch, pressure tube, or pressure tube dome/port. So let's take a look at these.
First of all, determine whether your overflow condition is mechanical or electrical. Start the washer filling, then turn the timer off by pushing the knob in. If the fill continues, pull the washer plug. If filling continues with the washer unplugged, you have a mechanical problem - nearly always a stuck valve ***'y. Replace the fill valve.
If however, the fill stops when you unplug the machine, you are looking at an electrical fill control problem, and it gets a little more complicated.
Here a small piece of rubber or plastic tubing is handy. Unplug the washer and open the console where you'll see the pressure switch. This is the switch with a small rubber tube, usually clear, sometimes black, attached. Pull this tube off and replace it with your short tubing. Blow a bit of pressure into the switch using your mouth, and listen for a click, then another when you release the pressure. Hear two clicks? Good! The switch is probably OK
Plug the washer back in (being aware that components in the console are now 'hot' - live electric, use extreme caution , u can be SHOCKED), and start the washer filling again. With it filling, again blow a bit of pressure into the switch. If the switch is good, the fill should stop and the machine should start to agitate.
This verifies that the pressure switch is working, and causes us to suspect the pressure tubing or a clogged port/dome to which it connects. Wipe off the end of the original tube you removed from the switch, and blow into it. You're blowing air down into the tank now, and you should feel very little restriction. If it is very hard or impossible to blow through this tube, the tank dome or port is clogged.
Really old Maytags were known for this, and if you have one, spin out all water, remove the 'Corbin' clamp from the pressure tube outside of the tank and pull the tube off. (Pull washer front off - 2 Phillips screws at bottom, then two 3/8 in. hex screws release top, which swings upward) You will probably see 'gunk' clogging both the rubber tubing and the 'spud' that is a part of the tank. The hose ***'y can be taken to a sink and flushed clean with hot water, and an old toothbrush used to clear the tank spud, which, in the Maytags, is about 3/4 in. ID.
Very important: WHENEVER THE PRESSURE TUBE IS REMOVED, BEFORE REINSTALLING IT, BE SURE ALL WATER HAS BEEN SPUN OUT OF THE WASHER! Otherwise, the water fill level will be incorrect and you'll be back in trouble.
May 25, 2011 | Maytag PAV2300 Top Load Washer
Awhile back I had FixYa help me with my washer. It would fill up with water and then just stop. It turned out to be the lid switch. Now about a month or so later I went to wash a load of clothes and again...
Hi.
If the lid switch is OK and there is water getting into the machine, then test and replace the pressure switch that detects water level.
Here the part:SUB 12002304 (Water Level Switch Kit)
Part is nr 6 in this diagram.
Also test the inlet valve to ensure that dual inlet is working. If hot is not filling, the machine will not complete filling.
A technician can swap valve contacts to find out if
both valves are opening.
If there is no filling at all, check the inlet valve and inlet duct:Water Inlet Valve.
Inlet valve is at the back of the appliance. It can be tested reading Ohms at terminals.
Aug 11, 2010 | Maytag LSE7806A Top Load Stacked...
My washer will not stop filling - it overflowed the tub, and will not drain.
If you can hear water running into the machine when the power is off then the fill valve has failed
If the water switches on and off when you switch the machine power supply on and off then it is either the pressure switch or the pipe supplying the pressure to the pressure switch
Easy test is to remove the pressure switch pipe at the base of the outer container and start the washer filling , blow lightly into the pipe and you should hear a click and the water should turn off
If it does not then the switch is faulty, if it does then check for congealed soap in the small plastic fitting from which you removed the pipe in the first place
Apr 07, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Performa wont fill hot water
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Nov 27, 2009 | Maytag Performa PAV2200
On my Maytag Neptune MAH-3, the water is running non-stop
check plastic hose out side of tub to pressure switch
if ok replace pressure switch
Oct 12, 2009 | Maytag Neptune Washer
My maytag washer does not stop filling with water no matter what size load I change it to.
The mixer valve (water valve) solenoid has failed in the open position.
Change out the valve to repair.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Jul 21, 2009 | Maytag Washing Machines
My kemore 80 series washer will not fill up
Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
May 03, 2009 | Kenmore 24032\24036 Top Load Washer
1999 maytag neptune washer stops after filling up with water
There are a couple of common causes for a problem like this. First is a bad door lock assembly that also damages the machine control board (in the control panel). If this is the case the R11 resistor on the machine control board will be burnt.
Maytag has identified seven resistors that relate to specific components that need to be checked or replaced if the resistor is damaged. Listed here are the resistor identification, the circuit involved, and the recommendation:
R9 / pressure switch / check for loose connections or high resistance on switch contacts; replace pressure switch if necessary.
R11 / door lock wax motor / replace door lock mechanism and machine control board.
R51 / hot water valve solenoid / replace water valve and machine control board.
R52 / timer motor / check for loose relay terminal connections and replace machine control board.
R53 / cold water valve solenoid / replace water valve and machine control board.
R143 / (-) 24 Volt DC / contact was made between neutral and the 24 Volt DC circuit.
R162 / electrical buffer circuit / wire harness and machine control board.
Another common issue is a slow water fill fault. If the washer does not fill within a certain time the control will stop on a fault. Usually when this happens the START button can be pushed to continue the cycle.
Washing machines that won't fill or fill slowly often have a restriction in the incoming water supply -- usually in the screens of the inlet hose washers or the water inlet valve itself. Remove the hoses to inspect this condition. If the water inlet valve screens are plugged, replace the water inlet valve.
Go here for: Maytag Neptune Washer Parts
RepairClinic.com
Appliance parts, help & more
Apr 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water level switch doesn't shut off the water
Washer Basics: Filling with water:
Water level controls - The water level control is also know as a pressure switch, this is where you set the water level ( small - medium - large ). The water level control is responsible to shut off the power to the fill valve and direct that power to the timer so the washing machine can start up. The WLC has electrical contacts in it that sends power to the fill valve and when the WLC is satisfied the water level is correct the electrical contacts open power to the fill valve and send the power to the timer and the washer starts. Picture of this here. How the water level control knows when it is time to shut the water off is, a air tight hose runs from the outer washer tank to the water level control. As the water fills the outer tank air is pushed up the hose, depending on which setting you have made ( small- medium - large ) is takes a certain amount of this pressure to make the WLC cycle over and shut off the water and send this power to the timer. If this hose develops a leak or a pin hole the washer can over fill as the WLC may not be able to shut the water off. The water level control can also break down and allow the washer to over fill as well.
Testing a  water level control or a fill valve can be done by using a Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter. Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter. Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter.
A couple of tips from readers (Thankx!! ):
~ If you have a loose hose on the water level control or tank end, use a plastic wire tie to help hold the hose tighter and make a tight fit.
~ The water level tube (tube that runs from the square box), access panel on the outer drum where the bleach tube also ends) from the pressure sensor switch (front panel) can become clogged.  Or the two holes from the outer tub into this square box panel on the outside of the outer tub can become clogged. Either clog, I am told by my help repair guy can cause the sensor to think that there is still too much water in the tub and so will not allow motor to activate spin.
~ If the water level control contact is bad, it may also stop the filling ok, but not tell the washer to start agitating.
Nov 13, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
24 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
