Question about D-Link DI-LB604 Router (DILB604)
After upgrade firmware, it is malfunction
DILB604_firmware_101.img
this is the file name that was installed. please help
    Scholar:
  • 37 Answers
Reseting the router does not fix firware issues it is a problem with the firmware itself. If it got intoerrupted then you could run into this error and you need to reinstall the firmware. I have a dlink router and they seem to have a problem with some of the firmware distros they deliver. One thing that you can try to do is revert back to an older version that they have if reinstalling the firmware didnt work. If this then does not work then you need to contact dlink.
Posted on Oct 01, 2009
Thanks, it is OK
Posted on Aug 23, 2008
    Genius:
  • 1,689 Answers
There is a possibility that the firmware upgrade was interupted, please try to press the reset button on the device for around 20-30 seconds, after this and you still have issues, please try to contact D-Link and check the warranty status of the device.
Posted on Aug 16, 2008
Restore factory settings for a pendopad
I have resolved the pendo pad hard reset lack of procedure and can factory reset a pendo pad that is locked with a passkey or and password full factory reset
First download you pendo pad firmware from here
http://shop.pendo.com.au/index.php/su...
I used the generic firmware 1 download and it worked fine for the TPC7SlV
Then Extract the . img file to you computer
Then you will need the firmware update too called rktools found here
http://download1942.mediafire.com/le9...
extract the zip file to your computer
Now your ready to flash the firmware
1. Power off your tablet with the switch
2. Turn the power switch Back the the on Position
3. Press & hold Side Button with the home picture also called the back/esc key
4. While holding, connect PC and tablet with USB cable (if tablet boot normally, try again)
5. Install the driver for your computer included in the RKtools Folder
6. Tablet should be recognized as "RK281X Device" in Windows
7. Start RKAndroidBatchUpgrade from rktools folder
8. In the bottom of the batch RKAndroidBatchUpgrade programme there should be a green light in the device upgrade area. * if there is no light in the upgrade area and all the numbers are grey then repeat the previous steps
9. Under the setting heading click and select the image file you downloaded from pendo ( will be a .img file if its a .zip file you need to extract it)
10.Click the upgrade button
11. wait till operation is completed
BAM Your pendo is password free, i hope i have created the best and easiest way to do this
***Please note if your wireless or Mobile network do not turn on then you have chosen one of the wrong firmware types from the pendo download site !!! the wireless and mobile network hardware are the only distinguishing features between the firmwares apparently******
Mar 08, 2013 | Tablets & eReaders
Problem when trying to add songs to albums
try removing all of the other info from the listing, except for the album, artist, and title. This is strange, but if you could tell me what brand it is, then it could be something much simpler.
Feb 05, 2008 | Samsung YP-K3 MP3 Player
Install XF2 Firmware V4.10
After you have downloaded the file "install.img" from lge.com,connect it to your TV,go to Settings,then System Upgrade,press OK to show the sub items of System Upgrade, choose "Cancel" to abort the operation and choose "Upgrade" to upgrade the system firmware. Afterward,
the system will reboot and the firmware upgrade page begin to show. After firmware upgrade completed, the system will reboot and show the language selection page.
Sep 06, 2012 | LG (HXF1N50SB) 500 GB USB 2.0 Hard Drive
I bought a lifetime update from Garmin a few years ago but now my nuvi 270 tells me that I don't have enough memory to install the latest maps and that I must choose only certain regions. I have an 8Gb...
The internal memory of the nuvi is full. Some maps will need to be delete before any new maps can be added. Typically, the map in the nuvi is named GMAPPROM.IMG and a map installed to an SD (or SDHC) memory card is named GMAPSUPP.IMG.
1) Remove the SD card from the memory slot
2) Connect the nuvi to the computer via USB cable.
3) Open the nuvi drive.
4) Locate and delete the GMAPPROM.IMG (or GSUPPROM.IMG) file(s). Optionally copy (instead of deleting) them to your hard drive in case there is a problem wit the new map file(s).
