Question about Garden
Hello - I just purchased a mastercraft plunging router that came with a set of bits included. The bit shank seems too large for the collet. Am I missing something or is it as simple as a bad fit?
    Sergeant:
    Champion:
  • 338 Answers
Should have two different collets- one for fine bits and one for larger bits
Posted on May 27, 2011
I have a B&D Router KW850E. It has collars and collet nut to take bits with 1/4 inch and 5/16th's shank. Can I get a collet nut and collar for 12mm or 1/2 inch?
probably not as the shanks of the router bits fit in the spindle shaft of the router which is around 1/2" dia
could always talk with manufacturer as to find an adaptor or like bit of equipment
Jan 19, 2017 | BITS Tools & Hardware - Others
How do I change bits on P/Cable 690LR?
If the collet was tightened without a bit in it, it may have been squeezed so it is too small for the bit shank. Completely unscrew the collet from the router and see if the bit will go into it. If not, you can try forcing an old bit in using your vice, and then using as hammer and punch to remove the bit, but most likely you will have to get a new collet. Just search "Porter Cable router parts to find a source.
Jul 19, 2014 | Porter Cable 690LR Router
Router bits wont fit on my router collet nut is to small.
The two sizes (in the US) for router bit shanks (and collets) are 1/4 inch and 1/2 inch. Some routers use only a 1/4 inch collet. Routers with a 1/2 inch collet also come with a 1/4 inch collet. You need a 1/2 inch collet to hold a 1/2 inch shank. Good luck.
Jan 16, 2013 | Tools & Hardware - Others
Router bits
Mike, The fit is just a little more snug than you expect. The collet is springy, and will expand to fit your bits, even if they were oversize (which is very unlikely). Put on a leather glove and just push the shank of the bit into the collet. Do not try to file down the shank of your router bits, you will only make them run eccentric. You don't need to remove the collet. Just loosen the locking nut about a half turn after it is easy to turn. Good luck. Thanks for using FixYa. Al Kupchella
Apr 20, 2010 | Freud FT2000E 3 Router
How to connect 1/2 inch router bit into dewalt router
Are you asking how to put a router bit with a 1/2 inch shank into a router with a 1/4 inch collet? You need a 1/2 inch collet. Most routers with a 1/2 inch collet can also use a 1/4 inch collet. But smaller routers cannot use a 1/2 inch collet.
If this isn't clear, please ask again.
Al K
Mar 29, 2010 | Dewalt DW621 Routers
Bits do not tighten in arbor
remove collet clean, and clean collet chamber lubbricate and replace. make sure corect size of collet is being used for bit shank.
Oct 26, 2009 | Craftsman Tools & Hardware - Others
The router bits will not fit in the collet. When the collet snaps into the collet nut the bit does not fit.
The collet is loosely screwed on, correct?
Is it close, or 1/4" off. You may need an adapter for different sized bits.
I have noticed, particularly with Freud bits, that they seem a bit oversized. Try putting the bit in the collet before you insert the collet into the router.
If you're very careful, you can use fine emory cloth (like 400 grit or higher) to polish the bit by cutting a long strip and clamping the bit in a vice, then gently polish the shank a little to allow it to fit into the collet. Pull back and forth on the ends of the sandpaper like you were buffing shoes, but I would only recommend this if you can use a micrometer to check the shank and it is in fact oversize.
You could create a dangerous situation if you polish too much and the bit is not held securely in the collet and flies out when the router is under load.
Another technique is to sand a slight chamfer on the end of the bit to help it slide into the collet.
Or return it and try another brand.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 15, 2009 | Freud FT2000E 3 Router
I am unable to get a tight fit on my router bit.
could be a couple things. First how is the shank on the bit e.g. is it worn down, second is it the right size for the collet being used (have to ask) and what is the condition of the collet and collet nut. What I would do is make sure there is nothing to prevent from completely tightening the collet nut. Also make sure if the collet locks into the nut that it is properly installed. Lastly make sure that you use the wrenches provided to tighten the assembly. If this doesn't help please provide the model number and brand and I will do some more research.
Jan 02, 2009 | Milwaukee 5615 21 Factory Reconditioned 1...
Different Bit shanks
Those with larger bit shanks can hold larger blades. For large joinery cuts, buy a router with a large bit-shank diameter.
Aug 27, 2008 | Dewalt DW618PK Factory Reconditioned 2 1/4...
Garden Logo
75 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
