Question about Thermador CVS236 36" Cook 'n' Vent System Kitchen Hood
Need to know how to wire thermador cv2236 - Thermador CVS236 36" Cook 'n' Vent System Kitchen Hood
How to replace spark module?
How to replace spark module Todd, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/42129-thermador-spark-module-replacement.html
Thermador Stove Burner Won Light
Burner on Thermador cooktop won light
Mar 22, 2016 | Thermador Cooktops
Thermador CM302 f63 error code
overheat situation. check oven sensor and soldered pin points for sensor wires at relay board. Resolder if needed.
Feb 10, 2013 | Thermador C301U Electric Single Oven
Thermador RES 30 range. I need wiring color and connection assistance to the display assy. I sent the display in for repair and now I am re-installing it. I thought I marked the connections down...
That is proprietary Thermador information, they are the only ones that can provide that. Was it Thermador that you sent the display into for repairs? If so they should definitely be able to give you the information you need. Do you need their phone number?
Please let me know and I can definitely help, thanks
Tim
Sep 10, 2010 | Thermador Microwave Ovens
Need info on how to change wiring from recirculation to remote
get another electrician, he doesn't know what he is doing, this is not easy to figure out without diagrams of the connector that shows exact wire colors and where they go or went in prev installation..
Apr 10, 2009 | Thermador UCV36ASS Kitchen Hood
I need to self- clean my Thermador convection oven
hi,
here is the manual for your oven try to follow them and make them as your guide enjoy..
click on this site..
http://specs.retaildeck.com/CACHE/FILE2202.PDF
thank you,
please don't forget to rate our answers.
Feb 19, 2009 | Thermador C272 Electric Double Oven
Thermador oven control panel light is not working
Please see post by bonanzsapilot on 14 March 2009; he gives exact & easy to follow directions for making this repair for <$10. It's listed uner 'Thermador SC301IT oven - FixYa'. In a separate post I added the correct capacitor numbers from Newark.com. I made the fix in abt 30 min & it's good as new. Thermador no longer makes control panels for this oven & no wiring diagram is available to help. Shop price was estimated at $500.
Nov 16, 2008 | Thermador SMW272 Electric Double Oven
Part 415191 Connection Tail Membrane
We are having the exact same problem with this part! Our oven is a S301T, but it still has the same part number for the tail membrane (touch control).
In FINALLY contacting someone at Thermador we were able to find the following information which might aid you. The part is manufactured by Bosch and according to Appliance Pros.com, the numbers:
Part Number 415191 Manufacturer's number (Bosch) Part number AP2832583 which replaces the part number originally numbered 14-38-680.
Don't know if this will help....it hasn't helped me so far. Thermador suggested that we go to a site named OBSOLETEAPPLIANCEPARTS.com. This site seems to be really messed up because you have to call and leave a message as the site is under construction!
I'm so darn frustrated that I'll never buy a Thermador product again (even thought they are great when they work) Good luck!!
Oct 22, 2008 | Thermador 37 in. SGSX365 Gas Cooktop
Thermador Convection Oven
well im not terribly familer with thermadors wiring but pull the top off and find the tech sheet then look for a device call a thermal fuse or tco thermal cut off most times they are on top or on the back of the oven yours should have one for each oven bet the one for the top is open can happen if there installed in to close a space
Jan 30, 2008 | Thermador SC302T Electric Double Oven
Thermador CVS236 36" Cook 'n' Vent System Kitchen Hood Logo
266 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
