Question about Garden
On my 16.5 kohler engine a mouse chewed the ground wire that mounts to the coil housing.do uou know where it goes to?
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly.
Since you did not include your model number this is my bease guess at the manual:
http://www.kohlerengines.com/onlinecatalog/pdf/tp_2339_d.pdf See pages 61 and 64. Page 64 Figure 8-7 has the wire colors. Also see figure 8-13 on page 72. (Best)
Your parts can be found here if I guessed the model number correctly:
http://www.searspartsdirect.com/partsdirect/part-model/Kohler-Parts/All-Products-Parts/Model-CV165S43527/0598/1503500/P0030143/00010?blt=06&prst=&shdMod=
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fP0030143-00010.png (Able to Enlarge)
Hopefully this is all the information you should need to get your engine up and running again. If you have any questions feel free to ask.
Thanks for choosing FixYa,
Kelly
Posted on May 27, 2011
Question on craftman riding mower
with the ground wire off the coil and it turns over, you have a bad coil these engines are notorious for this. GOOD LUCK.....
May 23, 2014 | Kohler 18 Hp OHV V-Twin Command Engine
What point wires goes to hot and the ground on a john deere lawn tractor 214 kohler engine
The HOT wire goes to the contacts and the ground normally goes at the mounting screw
Apr 21, 2014 | John Deere Garden
I have a 214 kohler engine john deere lawn tractor, what point wires go to hot and the ground
if that is the Kohler 14 hp motor it may have the spark control untit on the motor cover. I recently ran into one like that and switched the coil out from a blown 20 hp kohler engine. I just taped up the excess wires and made sure they were not near any moving parts. The mower ran fine after that. Kohler wants about $160.00 for a spark control unit. There have been no repercussions since making the switch.
No spark on kohler generator 4ckm21
I don't have any idea what Carl just said, but remove the little ground wire from the coil and try to start the engine. If it fires and runs ok, you have a grounding issue somewhere and need to follow the wires around to see if anything that shouldn't be touching metal, is.
Oct 10, 2013 | Kohler CH25 PA-CH730-0040 Command Gasoline...
I have a 2008 cub cadet rideing mower with a kohler 27 hp ohv v-twin eng. It has 2 coils .eng. model no.sv740s . Coil pt. numbers are 24-584-89s .These coils are about 100.00 dollars ea. Is there a...
it would be odd for both coils to go bad swap coils from side to side see if the misfire goes with the coil if there both died check the kill switch circuit to the coils one of my koher engines also has a ignition module with out a module style and no spark to either cylinder remove the harness side is you get spark with that wire off its a bad safety switch or grounded wire
Aug 09, 2012 | Garden
My husqvarna i wont suhts off when i turn key nothing happens
remove the upper cover from the engine and see f a mouse chewed threw the small wire at the coil that goes to the switch
Jun 20, 2012 | Garden
When i got the bike it wasnt running .it had no coils ,no plugs .iv bought new ones and need to know what lead goes were from waht coil .
The coil for the #1/4 spark plugs is mounted on the left side of the bike, and has the solid orange (ground) wire and the red-with-white-tracer-stripe (hot) wire input leading to it.
The coil for the #2/3 spark plugs is mounted on the right side of the bike, and has the solid grey (ground) wire and the red-with-white-tracer-stripe (hot) wire input leading to it.
Mar 23, 2011 | Yamaha XJ 900 F Motorcycles
Mouse chewed on right side center coil replaced coil and connector, but still wontfire on right bank
Sounds like the trigger to activate the on/off function of the coil is missing.Having power at the coil is good but to activate the coils build up/collapse you have to have a signal to tell it when to.You will have to back probe the trigger wire to find out where its been chewed with a continuity tester with noise.The noise option,multi meters,is very good if your doing a bit of testing on your own and tells you that cicuit is intact with out having to read multi meter screen.Good luck with it
Oct 31, 2008 | 2002 Jaguar S-Type
Garden Logo
46 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