5) Empty the Recycle Bin.
6) Retry the map update of the nuvi.
This method will take some time to perform depending on how many map segments you are sending to the nuvi. Transferring the entire map can take over an hour. A quicker way is to send the maps to the SDHC card directly by inserting the card into a card reader. This eleminates the slow Garmin card reader from the equation and transfers are done in a fraction of the time. No maps will be on the nuvi - they will all be on the memory card instead. To update the SD or SDHC card, do this:
1) Repeat steps 1 thru 5 above. This removes the maps files from the nuvi.
2) Disconnect the nuvi from the computer.
3) Connect a card reader to the computer.
4) Insert the SD or SDHC card into the reader.
5) Locate and delete the GMAPPROM.IMG (or GSUPPROM.IMG) file(s). Optionally copy (instead of deleting) them to your hard drive in case there is a problem wit the new map file(s).
6) Update the map to the SD or SDHC card.
When either method is employed, only one map file set will result. GMAPPROM.IMG or GMAPSUPP.IMG is the name of this file set. You should ensure / change the name to GMAPPROM.IMG. Any subsequent file set added should be named GMAPSUPP.IMG.
I hope this helps & good luck! Please rate my reply - thanks.
Jun 27, 2011 | Garmin nuvi 200W GPS Receiver
I'm upgrading firmware of the 3com 7760. I'm get from 3com.com and i download a file .img, but in the 3com web interface say "Please Input Address Path for Upload". I selected the file .img. Excuse me...
i know this was from a while ago but 3com 7760's have a problem when uploading it files either firmwere or setting backup files you have to use internet explorer or you will get the "please input address path" error
Aug 04, 2010 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
WRT120N no .bin or .img file in firmware update download
Hi Friend
in order to upgrade the firmware please follow the steps:
1. Click the link (http://homesupport.cisco.com/en-us/wireless/linksys/)
2. Enter the model number of the router and hit enter.
3.Click Download Tab
4.Now enter the hardware version of the router (which you can find by turning the router upside down)
5.Now you can download the firmware which is a .bin file and save it to the desktop.
6.Open the router page and click Administration and click Firmware upgrade.
7.Select the file from the desktop by clicking Browse and start upgrade.
8.Turn off the router for 30 seconds after upgradation and turn it on..
i hope this will resolve the issue.
Regards
Chiranjeet
May 21, 2010 | Linksys WRT120N Router
Nextar ma852-801 mp3 freezing...reset?
Hi.
Welcome To Fixya Community.
Solution 1:
  • Try to Turn it ON/OFF(Reset).
If that isn't Working try This:
Solution 2:
  • You are going to upgrade the Firmware of your Mp3 Player in order to perform that follow these Steps:
  • Installation of the Upgrade Tool:
  1. Download the Upgrade Tool application (the download link is in the bottom of this Solution) to your computer.Double click the application.Follow the instructions shown on the screen to complete the installation.Firmware Upgrade:Note: All the existing files in the player will be erased while upgrading,please make a copy of your files before doing this.Turn on MA852-801 player. Press and hold the MENU button todisplay the main menu. Select “Settings” → “System” →“Upgrade” and press the MENU button to confirm. Select “Yes”and then connect the device to a computer via USB interface once you see the following window:
2. Select ”Program files” 􀃆 ”Firmware Update” from the Start
menu or double click the “Firmware Update” icon on the
desktop. You will see the following window shown on the
screen:
6fc021c.jpg***************************************************************************************
3. Click Open button, and specify the upgrading firmware with
the extension “ .rfw ” (Please download the firmware from
Nextar website named MA852-801 – updated firmware.rfw).
Click Update button to start upgrading.
Note: This process may take about 2 minutes depending on the
computer system you use. Please don’t disconnect while upgrading,
it may cause serious damage to the player.
4. Once it shows "Firmware update successful"wording in
“Update Info” window, then click Exit button to finish
upgrading.
