Question about Kenmore Progressive Upright Vacuum with InteliClean System Slate Blue
Motor on agitator won't run - Kenmore Progressive Upright Vacuum with InteliClean System Slate Blue
  • 3 more comments
  • cyrusw May 27, 2011
    This unit is supposed to be Direct Dive- does that have a belt? Is there some way to check the drive motor?
    This is an Upright Vacuum cleaner, with maybe a separate motor on the beater?? There is no motion on the beater even when the suction is pulling very well...
    Is this a DIY or do I need tobreak down and go to the Sears Repair place?
    Still looking for advice- go to the shop, or can I do this myself?
    Rickead1- this is a Vacuum cleaner- do you have some data on them?
  • 710 Answers
Hi cyrusw,
Direct drive means that the agitator is driven by its own motor, which means there are no belts to change.
The motor could have one of two problems why it doesn't run.
The first is easy. There is an agitator overload sensor that turns off the agitator's motor should there be too much stuff stuck in the agitator making it difficult to turn. The solution would be to clean it and then push the reset button that is on top of the base on the left side as you're facing the cleaner.
The second possiblity is that something might be wrong with the agitator motor itself. In this case it would need servicing.
Please reply back if you need an owner's manual.
I hope this helps. If it does, I'd appreciate a 4 thumbs up. Keeps me working... Thanks,
Handie Andie
Posted on May 28, 2011
  • 1,998 Answers
Is this a washer or a vacuum if its a washer please send the model number as I will be able to provide a schematic to help in further diagnosis thanks Rick
Posted on May 27, 2011
  • Rick Ead
    Rick Ead May 28, 2011
    yes do you have a model number of the vacuum so I can look the unit up? Thanks Rick
  • Rick Ead
    there are 3159 kenmore vacuums a model number would help me narrow it down to which one Thanks Rick
  • 4,323 Answers
Hi
You can check the motor for 120VAC, if that is fine then it means the motor coupler should be replaced. Please check this video:
Hope this helps...please post back for further assistance.
Daniel
  • 2 more comments
  • Daniel Scott
    Daniel Scott May 27, 2011
    Yeah wrong video, my bad....the motor is bad and should be replaced
  • Daniel Scott
    Check this video and then decide if you want to do it yourself:
  • Daniel Scott
    Its just an example but will help you......post back for further assistance.
  • Daniel Scott
    That was the reason I gave you the video, it's better to get it done by a tech.
  • 776 Answers
This is posted under vacuum cleaner. Just making sure because there have been some sorting issues this week. There is likely a broken belt to the agitator. Replacements take about an hour and cost $5 to $10.
Hoover spirit 900 canister wont turn on?
see this causes and fix it. God bless you
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
Sep 27, 2012 | Hoover Vacuums
Beater bar motor quit, now the main motor quit. Replaced the on/off switch. still nothing
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced.
Sep 27, 2012 | Vacuums
Power is not coming on
Sep 27, 2012 | Wagner Spray Tech Wagner 915 1,500-Watt...
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
MY DC17 WITH NOT RUN, CAN IT BE THE MOTOR. IS THERE ANY WAY TO CHECK THE MOTOR? THANKS EARL
Hi Earl,
I'm sorry to hear you're having difficulties with your DC17. If the machine won't run at all, it's probably best if you get in touch with us directly. We'll be able to run through some troubleshooting over the phone with you to determine the cause of the issue. You can call us free on 1866MYDYSON - we'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Nov 28, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Shark SV736R motorized brush won't rotate
The 2 metal pins of the motorized brush are not in contact with the vacuum cleaner. or the Motorized brush is clogged up. You have mentioned that it is cleaned, but still give a thorough inspection. For the metal pins, firmly insert the motorized brush into the air-intake nozzle. This will connect the motorized nozzle to the unit power supply.
Oct 21, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Motor runs, brush won't turn, burning rubber smell
Easy to fix. The burning rubber smell is hair in the roller against the belt! Congrats, you have a healthy vacuum, you are lucky! Unplug the vacuum, remove the screws that cover the belt and roller brush. If you are nervous, take pictures with a cell phone or digital camera as you go for re-assembly. ok, pull the long roller out of it's slot and out of the vacuum. cut all hair off the roller and carefully move the belt from side to side to do the same. If the belt slips off, it slips back on easily. If the area is too tight for fingers guide it back on with any long thin wooden object. You can squeeze the belt to narrow it and slide it back over the thin metal rod that spins it from the motor. Slide the roller through the belt and back into it's slots. If it won't slide back on, turn it a quarter turn. Repeat till it does slide back into place. Put the face plate back on-tighten screws, flip it over, plug itr in and it should work!
Sep 05, 2011 | Bissell Vacuums
Power light on but motor won't run. where do i
the motor carbon brushes need replacing which is a most difficult job to get the cleaner disassembled. Brushes are easy to fit if You have replaced carbon brushes in other appliances etc..
Getting to the brushes in the Kirby is very difficult...
Lee in Australia
Jul 28, 2011 | Kirby Generation 3 Bagged Upright Vacuum
My Dyson DC16 usually shuts down after about 5 to 10 seconds. However, occasionally it will run for 45 seconds to 1 minute before shutting down. It is left on charge permanently. I have checked the...
Your battery is losing voltage too quick. It has probably developed a 'memory'. Dyson claims that their handheld has the best suction out of all the handhelds out there. In order to maintain that claim the circuit board will shut off power to the motor when the voltage drops below adequate charge for full suction.
We need someone who can teach us to bypass that part of the circuit so it won't cut power to the motor or you need to get a new battery.
Shorting the battery like an Aircraft battery then re-charging won't fix it.
Mar 23, 2011 | Dyson DC16 Root 6 Bagless Handheld...
Motor on our kenmore progressive agitator is not
Look for a reset button on the motor and press it in. If it clicks, then it was tripped. An excessive load on the motor can make the reset trip. Try turning the motor shaft to make sure that it is not bound up. Run the machine empty for a short time to see if it works. Good luck!
Jul 16, 2009 | Kenmore 31913 Progressive Direct Drive...
Kenmore Progressive Upright Vacuum with InteliClean System Slate Blue Logo
189 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
