I undocked my compaq 6320 laptop - just after accidently hitting the dock- power button (before hitting the eject button). I ejected the computer but noticed it began to start-up but shut down because my laptop lid closed. Now I cannot get my laptop power button to function. I can get the laptop to start up - in the dock ONLY. In the dock the laptop power button works but if I eject the laptop it shuts down and the power button does function. I have tried a complete shutdown (in the dock). Ejecting and trying to start it undocked - without success.
    Sergeant:
  • 231 Answers
Have you tried holding the power button for about 6 seconds - try shutting it down that way. Then try starting it.
Posted on May 27, 2011
  • 159 Answers
Try removing the laptop from the doc, pulling out the battery, hold the power button down for 10-20 seconds, and re-install the battery.
This should drain out the laptop and it should boot up properly without the dock.
Manual eject button
Restart your computer. That should fix it if I understand what you wrote correctly.
Jan 07, 2014 | Computers & Internet
Toshiba undock
Hello Eleanor,
By your question I can not tell if you have used the docking station or not so here is the removal procedure for a Hi Speed Port Replicator II
To disconnect the Port Replicator, follow the steps below.
1. Set the computer lock to the unlock position.
2. Make sure you perform
one of the following:
• Save all your work.
• Turn off the computer's power in any mode: boot, suspend or hibernation.
• Perform any software disconnect operation required by the operating
system.
• Press the eject switch.
CAUTION:
Make sure the Eject LED is out. Do not try to disconnect the
computer while the Eject LED is glowing.
3. Pull the eject lever out towards you to disconnect the computer.
4. Lift off the computer
Now if there are further problems or this did not help you please post further information like at what step did the station not perform correctly. Hope this helped.
Nov 29, 2013 | Computers & Internet
Eject ds829av
Try taking the power plug off and plugin it back on... Press it while com loading.
Aug 16, 2013 | Compaq Presario V4000 Notebook
How do I eject cd tray on latitude E4310 ?
don't know of that labtop but hit start, hit computer, right click on cd drive hit eject.
Jan 17, 2013 | Dell Latitude E4310 Laptop Computer (Intel...
Loaded a cd to upgrade firmware, firmware would not load. eject button would not eject. read manual, says to push eject at the same time you plug in the electric cord,still would not eject. Any...
Please try in this way.
Disconnect power.
Connect power back, and keep REPEATEDLY pressing the eject button while you connect. If still no ject press power on button while you keep hitting the ehect button. You need to press eject on the unit, do not use the remote.
If that does not work, then the unit must be taken apart.
Dec 09, 2010 | Cameras
Dell D630 Docking Station
First option if using Windows XP is to undock the system then delete the Docked hardware profile in Device Manager, Hardware Tab, Hardware Profiles. Once deleted, power off, dock the system, boot, Profile recreated.
Jun 28, 2009 | Dell Latitude D600 Notebook
Turn off laptop to undock/dock?
Yes, You can just push the big "undock button and undock it anytime.
However, if you are using a "hardwired" internet connection, you will lose connectivity.
Otherwise, it is perfectly fine to do so.
Rick in Phoenix
Apr 02, 2009 | Dell D/Dock Expansion Station Docking...
IBM Thinkpad T41 docking station USB ports
Try removing all the USB devices in Windows Device Manager with the laptop docked. To do this: Right-click My Computer, left click Manage. On the right side of the window, click Device Manager. On the right side, click the + sign next to USB Devices. Highlight each device under this heading and hit Delete on your keybaord to remove all the devices in order. Then right-click Computer at the top of the list and click Scan for Hardware Changes.
Hopefully Windows will re-detect your USB devices and get them back operational.
Hope this helps!
Jan 30, 2008 | IBM ThinkPad T41 Notebook
Removing laptop from docking station
If you have the ArmadaStation EM:
The issue of removing the notebook is compounded by the fact that the ArmadaStation EM uses a motorized dock/undock mechanism to remove the notebook. When the expansion base has no power, it is unable to eject the notebook with the motor
 To manually remove the notebook, use manual eject lever to push notebook out of ArmadaStation EM. The manual eject level is a small white lever located inside the back cover of the base. To remove the notebook, push the white lever to the left. Slight pulling is required to remove the notebook completely out of the base.
Hope this helps!
Jan 15, 2008 | Computers & Internet
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
