Question about Sony Playstation 3 (PS3) Console
Hard drive not found system wont do anything you have to unplug to shut it down held power button down after powering up it asks to push ps button and bring up menu but nothing works
  • 127 Answers
Has the console been opened or repaired before is so then the blueray was changed for a wrong one ,or it needs updating visit xbox360repairspro.webs.com
Posted on May 29, 2011
MY LAPTOP AFTER 2-3HR WORK SHUTS DOWN AND WONT TURN OFF.i HAVETO PRESS THE START BUTTON TO REBOOT-PRODUCT ACER F5
Just wanted to confirm a few things..
Did you do a hard power down by holding the power button down for 5 seconds or by just briefly pressing the power button (which would put the computer to Sleep).
I've found this laptop occasionally does not properly recover from Sleeping under Win8, that's why I ask.
Either way, do a hard power down by holding the power button for 5 seconds.
Unplug the laptop and find the battery disconnect pinhole switch underneath (indicated with a picture of a battery lifted up) and using a paperclip press and hold for 30 seconds.
Try powering on again, do you atleast get the Acer logo appearing when powering on?
Aug 22, 2016 | Acer Computers & Internet
I can't shutdown my laptop.
If you can't shut down normally (using windows), you can press and hold the power button until the computer shuts down. You can also remove the battery.
Make sure to save you work or anything that is open before you perform a hard shut down.
Feb 28, 2011 | Lenovo Computers & Internet
I was watching a dvd and ejected it with the eject button without quitting, then the screen went black for over 5 mins so i held down power button for 10-15 secs to shut down, turned it back on and it said...
Whenever you have a system that shuts down like that, you can expect to have hard drive problems.
ry accessing the recovery menu 'safe mode'.
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until you here 3 beeps. Let go.
If you have a HDMI cable, plug it up, if you have AV plug it in as well. If you have both settings on your TV, be sure to have them both inserted into the system. Also, make sure that you are switching your TV from HDMI to AV and vice versa.
It should ask you to connect your controller via usb and press the PS button in
the middle of your controller. There will be a menu with 6 options. Try 1-5
If none of this works:
ou will need to replace the HD.
When you replace your hard drive, you will need to have the latest firmware on a
usb stick. Download the firmware from the playstation official website onto a usb
stick. Once prompted by your system you will need to insert the usb stick into the
PS3. Good luck..
You will need 2.5" Sata Hard Drive.
Feb 04, 2011 | Sony Playstation 3 (PS3) Console
Bought a used (assumingly broken) 160gb PS3 Slim yesterday. When I first plugged it in, I got a full green light, the fan was on, but I was getting no video. I let it sit there for around 15 minutes, and...
There could be so many things wrong with this unit..
If you are getting the light sequences, but at times it powers up, then you will have your hands full with troubleshooting.
Try accessing the recovery menu 'safe mode'.
the middle of your controller. (if applicable, try to use both HDMI and AV, switching from one input to another on the TV)
If you do not see this menu with either HDMI or AV/Component cables, you will need to try replacing the hard drive..
PS3. Good luck..
When you need to power down the system when it freezes, hold the power button until it goes off. At times it can take up to 2 minutes, or more.
Has it ever been opened?
Look underneath the system, do you see a 'Warranty Seal' sticker?
If not, it has been opened and your problems will have to be solved by a technician who has experience.
Good luck with this unit.
Jan 26, 2011 | Sony Playstation 3 (PS3) Console
Cannot start . the correct hard disk was not found
Hold your front power button down until it beeps the third time and shuts off. Then hold it down again it will beep two time and the third time will be two quick beeps, let go. It will ask you to plug in your controller with a USB cord and press the PS button. A menu will pop up. Try option 3 Restore File System. When it's done see if it boot up normally. If not do this again and try option 4 Rebuild Database. If that one doesn't work then you will need to try a different hard drive. Sometimes after you intall a different hard drive then put your old one back in it will work. If not you can just use the new hard drive. If you're not sure how to install another hard drive look it up on playstation.com. One of these should definitely fix your problem.
Sep 26, 2010 | Sony Playstation 3 (PS3) Console
Cannot shut off & no display
The eMachines M5105 is notorious for failing to boot if left unplugged and powered off long enough for the battery to become mostly discharged. Plugging it in to AC power will cause the battery to start charging; and the hard disk drive to spin while the CPU cooling fan cycles on and off vigorously. THE UNIT WILL NOT BOOT UNTIL THE BATTERY IS NEAR FULLY CHARGED; then THE AC DISCONNECTED; and then THE (charged) BATTERY REMOVED AND RE-INSTALLED! Most units will boot after following the foregoing procedure.
Jun 24, 2009 | E-Machines M5105 Notebook
Dualshock 3 sixaxis why does it always need to be plugged in
Once the controller is plugged in and connected to the console, hold down the PS button to select "turn off the system." Once the system has completed shutting down, unplug the controller and press the PS button. The console should turn on. If so, the controller will connect wirelessly. Unfortunately you'll have to do this with each controller but it works every time.
Feb 19, 2009 | Sony Dual Shock 3 Controller for...
Orange light on instead of green light..also 3 and 4 number light up
When I first started repairing things a mentor said always unplug anything you are working on. I found this to be a number one rule. You just don't know what still has power even though it says it's off. I've made this mistake too by not checking.
Okay. So...
Hopefully the power supply is just shutting down due to a drain on it's voltage and will be okay. Take out whatever you tried to install. Try it again. Take out anything not necessary to boot your computer. You'll need the video card if not integrated. If you have a bootable floppy, Unplug the hard drive. See if you get to a screen where you can go into the bios setup mode. You also might want to write down where things go back. This is especially if doing this with little sleep. Let me know..'ask me.'
Sep 14, 2008 | Computers & Internet
Computer powers off during boot
Hmmm...try resetting CMOS & checking all external peripheral connections: (KB/mouse, monitor, etc.)
Oct 26, 2007 | ASUS A8N-E Motherboard
Froze
Hold the power button down and the UP volume botton at the same time to reboot it.
If that fails youll have to le t the battery die and recharge it, that will reset it.
Oct 02, 2007 | Philips HDD1630 MP3 Player
Sony Playstation 3 (PS3) Console Logo
19 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
