Question about Kenmore 18.2 cu. ft. Top Freezer Refrigerator w/Factory Installed Ice Maker
Ice forming in the top freezer, leaks in the bottom refrigerator section
    President:
  • 670 Answers
Sounds like the defrost circuit of your fridge has failed. If you remove the back panel of the freezer compartment, you will see the evap coil encased with ice. Normally the defrost circuit will turn off the compressor and turn on a heater to warm the coil to about 45 degrees to melt any frost build up. After about 40 minutes the compressor will kick back in to keep your fridge cool again.
The typical failures are that the defrost heater burns out. If you have an older fridge, the defrost timer fails to advance, causing the fridge to stay in cooling or defrost mode.
Posted on May 27, 2011
Water leaking from bottom front, ice in bottom of freezer
Your drain line form the evaporator is clogged. Locate the drain under the back and use a wet/dry vacuum to unclogged drain. The drain line can be also blocked by excessive ice buildup from incomplete defrosting. Remove frozen foods and open door to freezer section and remove power and manually defrost unit. Once ice is stopped melting try vacuuming the drain line again. Sometime drain line gets clogged with debris such as garden peas, corn, wrapping and the like. Once drain line is cleared the water and ice on the freezer bottom should stop forming.
Hope this helps
Dec 12, 2014 | Refrigerators
My fridge-freezer (FFM90) has ice forming in the bottom of the freezer section under the last drawer. Why is that and what can I do?
This is due to excessive condensation and in bottom freezers due to proximity of the compressor.There is some residual water falling on to the drawers which forms the ice and this must be prevented. make sure that the frozen foods that was stocked did not loose water into the bottom till we can suspect the freezer. Also frequent opening of the freezer will allow for condensation whicj must be wiped out at intervals.
This can prevent some ice formation and also check if there is leak from the evaporator trays to the freezer during defrosting.
Sep 29, 2010 | Hotpoint FFM90 Bottom Freezer Refrigerator
Water collecting in bottom of freezer
Your seal may be bad letting in moist air that provides a source of water to condense on parts of the freezer.
Jul 24, 2010 | Kenmore 53703 / 53706 Stainless Steel Side...
Water on the top shelf of the refrigerator
Your defrost drain is clogged and now the defrost drain trough has filled with ice causing the water from your defrost cycles to flow into the fresh food section. You will need to clear all ice form thr drain area and this is done thru the freezer wall and some models also have a removable bottom panel in the freezer that has to come out also to get to the drain. You can do this it will just take a little time. About an hour for a first timer with little experience. Good luck and hope this helps
Feb 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerator Freezer has ice forming in the bottom inside freezer section. It appears to be leaking down the back inside compartment. The top section has an ice maker and water dispenser but I haven't had...
I believe you just described a defrost condensate blockage that is causing the leaking. There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a in the defrost pan, water leaking and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
Nov 19, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice forming in the bottom of the freezer
Unclogh the drain hole inside the freezer in the bottom of the bakc wall pouring hot water until the ice melted and keep pouring until goes through.Repet this every 3 or 4 months to keep it clear.
Jul 22, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Water leaking and ice in bottom shelf of freezer
Chances are you have a bad seal around the door if it's leaking from the inside which causes the ice to form as well, or if it's leaking from under the freezer you lave a bad heating element that evaporates the water collected in the pan under the freezer or you have a clogged hose that goes to the pan under the freezer which also causes the ice to form because the water has no place to go. Defrost and try to find a way to blow out the hose that goes from your freezer to the pan under the freezer and that should take care of your problem.
Apr 18, 2009 | Refrigerators
Water collects in bottom of freezer forming ice which leaks.
your drain hole is frozen over u need to unthaw with a steamer
Mar 18, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Ice forming on bottom of freezer section. Water leaking in from back
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Nov 07, 2008 | Maytag MSD2454G Side by Side Refrigerator
NO ICE (ATLEAST NOT WHERE IT SHOULD BE)
Try to defrost the unit, after defrosting restart the unit and monitor. If ice formation still exist then unit a qualified technician. May be your unit has leak and under charge or need to be reprocess.
Jan 07, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
165 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