*************************************************************************************(5) 5. Safely remove the player from the PC.
6. Turn on the player. Please wait about 20 seconds for the
player to automatically initialize settings.
Downloads:
Upgrade Tool.
Firmware File.
Additional Help:
Nextar Ma852-801 Mp3 Player Manual Guide.
please don't hesitate asking me if you need any Further Info.
Thank You For Using Fixya.
Good Luck.
Nov 04, 2009 | Audio Players & Recorders
Netgear DG836GT
OK. First, that dg836gt_1_02_09.img file does not seem to be a firmware file. You need to get a .zip file or a .bin file to upgrade the firmware. Check Netgear's website for the current firmware. If it is a .zip file, then you need to extract the .bin file from the .zip file with winzip software. Then, log into your router with Internet Explorer by typing it the routers IP address in the address bar like this http://xxx.xxx.xxx.xxx. Enter user name and password. Look for a tab that states software update. Browse for the .bin file you downloaded or extracted from the .zip and click update.
Apr 25, 2009 | NetGear DG834 Router
Firmware update for netgear router
I was having the same issues too. I followed the steps dotted all over the internet and was getting stuck in exactly the same place. No matter how hard I tried, I just kept getting the 'invalid filename' issue.
Eventually I figured it out - the way that Netgear/Virgin have blocked firmware updating is to break the filename checking page so it doesn't accept any files. What we need to do is bypass the filename checking code so that the firmware upgrade system can then handle the file, and we're going to do this by manipulating the web page using a tool called Firebug.
Here is the solution:
1) If you haven't already got it, install Mozilla Firefox 3 (there is good reason for this - I'm not just shamelessly plugging it! :P).
2) Install the 'Firebug' extension for Firefox from https://addons.mozilla.org/en-US/firefox/addon/1843 and restart your browser when requested.
3) Navigate to your router's admin page, and fill in your login details (if you don't know them, it's likely to be the one written on the bottom of your router).
4) Navigate to the router upgrade page (the one where you select the firmware to upload' and select the location of the firmware file, like you would normally. Now, instead of clicking the 'Upload' button, press F12. This should bring up Firebug in the bottom quarter of your screen.
5) Now, click the moz-screenshot.png2193448.jpgbutton at the top of the Firebug panel and then click on the 'Upload' button. This will bring up the code for the upload button, where it does the filename checking. It'll look like this:
6) It looks like Netgear have actually stripped out the real checking code so it can't be used, so we'll need to fool the page into thinking everything's fine and dandy with the filename so it can update the firmware. Click where it says "return checkData();" and replace it with "return true;".
7) Finally, click the upload button. The router should now accept the file and start updating.
And hey presto! You have a non-nargled wireless router with the latest firmware!
Mar 13, 2009 | NetGear WGR614 Wireless Router
How do I flash my bios on ca63-sn rev. a1
mail755,
Before I continue, I have to tell you that upgrading the BIOS firmware required extra care.
U need to check if you r using the correct firmware or not. If you are not sure, you can download it here.
http://img.lanparty.tw/Upload/BIOS/CM/CA63ESN0319.ZIP
after you have the correct files, you need to have the correct environment to upgrade the firmware,
here's the instruction to make a bootable USB Pendrive for the BIOS firmware upgrade.
http://tw.dficlub.com/tw/modules/newbb/viewtopic.php?topic_id=1837&forum=27&post_id=6679#forumpost6679
When you are boot into the DOS environment, you will see the A:\ prompt, you need to type in this in order to let the upgrade to proceed,
A:\>F780.exe 2A6LGD4N.bin
I have follow the exact filename of the files that you are goinn to download.
These will be the procedure to upgrade ur BIOS firmware. Please be sure that you are understand before you proceed, of not, you can post a comment here and I will follow up to explain to you.
Good Luck,
Don't forget to rate my solution, thanks.
Jan 14, 2009 | Computers & Internet
D-Link DI-LB604 Router (DILB604) Logo
261 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
